Old 03-01-2014, 02:06 PM   #136
pilo OP
Rhymes with below
pilo's Avatar
Oddometer: 914
Re: Perm ODO
Currently the "B" tripmeter has a switch in settings so that it cannot be adjusted like the regular "A" and "B" ODOs. This means no incrementing or zero'ing. In the next version we are considering adding a password function on that ODO so a race organizer would have some visibility to the overall distance covered. We're also considering making the password function lock the App with an "SOS" mode that would allow exiting the App but would record the SOS access.
Would any of this be of value?
pilo is offline   Reply With Quote
Old 03-02-2014, 01:56 AM   #137
640 Armageddon
-oo-
640 Armageddon's Avatar
Oddometer: 2,633
The sos function would be nice. You could even ''simulate'' the iritrack buttons, and send predefined text messages if a sim card exists.
About the sos, this is a safety feature that everybody would like, and since gps is active I would suggest to create at some poin a feature that it sends the coordinates to predefined numbers and keep trying to do that until a signal is found (if there is no coverage).
I dunno if the overall distance is critical for the organiser, critical would be for example to record the gps path so the orga can compare it with the predefined one, but then again most (if not all...) races have trackers. Another idea would be to record the paths, and share them around
Aurora Rally Equipment - Rally parts with lifetime warranty
"Do or Do Not. There is No Try" - Yoda
640 Armageddon is offline   Reply With Quote
Old 03-02-2014, 07:31 AM   #138
Scotty Breauxman
Baja Breaux
Oddometer: 364
I tested RB yesterday vs a roadbook made from a GPX file in Rally Navigator.
Flawless!
Later around the campfire, I was explaining RB to Jimmy Lewis when he pulled his phone out with RB and I quote,"It's the best odometer there is."
Scotty Breauxman is offline   Reply With Quote
Old 03-02-2014, 07:57 AM   #139
Whatever Dood
No title available
Whatever Dood's Avatar
Oddometer: 36
Wow
Flawless!
It's hard to explain how satisfying it is to read that. Thanks so much for the kind words! Please let us know if you find any bugs or have feature suggestions.
All the best,
Rich (RB code monkey)
Whatever Dood is offline   Reply With Quote
Old 03-02-2014, 09:00 AM   #140
HogWild
Scott Whitney
HogWild's Avatar
Oddometer: 2,712
What I want as an rally organizer is the ability to know if it was taken out of odometer mode at any time during the race. This is because normally it's not allowed to use any mapping or other smart phone navigation aids while racing. And if they do anything like that, we need to know so we can apply a penalty.
If RB recoded the time it was last taken out of odometer mode, then we can see if that time was during the race. There must be no way to bypass it into not recording this time, such as turning off the phone while the app is running, or other tricks. Maybe also record the time RB was last started, so we can verify that time was before the race started, and not some time in the middle of the race. Then make an easy way to access these two times, so officials can quickly verify them at the finish of the stage. Or maybe you can think of another way to verify that no other apps where used during the race? Or maybe the SOS function you're already considering does this, and I don't fully understand it yet.
New desert racing frontiers
It will be Devilish !
HogWild is online now   Reply With Quote
Old 03-02-2014, 01:58 PM   #141
kramsetac
The Dude Abides
kramsetac's Avatar
Oddometer: 143
Poorman Case
Hopefully not too much of a derail. Want to get a trick HDB case, but got impatient, so cobbled together a case out of stuff in the garage: Pelican 1015 Iphone case, diamond RAM base, a SAE to USB converter and a Powerlet to SAE cord. Not zip tied or shrink wrapped (USB connection) but seems like it will work as an interim. Pics below:
Mark.
'06 TE610
'05 R1200GS
'02 200EXC
kramsetac is offline   Reply With Quote
Old 03-02-2014, 05:01 PM   #142
Mr Head
PowerPoint ADV
Mr Head's Avatar
Oddometer: 7,375
I finally got around to mounting my phone to the bars, looks cool.
All I'll be doing initially is checking my speed and odo against the bikes readings.
...Dick
"You don't go to Mongolia for the food." - Sebastian & Kim
2010 KTM 990 Adventure R
My Life With The 990R
Smugmug
Mr Head is online now   Reply With Quote
Old 03-25-2014, 06:18 AM   #143
MaxThePanda
Psycho Panda
MaxThePanda's Avatar
Oddometer: 89
Originally Posted by theantipaul View Post
Not for a while guys, still need a cable so I can integrate that into the design. The app does work in the cold too.
Hey Paul
So, when you say 'not for a while' does that mean a month, 3 months, 6 months? I'd love to do away with cables and run one of these to replace an ICO at the Amageza Rally in South Africa in November >
Whaddya say?
cheers, Ian
MaxThePanda is offline   Reply With Quote
Old 04-03-2014, 02:15 PM   #144
Gany
Oddometer: 340
Anybody run this off battery only? Any idea what sort of battery life I might expect running just this app?
Gany is offline   Reply With Quote
Old 04-03-2014, 02:24 PM   #145
Whatever Dood
No title available
Oddometer: 36
RallyBlitz turns the iOS device location sensors up as high as they'll go, so your battery will drain pretty quickly. My relatively young iPhone 5 will drain in a little over hour when RB is running on battery power alone.
Old 04-03-2014, 03:12 PM   #146
Gany
Oddometer: 340
Thanks, sounds like running power to the phone is a must then.
Old 04-03-2014, 03:14 PM   #147
Whatever Dood
No title available
Oddometer: 36
Definitely!
Old 04-03-2014, 03:37 PM   #148
Super Dave Hawaii
Ain't Dead Yet!
Super Dave Hawaii's Avatar
Oddometer: 248
Zero B screen
Is there a way to zero B screen? I don't see a switch and see it tracks total miles.
Dave
2001 XR650L With 112,034 miles. Nicest one around! CRF450 Rally Bike.
Super Dave Hawaii is offline   Reply With Quote
Old 04-03-2014, 06:38 PM   #149
Whatever Dood
No title available
Oddometer: 36
Dave
There sure is:
1. Tap the "Control Panel" button (top-center).
2. In the "Odometer Adjustments" section, tap the mileage value in the "B - Total" row.
3. You should be asked to enter an "ODO B Passcode". The default passcode is 0000 (four zeroes). You can change the ODO B passcode from the Preferences screen.
4. Once you enter your passcode you should be good to go!
Hope that helps!
Old 04-03-2014, 07:26 PM   #150
Super Dave Hawaii
Ain't Dead Yet!
Oddometer: 248
Originally Posted by Whatever Dood View Post
There sure is:
Hope that helps!
Hey DOOD,
Worked like a charm. Thanks for the help.
Dave
Times are GMT -7.   It's 09:28 PM.
