Old 11-19-2013, 05:58 AM   #16
bobbybob OP
Oddometer: 707
Originally Posted by biometrics View Post
I ride an R1100RT and used a $10.00 HF heat gun on the HIGH setting (carefully) and had no problems with paint blistering... just focus the heat on the exposed portion of the bolt... an infrared thermometer to gauge how hot you are getting it might also be helpful, although I didn't need one...
-John
There is NO exposed portion of the bolt. Except the tip of the head and its 3" away from the threads and runs thru the swingarm and shock eye. No help there.
bobbybob is offline   Reply With Quote
Old 11-19-2013, 03:33 PM   #17
bobbybob OP
Oddometer: 707
Picked up a H-F 2-speed heat gun and heated it for approx. 25 mins--came loose pretty easily with the impact driver. Used my infrared heat gun to measure the temp. I knew I'd get a chance to use that one day. :)
Now I understand why you don't need to worry about the paint so much; the metal underneath soaks the heat away before it can build up enough to blister the paint, as long as you don't hold it closer than about 3-4".
Thanks for the tips guys!
bobbybob screwed with this post 11-19-2013 at 03:49 PM
Old 11-19-2013, 03:52 PM   #18
LaurelPerryOnLand
Oddometer: 3,481
On and Off?
Glad you had success!
LaurelPerryOnLand is offline   Reply With Quote
Times are GMT -7.   It's 08:53 AM.
