Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 02-03-2014, 11:33 AM   #1
BassGT3 OP
Oddometer: 13
Question 1190 0il Level Checking
Hi Guys,
Can someone help me out please. I'm currently 2500kms from home and I forgot to bring the owners manual along with me. Doh indeed!!!
Can anyone tell me if there's an online resource for these, or alternatively, post up the exact process for checking the 1190's oil level and required fill levels.
Many Thanks,
Steve
BassGT3 is offline   Reply With Quote
Old 02-03-2014, 11:44 AM   #2
Tjeu
Oddometer: 143
When warm (is better), shut off engine.
Put on central standard.
Look in oilglas (left front). Max = +/-0.7cm from top. Lowest = +/-1cm from bottem.
Simple as that.
Tjeu is offline   Reply With Quote
Old 02-03-2014, 11:46 AM   #3
BassGT3 OP
Oddometer: 13
Simple as that.
Any minimum time to wait from shut off to using sight glass?
Old 02-03-2014, 11:49 AM   #4
Doug Matson
Doug Matson's Avatar
Oddometer: 2,004
Wait a few mins before you check. The manual says 3.8 ltrs is full but last week when i changed mine it took all of 4 ltrs to get it full. If you check it when the bike is cold just look in the site glass with it on the center stand.
04' 950 Adventure
03' 450 EXC
05' K1200 LT
93' XR 200
72' SL 100
67' Triumph Bonneville
70' CB 350
65' CB 160
Doug Matson is offline   Reply With Quote
Old 02-03-2014, 11:55 AM   #5
BassGT3 OP
Oddometer: 13
Thanks Doug.
So anywhere in the upper regions is ok? Just checked after a few thousand kms and the oil seems to be sitting very low. Wasn't sure if this bike ran a dry sump type arrangement that needed a specific procedure to fill.
and I'm flying home next week so I might bring enough oil and a filter for a full change back up with me. Motorex isn't so easy to get in the middle of Africa!!!
Thanks guys!
Old 02-03-2014, 02:11 PM   #6
Doug Matson
Oddometer: 2,004
Ya anywhere in the upper part of the glass is fine.
04' 950 Adventure
03' 450 EXC
05' K1200 LT
93' XR 200
72' SL 100
70' CB 350
65' CB 160
Old 02-03-2014, 05:23 PM   #7
kag
Wander Lust
kag's Avatar
Oddometer: 1,719
Just so everyone knows....3.8L is.... 4 quarts
“Always drink upstream from the herd”
2007 Yamaha TW 200 / 2008 Buell Ulysses
2013 Triumph Tiger 800r / 2014 KTM 1190 EDS
kag is offline   Reply With Quote
Old 02-03-2014, 10:24 PM   #8
BassGT3 OP
Oddometer: 13
Originally Posted by RobZorba View Post
Steve,
In case you need it before you get home, the online owners handbook link is here:
http://www.ktm.com/dealer-service/se...documents.html
Rob,
Many thanks.
Times are GMT -7.   It's 04:19 AM.
