Old 11-27-2013, 04:08 PM   #1
pecos OP
BAM!!
pecos's Avatar
Oddometer: 535
77 r100 horn relay unavailable
I tried ordering a horn relay part# 61 31 1 373 585 from the dealer today and they said bmw is "blocking" the order or something like that. I will find out more on Monday/Tuesday they said.
Its a bosche relay 0332014406 12v 30a.
Where else can I buy a new one. Maybe autozone or napa?
pecos is offline   Reply With Quote
Old 11-27-2013, 04:13 PM   #2
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,533
You can use any automotive 12v 30amp relay. There are spare slots in the relay base that can be shuffled around to suit or ditch the base and plug straight on the terminals. Around $3 each.
Rob Farmer is offline   Reply With Quote
Old 11-27-2013, 04:40 PM   #3
pecos OP
BAM!!
pecos's Avatar
Oddometer: 535
Rob, I understand what you are saying. I will try that.
Old 11-27-2013, 05:47 PM   #4
r60man
r60man's Avatar
Oddometer: 434
I needed a new relay when I went to dual Fiamms on my R75. Fiamm has a relay that works perfectly as well.
K1100RS, R75/6
Speed doesn't kill anyone, suddenly becoming stationary, that's what gets you - Jeremy Clarkson
r60man is offline   Reply With Quote
Old 11-27-2013, 07:57 PM   #5
pecos OP
BAM!!
pecos's Avatar
Oddometer: 535
Yes, I am running dual fiamms.
I went to autozone and struck out. I don't think the guy understood what I was trying to accomplish.
I then went to O'Reilys and they had a relay for $8. After reviewing it, I noticed that the pin layout was the same....however two of the numbers were switched. 30 and 86 I think.
I switched the 30 and 86 wires under the relay mount. Shaved off a plastic tab on the new relay, installed....and bam...it worked. Nice, loud horn.
Thanks for the help Rob.
Times are GMT -7.   It's 10:03 PM.
