Old 11-26-2013, 01:50 PM   #1
boyblu OP
Oddometer: 37
exhaust-pipe nuts
Most of you have already realized that airhead exhaust-pipe nuts do not nearly need to be torqued as recommended. A little beyond snug is all they need, some anti-seize on the threads. Ok?
boyblu is offline   Reply With Quote
Old 11-26-2013, 02:18 PM   #2
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,651
Ok.
crazydrummerdude is offline   Reply With Quote
Old 11-26-2013, 04:52 PM   #3
patrkbukly
52 Weeks of warm
patrkbukly's Avatar
Oddometer: 1,261
loose nuts
10-4
You only live once, but if you do it right, once is enough.
Mae West
patrkbukly is offline   Reply With Quote
Old 11-26-2013, 05:26 PM   #4
Beezer Josh
Moto-Amish
Beezer Josh's Avatar
Oddometer: 1,200
I prefer the use of the BFH-gets it nice and snug.
Beezer Josh is offline   Reply With Quote
Old 11-26-2013, 06:21 PM   #5
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 10,203
I may not put them on as tight as the book says but I do put them on f***ing tight. I use the BMW cast iron wrench and I hit it with a big hammer. If I had to remove these on the road it would be a problem. But if I had the wrench with me it would not be a problem.
I forget what the reason was or is. There's some reason why we are supposed to resist the temptation of putting these on too loose.
---Albert Einstein
Old 11-26-2013, 06:25 PM   #6
Beemerguru
Beemerguru...G/S guy
Beemerguru's Avatar
Oddometer: 1,027
Anti-seize on the threads and on the split rings
I also put it on the header.collector, muffler where anything slides into anything else.
Greg Hutchinson
BMW Club of Northern California, Ambassador, BMW MOA, Vice President Vintage BMW Club
http://gregsgssite.shutterfly.com/
Beemerguru is offline   Reply With Quote
Old 11-26-2013, 11:17 PM   #7
mesher
mesher's Avatar
Oddometer: 82
I would have thought that if they don't come loose, they're tight enough. If they leak you'd know it, and if they were falling off you'd know it, or is that too simple a view? Is there a soft gasket in there which would blow apart if they aren't super tight? Mine have never been off, so I have no idea. Is it perhaps an issue of efficient heat transfer away from the exhaust port?
mesher is offline   Reply With Quote
Old 11-27-2013, 05:21 AM   #8
ozmoses
Ride On
ozmoses's Avatar
Oddometer: 4,479
Block the crank!
Opinions are like internet connections- everybody has one.
ozmoses is offline   Reply With Quote
Old 11-27-2013, 05:31 AM   #9
boxermoose
Now fully goosed
boxermoose's Avatar
Oddometer: 2,851
Originally Posted by ozmoses View Post
Block the crank!
I believe the OP is being sincere
Sometimes you get the ABAT....and sometimes the ABAT gets you
boxermoose is offline   Reply With Quote
Old 11-27-2013, 05:58 AM   #10
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,874
Optimal TA anti sieze and tightened hand tight with the exhaust spanner for me. Never had one come loose and they don't blow. So yes just as the OP says.
Rob Farmer is offline   Reply With Quote
Old 11-27-2013, 06:51 AM   #11
Beemerguru
Beemerguru's Avatar
Oddometer: 1,027
No soft gaskets but you do have to compress the split ring inside the exhaust nut so it makes a good seal. You don't need a breaker bar for that.
Some models also have a sleeve insert at the header/collector that rusts out and must be replaced. If you leave that out, you'll know it the minute you fire up the engine...and so will the neighbors.
Greg Hutchinson
Old 11-28-2013, 01:12 AM   #12
Screaming Chicken
Screaming Chicken's Avatar
Oddometer: 618
I just use these:
http://sternmutterersatz.de/
'92 R100GSPD
Two Bings to rule them all, Two Bings to ride them,
Two Bings to bring it all and in the twisties grind them.
In the land of Bavaria, where the boxers ride...
(Gandalf the oil-stained)
Screaming Chicken is offline   Reply With Quote
Old 11-28-2013, 01:27 AM   #13
ME 109
ME 109's Avatar
Oddometer: 3,135
So is Ozmoses.
Lord of the Bings, kangaroo farmer
ME 109 is online now   Reply With Quote
Old 11-29-2013, 07:24 PM   #14
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,278
There is a down-side of too tight, besides being hard to remove or possibly seizing. And that is - shrinking the header at the point where the sealing ring forces against the pipe.
I'm not making this up - quite a few times I've had an exhaust leak and more torque on the nut didn't fix. A close look revealed the pipe had a groove in the sealing surface which required some metal-work to remove.
I also clean the sealing rings very well on the wire wheel and coat everything in anti-seize. I never tighten the nuts any more than required to prevent leaks. So far in the 23 years I've ridden these bikes I haven't noticed any downside to this practice.
Wirespokes is online now   Reply With Quote
Old 12-01-2013, 10:54 PM   #15
Warin
Retired
Oddometer: 2,329
Too loose ... is when the nut falls off ... done it twice. No problem ... bit of wood and a rock does it up tighter. Rather have those loose than tight .. they don't go anywhere other than along the pipe.
Warin is offline   Reply With Quote
Times are GMT -7.   It's 06:38 AM.
