Old 11-28-2013, 05:52 AM   #1
lancas OP
Oddometer: 42
Compression bump up ????????????????
I'd like to bump up the CR on my R100 and am wondering what might be a safe amount to have shaved off the heads without having to do the calculations. These heads have never been machined before by the way.
lancas is offline   Reply With Quote
Old 11-28-2013, 06:17 AM   #2
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 10,004
What year and model R100. There were different pistons and compression ratios thru the years?
May also include some note about what result you'd like, are you going with any other "bigger" parts like cams or carbs and any budget ideas?
---Albert Einstein
Old 11-28-2013, 08:00 AM   #3
R100LT
Chasing 11
R100LT's Avatar
Oddometer: 631
I am very interested in this discussion . I have a set on nice 1980 R100 heads that have been rebuilt and dual plugged and wanting to put them on 91 mono . I have a set of Omega ( MS) pistons ... Just not sure if they fit
BMW R100LT 93 BMW R100RS 91 BMW K1100LT SE 94 76 R90S
R100LT is offline   Reply With Quote
Old 11-28-2013, 09:52 AM   #4
supershaft
because I can
Oddometer: 9,116
It all depends on what model you have and/or what pistons you have in your bike. Personally, I am very conservative about CR. I grew up in and around a BMW dealership in the '70's. I started working there as soon as I quit my paper route. I have heard a LOT of complaints about airheads pinging. I have seen tons of airheads that came stock with 9.0:1 CR get their CR lowered with thicker base gaskets for pinging. I had to detune my own R69S for pinging. My LS with 8.2:1 CR didn't ping. My '92 R100 with 8.5:1 CR didn't ping on regular until ambient got around 80F. Then it needed premium to not ping and that is WITH a 336 cam that lowers effective CR for a later closing intake valve. That is cutting it pretty close IMO. I think 8.5:1 is about perfect for single plugged airheads. Personally, I would not raise my CR above 9.0:1 without first dual plugging it and re-mapping the ignition curve.
Old 11-28-2013, 11:58 AM   #5
Voltaire
Bored Of The Rings
Voltaire's Avatar
Oddometer: 1,687
Does fuel vary from country to country as I run all my bikes on 95 including the race bike and a Ducati ST4 and no issues with pinging ever.
Even my race bike with 1mm off the heads runs on pump gas.
Voltaire is offline   Reply With Quote
Old 11-28-2013, 12:03 PM   #6
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,580
Yep. Octane ratings differ. RON, MON, or AKI are used to calculate the octane rating depending on the country, so numbers from one country aren't necessarily directly comparable to numbers from another country.
http://en.wikipedia.org/wiki/Octane_rating
Our premium in the US which is typically 93 by the AKI method is roughly equivalent to 97 by the RON method which (I believe) is what you kiwis use.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Airhead Wrangler screwed with this post 11-28-2013 at 12:12 PM
Old 11-28-2013, 02:22 PM   #7
lancas OP
Oddometer: 42
Standard cam, 44mm in, 42 mm ex, twin plugged, currently standard pistons but would like it to be flexible enough so a Siebenrock upgrade could be fitted at some stage. I agree with the idea of being conservative which is why I only want a modest increase. I could also be swayed to stay with standard CR.
Old 11-29-2013, 09:54 AM   #8
supershaft
because I can
Oddometer: 9,116
So does specific gravity and boiling point.
Old 11-29-2013, 09:58 AM   #9
supershaft
because I can
Oddometer: 9,116
Siebenrock upgrade with 9.5:1 pistons?
Old 11-29-2013, 01:42 PM   #10
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,994
YOu can only go far with head gaskets and whatnot, right? custom pistons are the answer, after that?
HEy SHaft, i do have the 9.5's, and I run 87 octane through them on single plugs, no problem.
My R60/6, CRwhoknows pings like crazy, unless its getting the pretty wine.
Unintentional psychokinesis.
Stagehand is online now   Reply With Quote
Old 11-29-2013, 02:02 PM   #11
supershaft
because I can
Oddometer: 9,116
I have heard your story many times Sh but I have heard my story many times over that. I think I have a pretty good sample of such things growing up around and in a BMW dealership and working at a few more after that. Plus I have my own personal experience. Some people say they never hear their airheads pinging. Some people say R1200's don't ping because they have anti-knock sensors. I reqlly wish I could say that and so do a LOT of other people!
You don't hear your airhead ping? Some of it depends on how you use the throttle. Some of it depends on your hearing. I think a lot of it depends on SO many people timing their airheads retarded from spec for looking down at the timing marks versus lining them up correctly.
Old 11-29-2013, 02:18 PM   #12
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,994
HMm. OK, I will keep checking. THere's always a lot going on, and my hearing aint the best.. and honestly the old girl aint running right, offhand
I do trust your opinion, so my own experience is always interesting to compare.
Old 11-30-2013, 12:14 PM   #13
supershaft
because I can
Oddometer: 9,116
Thanks Sh!
Since I got my bike running a LOT stronger with a major CR bump and port job you can really notice a power drop for pinging versus pinging going on with less power to start with. I hope that makes sense?
Old 12-02-2013, 05:21 PM   #14
lancas OP
Oddometer: 42
9.5:1 pistons
That would be the ultimate set up but it may be a year or 2 before that happens. In the mean time my aim is to avoid any pinking on 97 / 98 RON fuels and improve the combustion process and performance. No plans for anything radical in the ports at this stage but if you have any photo's of your porting work that would be great to see.
Old 12-02-2013, 09:11 PM   #15
supershaft
because I can
Oddometer: 9,116
We still need to know year and model and hopefully what pistons are in it now?
Pictures? I did buy a camera a few years back at nearly 50 years old. It's the first one I have ever owned but I still don't take many pictures. Especially while I am working! I learned my general port mods while doing valve jobs on airhead race bikes with heads flowed by Branch flowmetrics, Kenny Agastini (SP), and the like. They all did pretty much the same thing to them. Pretty much right out of a Smokey Yunick book only a little different.
Times are GMT -7.   It's 11:08 PM.
