Old 11-19-2013, 05:51 PM   #1
Hubbman OP
Hubbman's Avatar
Oddometer: 722
(correction!) side stand in the way!
Does anyone else have an issue with your heel hitting the SIDE stand arm when your standing on the pegs? It seems that this shouldn't be an issue, but sometimes when I drop my heel, I wonder if it's a hazard... I'm mostly worried that it will activate the kill switch if I push it down too far.
BTW, I have 2011 GS, so I'm not sure if this problem is unique to my particular model year....
Hubbman screwed with this post 11-28-2013 at 10:19 AM
Hubbman is offline   Reply With Quote
Old 11-19-2013, 06:30 PM   #2
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,332
Originally Posted by Hubbman View Post
Does anyone else have an issue with your heel hitting the center stand arm when your standing on the pegs? It seems that this shouldn't be an issue, but sometimes when I drop my heel, I wonder if it's a hazard...
Yes. On a '13 wethead with lowered BMW enduro pegs and size 12ish boots. The deployment tang captures the heel of the boot if on the balls of my feet. I have to slide the left foot forward maybe 20mm if I want to pivot my left foot heel out without interference.
Annoying, as the bike is new enough that foot placement is not yet an automatic action.
marchyman screwed with this post 11-20-2013 at 12:33 PM Reason: spelling
marchyman is offline   Reply With Quote
Old 11-20-2013, 06:56 AM   #3
catch
Deutscher
Oddometer: 22
Put it on the side stand and give it a few hits with a rubber hammer. Worked for me!
catch is offline   Reply With Quote
Old 11-20-2013, 07:50 AM   #4
Smoke Eater 3
Oddometer: 660
I have a '14 GS. The center stand stem is a real problem for my size 11 boots off road. I cut about 4 inches out of it and welded the foot back on. It's perfect for me now. Someone light may need the extra leverage getting it on the stand but I have no problem.
'14 GSW
'02 Aprilia Mille
'66 R50/2 with hack
Smoke Eater 3 screwed with this post 11-20-2013 at 10:48 AM
Smoke Eater 3 is offline   Reply With Quote
Old 11-20-2013, 07:59 AM   #5
IB1
IB1's Avatar
Oddometer: 982
13 GS LC: Yes, but I got used to it.
Past bikes: 09 BMW F800ST
Current ride: 2013 BMW R1200GS
On order: 2015 BMW R1200GSA
Yes, still a rookie
IB1 is online now   Reply With Quote
Old 11-20-2013, 08:05 AM   #6
RomaDakota
Illuminatus!
RomaDakota's Avatar
Oddometer: 1,421
Centerstand no; side stand, yes. Aftermarket sidestand enlargers usually exacerbate the issue.
КМЗ Dnepr MT11 // КМЗ M72 // ИЖ Planeta 5 // КМЗ MV750 // Урал М63 // BMW R1200GS 30th
RomaDakota is offline   Reply With Quote
Old 11-20-2013, 12:23 PM   #7
justinallen03
Oddometer: 213
yes
but it went away when I put a GSA centerstand during my shock swap. I still feel it occasionally, but its not a problem anymore.
justinallen03 is offline   Reply With Quote
Old 11-20-2013, 12:34 PM   #8
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,158
You all realize..the Waterhead stands are completely different than the previous model, correct?
The OP has a '11 GSA..so it's old style..The Waterhead, didn't arrive until 2013
Yes, your heel will hit the SIDESTAND now and again..and you will notice it more if you have an enlarger on it..
"Ignorance is a powerful tool when applied at just the right time..sometimes even surpassing knowledge.." EJ Potter
Bill-66 is online now   Reply With Quote
Old 11-20-2013, 12:41 PM   #9
justinallen03
Oddometer: 213
Mine is a '10 GS, so still relevant. And actually i can't recall hitting the sidestand. My problem was the side of my heel would contact the centerstand lever when moving laterally, and I think its the same with the OP
Old 11-20-2013, 01:13 PM   #10
deacon51
deacon51's Avatar
Oddometer: 354
Same here....
deacon51 is offline   Reply With Quote
Old 11-20-2013, 02:35 PM   #11
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,158
Yeah..I wasn't referencing you, sorry..mine will vary actually as I move my foot around..Sitting..with balls of feet on pegs..yep..you are correct..standing...I feel the sidestand..and have accidentally killed the bike because of it..
Old 11-20-2013, 02:37 PM   #12
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,158
Originally Posted by deacon51 View Post
Same here....
How does this relate to the OP? He has a different style bike than you..
Old 11-20-2013, 02:46 PM   #13
deacon51
deacon51's Avatar
Oddometer: 354
We all got the same style feet...
Old 11-20-2013, 03:02 PM   #14
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,158
The stands are different on the bikes though...
Old 11-28-2013, 10:19 AM   #15
Hubbman OP
Hubbman's Avatar
Oddometer: 722
Exactly!
YES! This is exactly the issue I have. I cant believe this was how BMW designed this stand! And yes, adding a foot enlarger for stability only made a bad design worse.
Times are GMT -7.   It's 07:36 AM.
