Old 11-22-2013, 10:02 PM   #1
Brown Town OP
Brown Town's Avatar
Oddometer: 195
Dealer Build Mistake
So I was doing some work on my 990 Baja today and noticed that whomever built the bike either lost or was unable to find the little plastic piece that sits under the crash bar clamp and protects the frame. Unfortunately, as a replacement, they used the rubber O2 sensor wire strap and you guessed it...the sensor wire. Upon inspection the wire sheath is definitely damaged but I can't tell if the wire inside is totally effed. I'm going to bring this to my dealer's attention first thing tomorrow however my question for you all is what would be the result if I rode the bike with the wire severed?
-BT
Brown Town is offline   Reply With Quote
Old 11-22-2013, 10:32 PM   #2
tacosupreme
tacosupreme's Avatar
Oddometer: 269
Funny, my 2012 had the 02 wire smashed as well, and I didn't know there is a frame protector (if there is mine are missing). Mine weren't smashed to bare wire, so I just taped them up. If yours are down to bare wire, you can repair them or just get a new 02 sensor as it comes with a new pigtail past that point. Another option is to use tune ecu to turn them off completely. If you aren't comfortable doing that stuff and just want to take it to the dealer...just ride it, it will be ok.
'12 990 with some orange stuff on it to make it go faster.
tacosupreme is offline   Reply With Quote
Old 11-22-2013, 10:45 PM   #3
Brown Town OP
Brown Town's Avatar
Oddometer: 195
I'm guessing the FI light would come on if it were severed?
-BT
Old 11-22-2013, 10:48 PM   #4
Denalidirt
High Plains Drifter
Denalidirt's Avatar
Oddometer: 921
2012 990
plastic piece?
Denalidirt is offline   Reply With Quote
Old 11-22-2013, 10:54 PM   #5
Brown Town OP
Brown Town's Avatar
Oddometer: 195
Originally Posted by Denalidirt View Post
plastic piece?
Wire. Right in the middle between the pipe and pigtail.
-BT
Old 11-22-2013, 11:00 PM   #6
Brown Town OP
Brown Town's Avatar
Oddometer: 195
plastic piece?
Sorry...you mean the little clear white plastic pieces that protect the frame from being marred by the crash bar clamps. The builder lost a couple and used the O2 sensor wire/strap in its place thus crushing the wire.
-BT
Brown Town screwed with this post 11-22-2013 at 11:11 PM
Old 11-23-2013, 12:01 AM   #7
Zuber
Zoob
Zuber's Avatar
Oddometer: 1,983
Very easy to clamp the O2 sensor wire while you are fighting the tank and crash bar install.
Those little clear plastic 'protectors' are useless. Very difficult to install and if you tighten the clamp down it will cut through them. They allow the clamp to slip on the slightest tip over. The clamp will then gouge the tank.
If the O2 sensor wire is cut, shorted, or has voltage out of spec, you'll get an error code. Since that hasn't happened yet, just tape it up keep riddin'.
Instead of the plastic thingies, wrap some aluminum sheet around the tubes. I used .050" thick scrap, about 1 1/4 x 2 1/2". It's just sticky enough to keep the clamp from slipping when you drop the bike. It has enough surface area to keep from scratching the powder coating on the frame. And, it's a lot less fiddly.
"Son, you can't do both"
Old 11-23-2013, 12:06 AM   #8
Brown Town OP
Brown Town's Avatar
Oddometer: 195
Thanks zuber, any idea if bicycle tubes will keep it from slipping/marring? Who carries .050" aluminum sheeting? Home Depot or metal supply?
-BT
Old 11-23-2013, 12:27 AM   #9
Brown Town OP
Brown Town's Avatar
Oddometer: 195
Also, how hard are you torquing (not to be confused with twerking) the bolts that clamp the crash bars to the frame?
And I'm sure it's very easy to clamp the wire but the fact that they used the wire strap as a substitute means they were looking very closely at the wire during the process. The whole build was quite shoddy actually...the bars were way off center, the front end was out of alignment, the hand guards were coming out of the bar they were so poorly installed...nonetheless I'm not complaining I have this awesome machine in my garage!
-BT
Old 11-23-2013, 02:06 AM   #10
种.
Ajaa kuin mummo
种.'s Avatar
Oddometer: 280
I used 4 mm inner tube on mine. No problems.
Pics and vids
种. is offline   Reply With Quote
Old 11-23-2013, 04:18 PM   #11
Weldit
Weldit's Avatar
Oddometer: 336
I took 4 pieces of small rubber 1/8" vaccum hose 2.5" long
and split them down the length then used these to replace
the white plastic things - which were all destroyed anyways
hope that makes sense.
looks cleaner than a big piece of rubber inner tube
I think some colored vaccum hose would be even better !
'11 Dakar 990
Weldit is offline   Reply With Quote
Old 11-23-2013, 04:24 PM   #12
Deuce
Crazy Canuck
Deuce's Avatar
Oddometer: 2,785
Being a Canuck I just used hockey tape wrapped around the frame where the clamp attaches.
I'm not lost for I know where I am. But however, where I am may be lost.
-- Winnie the Pooh
Deuce is offline   Reply With Quote
Old 01-09-2014, 03:43 AM   #13
Bowser
Oddometer: 165
nope, the FI comes and the main fuse blows and you stop, well at least my son did when riding my bike after "I" had done some maintenance and got the wire caught without realizing it, man was he pissed waiting at the side of the road for 4 hrs waiting for recovery!!!
However I can assure you that its a mistake you only make once!! Every time I take anything on or off the bike now I damn sure check that wire is not trapped.
Bowser is offline   Reply With Quote
Times are GMT -7.   It's 09:53 AM.
