Old 11-18-2013, 02:21 PM   #1
bobbybob OP
Oddometer: 638
Removing lower shock bolt--heat needed?
Changing out my shocks for Ohlins on my 2010 R12GS, 34K miles and they are TOAST. The Reprom calls for 212F heat to remove the swingarm shock bolt. Just how the hell are you supposed to heat that swingarm up without blistering the crap out of the paint--and maybe roasting some other components close by? I have a heat gun but if anyone has any experience and/or tricks for this, I'd appreciate you letting me know. TIA!
bobbybob is online now   Reply With Quote
Old 11-18-2013, 02:56 PM   #2
Quirky
Quirky's Avatar
Oddometer: 570
I've taken this bolt out with no heat on 2 new GS's with no issues. I recall the lower bolt on the front was a bit tight once and needed some heat.
BMW R1200GS, Husqvarna TR650 and Mrs Q is on a F700GS
SPOT link
Quirky is offline   Reply With Quote
Old 11-18-2013, 03:00 PM   #3
bobbybob OP
Oddometer: 638
Thanks quirky, maybe I'll just try it without the heat then. On my '07 RT I almost ruined the bolt head it was so damn tight. Didn't want a repeat of THAT! Maybe their shops have complained also, as heating it takes more time and can be risky.
But if anyone else has had to use heat, please chime in.
Old 11-18-2013, 03:21 PM   #4
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,379
You may or may not need it, but I would use heat just to make sure you do not gall the threads. Heat it until the bolt sizzles spit.
Jim
Old 11-18-2013, 04:28 PM   #5
bobbybob OP
Oddometer: 638
Jim, apparently you have done this before---how did you heat the swingarm up without blistering the paint or worse? Any tricks?
Old 11-18-2013, 04:39 PM   #6
Flying Tivo
Oddometer: 189
Soldering iron
If you have a heavy duty soldering iron you can try to heat it the bolt by itself.
Felipe
2013 1200GSW Brand Spanking New!
Flying Tivo is offline   Reply With Quote
Old 11-18-2013, 04:45 PM   #7
bobbybob OP
Oddometer: 638
I do have one--thanks Felipe--I will try that first. Dunno if the heat will make it thru to the threaded area of the bolt but its worth a try.
Edit: took a look, I think there will be too much "heat sink effect" for the heat to make it all the way to the threads. But I'll try it and see.
bobbybob screwed with this post 11-18-2013 at 04:56 PM
Old 11-18-2013, 05:32 PM   #8
JimVonBaden
"Cool" Aid!
Oddometer: 52,379
I usually use a heat gun. You can get one for $10 from Harbor Freight. No chance of damage like that.
Some also use a map gas torch, but you have to be more careful with it.
Jim
Old 11-18-2013, 10:33 PM   #9
Flying Tivo
Oddometer: 189
Look at it from the other side, and see if you can touch with the soldering iron the threaded side first.
Felipe
Old 11-19-2013, 01:01 AM   #10
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,013
A little heat properly applied will make things easier.
def is offline   Reply With Quote
Old 11-19-2013, 05:52 AM   #11
bobbybob OP
Oddometer: 638
Felipe
Didn't know the other end was exposed--I'll take a look.
Old 11-19-2013, 06:34 AM   #12
Dan Căta
Dan Căta's Avatar
Oddometer: 1,650
I doubt the threads are visible. Use a heat gun and you'll be fine ;)
Dan.
Dan Căta is offline   Reply With Quote
Old 11-19-2013, 06:43 AM   #13
JimVonBaden
"Cool" Aid!
Oddometer: 52,379
Felipe
There is no access from the other side on an R1200.
Jim
Old 11-19-2013, 06:52 AM   #14
bobbybob OP
Oddometer: 638
My heat gun is old, has only one temp--hot as hell. I think you could weld with it, lol. I'll pick up a cheap H-F 2-temp unit and use the low 500F setting. Just trying to avoid paint blistering and other unwanted effects. Like melting my rear fender extender.
Old 11-19-2013, 06:55 AM   #15
biometrics
biometrics's Avatar
Oddometer: 141
used a $10.00 HF heat gun...
I ride an R1100RT and used a $10.00 HF heat gun on the HIGH setting (carefully) and had no problems with paint blistering... just focus the heat on the exposed portion of the bolt... an infrared thermometer to gauge how hot you are getting it might also be helpful, although I didn't need one...
-John
biometrics is offline   Reply With Quote
Times are GMT -7.   It's 06:48 PM.
