Old 11-27-2013, 01:22 PM   #1
rockohlic OP
rockohlic's Avatar
Oddometer: 137
ktm hard parts heated grips
just ordered from ktm and they just flash. Checked connections twice and cycled thru the switch and ignition switch many times with no luck.
There was a thread on here about just this problem but I no can find.
Ktm hard parts sent me an e-mail that said "lots of luck" Does any body have some good advice? Can I use a different switch? I hate to just piss away a hundred dollars! btw they went on 2005 950 adv.
rockohlic is offline   Reply With Quote
Old 11-27-2013, 02:22 PM   #2
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,519
Try a jumper straight to the battery to see if this is a defective grip controller, or an issues with routing the power thru your switch. Maybe the switch can't handle the current. If so, you may need to install a relay.
We don't stop riding because we get old, we get old because we stop riding.
"Wisdom is knowing what to do next, Skill is knowing how to do it, and Virtue is doing it"
HellSickle is offline   Reply With Quote
Old 11-27-2013, 03:05 PM   #3
rockohlic OP
rockohlic's Avatar
Oddometer: 137
both grips ohm out the same so I think the controller is the problem. Just want to know what other people have done with this same problem. And has anybody else had a problem with ktm not standing behind a product. I know it is electrical butI just purchased it!
Can I put a 3 position switch on it? do I need a ballast?
Old 11-27-2013, 03:23 PM   #4
Andrejs2112
ihatecars
Andrejs2112's Avatar
Oddometer: 673
Mine doing the same thing. I have not started to troubleshoot it yet. Can you buy just the controller?
2006 Buell Ulysses
2006 KTM 950 Adventure
Andrejs2112 is offline   Reply With Quote
Old 11-27-2013, 05:24 PM   #5
renogeorge
Oddometer: 1,425
Try holding the button in for about 3 seconds to get the green light on. Once you get that, push again and hold 1-2 seconds to move up to the next highest heat setting. Mine work fine once I figured this out.
FWIW
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Old 11-27-2013, 06:00 PM   #6
rockohlic OP
rockohlic's Avatar
Oddometer: 137
nah, hold for 3 sec and it goes off, hold for three more and it comes on flashing all the lights at once. Do this over and over till you sit in the corner and roll your shit into balls.
Old 11-28-2013, 07:39 PM   #7
rockohlic OP
rockohlic's Avatar
Oddometer: 137
hey andrejs2112, gonna go to radio shack and get a hi-med-low switch , I'll let ya know how it works.
word of caution: ktm hard parts people not to helpful at all so buy with caution.
Old 11-29-2013, 07:14 AM   #8
travelsomewhere
Oddometer: 158
grip
I had a pair go bad and that is what happened. try unplugging one grip and see if the other works by itself. when they all blink at once that is the system telling you something is wrong. i ended up having a the throttle side go bad. there are no repair parts and no help to be had. i just had to buy a new set. have them send you a new set. i also recommend you go to a local shop and buy an old throttle sleeve that they have laying around in the shop and cut a spall piece from it to fill the void at the end of the grip. i think that if you bend the heat fibers it can break them and there is a section at the end of the grip that is not supported. hope this helps.
travelsomewhere is offline   Reply With Quote
Old 11-29-2013, 06:03 PM   #9
rockohlic OP
rockohlic's Avatar
Oddometer: 137
Actually the grips went on with no drama at all. Glue was used and they went on easily.
Hot Grips ! only use Hot Grips, they stand behind their product.
Old 11-30-2013, 02:20 PM   #10
AB13
Oddometer: 1,091
KTM junk I ment heated grips
I thru mine in the trash and put on some Oxfords work great!
Just joined for the sticker.
AB13 is offline   Reply With Quote
Old 11-30-2013, 03:23 PM   #11
Ogre1
Oddometer: 5
I had same prob my wires were crossed. It hard to tell from instruction but the wires are wrong. It took me two hours to figure out. Once I did they work great.
Ogre1 is offline   Reply With Quote
Old 11-30-2013, 04:28 PM   #12
rockohlic OP
rockohlic's Avatar
Oddometer: 137
thanks ogre1 - just figured it out myself. I feel like ass-wipe but those instructions fail to tell you to cross the wires, although when you think about it, it only makes sense.
A little support from ktm- hardparts wooda been nice!
Old 11-30-2013, 06:16 PM   #13
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,971
80,000ks on mine and they haven't missed a beat.
Stories from the Seat Facebook My Photos Cannonball Charity Ride
Personal Attacks - the last refuge of the intellectually impaired.
Originally Posted by XR650L_Dave View Post
The only guaranteed route to failure is the attempted solution of problems through the application of ideology.
ciedema is offline   Reply With Quote
Old 12-02-2013, 02:56 AM   #14
Bowser
Oddometer: 169
Mine did that from the moment I fitted them, took the control back to the shop and they confirmed it was busted straight out the box, swaped it out for a new one and its been ok ever since.
I would suggest that you send it back for a replacement, that controler box is "shagged" (thats english speak for, broken beyond anyones ability to fix)
Bowser is offline   Reply With Quote
Old 12-06-2013, 03:10 PM   #15
Ogre1
Oddometer: 5
"bora" Glad I could help
Times are GMT -7.   It's 03:03 AM.
