Old 11-27-2013, 02:09 PM   #1
Captain Yesterday OP
Captain Yesterday's Avatar
Oddometer: 152
/5 starter relay
Looks like my starter relay took a dump, looking to replace it with a bosch generic relay 12v 20amp
Based on this site http://bmwmotorcycletech.info/slash5cricket.htm
Not sure on the re wire the numbers on the replacement relay are different from the web article, I have 85, 86, 87, 87a, 87, 30?
Anybody have any experience doing one of these swaps?
Captain Yesterday is offline   Reply With Quote
Old 11-27-2013, 04:52 PM   #2
DiabloADV
Semi-Occasional
Oddometer: 2,321
A generic will not have the circuit that keeps you from hitting the starter while the motor is running. It's explained in that snowbum article you linked.
1974 R90/6 motor w/1050 kit; twin plugged; installed in...1970 R60/5 frame; RM125 front end; KZ1000 Police Tank.
DiabloADV is offline   Reply With Quote
Old 11-27-2013, 05:02 PM   #3
elite-less
As above, so below
elite-less's Avatar
Oddometer: 548
I run this Bosch relay (0 332 019 150) on all my /5's. They're so cheap, and small, I install two for a belts and suspenders approach.
Untitled
It will bypass the starter protection... as mentioned by DiabloADV.
If your harness is stock… wiring should be as such:
85 - Brown
86 - Green
87 - Double Red
87 - Red
30 - Black
You'll also need to add a jumper wire to connect the blue connectors.
Slash 5 Revive
elite-less screwed with this post 12-12-2013 at 11:50 AM
elite-less is offline   Reply With Quote
Old 11-27-2013, 05:29 PM   #4
Oddometer: 152
Sweet it works, Thanks
125$ for a relay is about as crazy as 500$ for 70's ducati turn signals
Also, I'm not running turn signals, so there should be less of a chance of hitting the starter when the engine is running.
Old 11-28-2013, 11:21 AM   #5
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,829
Motorrad Elektrik carries a good relay for $10.
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is offline   Reply With Quote
Old 11-28-2013, 03:34 PM   #6
blaine.hale
blaine.hale's Avatar
Oddometer: 3,171
What symptoms does "dump" entail? Is it just clicking the starter like crazy?
Might be able to fix it with this super cheap mod:
http://www.advrider.com/forums/showthread.php?t=935824
1974 BMW R90 /6
1968 Bultaco Matador MK3
1973 BMW R75 /5 Toaster LWB
1969 Bultaco Bandido MK2
2013 Husqvarna Terra TR650
blaine.hale is offline   Reply With Quote
Old 11-30-2013, 02:48 PM   #7
khale
ride dirty
khale's Avatar
Oddometer: 557
OP - just be careful with these bosch starter relays. As many have said, it bypasses the circuit that prevents the starter from being activated when the bike is running - that was by design by Bosch and implemented by ze Germans for good reason. If you are 100% certain you would never push the starter button while the bike is running, even on accident (which I find unlikely), you are better off doing the mod snowbum suggests (my brother and I did it, works great), or putting in a used starter relay from the flea market.
2013 BMW R1200 GSW | 1972 BMW R75/5 toaster | 2011 Husky TE310
"4 wheels move the body, 2 wheels move the soul"
khale is offline   Reply With Quote
Old 11-30-2013, 10:56 PM   #8
DiabloADV
Semi-Occasional
Oddometer: 2,321
Originally Posted by elite-less View Post
You'll also need to add a jumper wire to connect the blue (turn signal) connectors.
Those blue wires at the starter relay are the charging light and diode board circuit, not turn signals. That's how the relay "knows" the motor is running.
You definitely need to jumper those or the bike won't charge. A jumper is built into the /6 relay to do just that.
Old 12-01-2013, 10:55 AM   #9
Michel77
Oddometer: 193
+1 at the above, mine were disconnected at the relay and it didn't charge. It seems there is some confusion on the purpose of these wires as I was initially also informed that they were turn signal wires.
'06 KTM 640 ADV'
Michel77 is offline   Reply With Quote
Old 12-01-2013, 11:50 AM   #10
Big Bamboo
Aircooled & Sunbaked
Big Bamboo's Avatar
Oddometer: 3,776
Sorry about that, I was referencing the info posted above.
Big Bamboo is offline   Reply With Quote
Old 12-01-2013, 04:06 PM   #11
elite-less
As above, so below
elite-less's Avatar
Oddometer: 548
Great catch! That'll learn me from leaning on me memory!
Slash 5 Revive
Old 12-01-2013, 06:00 PM   #12
Michel77
Oddometer: 193
Hey, no worries man, thanks for chiming in when I posted.
'06 KTM 640 ADV'
Times are GMT -7.   It's 02:07 AM.
