Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 11-19-2013, 07:15 PM   #1
CanningOz OP
Oddometer: 63
1190 Adv Dyno test power outputs. How does this compare to yours?
I'm not sure if I should be disappointed with the measured power output of my 1190 Adv R that comes in with 127.3 HP, so to try and understand this I thought to start a thread and ask that when others test their bikes that power curves be posted so that we can see what is normal and what isn't.
My bike is fitted with a long Wings pipe with the bung removed. Apart from this it's standard and running on 98 Octane unleaded from BP.
Would love to know what other bikes are putting out just to check if mine is normal.
As a brief explanation, the upper curve is the final power output after fault codes were cleared that the dealer said were caused by the optional KTM bad fuel dongle. I know a KTM part causing fault codes doesn't sound right, but the dealer insists this is the case.
CanningOz is offline   Reply With Quote
Old 11-19-2013, 08:21 PM   #2
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 4,986
parasitic loss on a bike is somewhere between 15-20 percent....so your numbers look spot on...
'14 1190R...Adventure Beast
'13 690 Quest...Rally Beast
'15 Husqvarna 501...Trail Beast
950SE......Desert Beast
Nowwhat is offline   Reply With Quote
Old 11-19-2013, 11:31 PM   #3
CanningOz OP
Oddometer: 63
You may well be right but I think 20% is a lot of loss, especially when you look at most standard 1200 Multistrada's are testing between 135 - 145hp at the rear wheel. (There is a lot of test reports in the net)
The only Dyno test I can find on an 1190 Adv R is showing 148hp. See below from Remus.
http://www.youtube.com/watch?v=-QhOPsq1FdE
Guess I'm a little worried that my bike's air box wasn't screwed together properly (ie. not sealed at all) and I have be riding it a bit in dust. Is sealed now with uni filters installed.
So thought I'd ask what others have or will measure at the rear wheel just for a reference point, and figure if I need to be worried or not. If several others are sub 130hp, then I'll sleep easier.
I do understand there are marked differences between dyno's and parasitics might be as high as 20%. There also will be differences in ambient temp, humidiy, pressure etc. But 150 published and 127 actual on a recently calibrated dyno is a fairly large loss.......
Old 11-20-2013, 01:54 AM   #4
PPiA
Pete
PPiA's Avatar
Oddometer: 1,182
Phil, was that with the bad fuel dongle plugged in?
PPiA is offline   Reply With Quote
Old 11-20-2013, 02:52 AM   #5
LocuL
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,332
150 at crank and 127ish at the rear. Sounds correct and healthy.
KTM 950(1190) Adv-s, Soon to be Project 1190
KTM 530 EXC-R 08
LocuL is offline   Reply With Quote
Old 11-20-2013, 08:23 AM   #6
Scutty
Oddometer: 216
17.7% loss - its in the ballpark of expected
My bike anthology: Another KTM 690 Enduro R, BMW G450X, BMW R1200GSA LC, KTM 690 Enduro R, Yamaha WR250R, Yamaha XT600E, KTM 990 SM-T, Ducati Diavel, Kawasaki Z1000, Suzuki SV1000, Kawasaki Zx7-R, Honda VFR800, Honda CBR600F, Yamaha RD350, Yamaha DT175, Honda CM125, Kawasaki AR125, Kawasaki AE50 - wow I have owned a lot of bikes
Scutty is offline   Reply With Quote
Old 11-20-2013, 08:59 AM   #7
mousitsas
mousitsas's Avatar
Oddometer: 2,887
It is 15.5% on a bike not fully run in yet (that is a guess as I don't know how many kms you have). Sounds ok!
Crank power should be 147.
Old 11-20-2013, 04:26 PM   #8
CanningOz OP
Oddometer: 63
Green= Offroad
Blue= Sport without dongle
Red= Sport with dongle
All runs were done with traction control off
Old 11-20-2013, 04:37 PM   #9
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,436
How many miles on it?
2012 KTM 990 Adventure
Chuckracer is offline   Reply With Quote
Old 11-20-2013, 08:03 PM   #10
CanningOz OP
Oddometer: 63
5,500kms. Approx 3,500 miles.
Old 12-20-2013, 11:58 AM   #11
Wonway
KTM Fanboi #2
Oddometer: 428
Here is what my dealer's Demo bike did.
Red is with Akra slip on installed.
Wonway is offline   Reply With Quote
Old 12-20-2013, 12:23 PM   #12
OrangeV
OrangeV's Avatar
Oddometer: 661
Wow thanks for posting that, Im very suprised that the power difference
from 129.75 to 130.72 with Akra slip on is a 0.97 power gain .
Considering the Akra is a $1,599 Aud price hardly seems the effort.
Of course it looks great but you would think for that money it would give a bit more ...
75 V perky peak power from around 5000rpm and loves to be worked through the gears.
When you hit that sweet spot, it is simply electrifying. Stoner
A smile is a curve that sets allot of things straight..
OrangeV is offline   Reply With Quote
Old 12-20-2013, 12:25 PM   #13
Wonway
KTM Fanboi #2
Oddometer: 428
I was told that it actually lost a bit of power when it was put on. They made some adjustments (I'm not sure what they are able to do) to bring it up a bit.
Times are GMT -7.   It's 06:00 PM.
