Old 11-29-2013, 06:32 AM   #1
john_aero OP
john_aero's Avatar
Oddometer: 1,173
Ktm Engine Oil Quantity
Ok,
My Manual is saying 3l after oil and filter change
3l in and not registering on dipstick
i know from talking on uk forum that one menber had put 3.8l in after good oil drain and had coveres etc ff meaning all oil was removed.
So i had bike dripping oil for least 1 day and had both side covers off for few days so engine was well and truly dained
women are like clouds.......
once they fuck off it is a really nice day.......
john_aero is offline   Reply With Quote
Old 11-29-2013, 06:59 AM   #2
travelsomewhere
Oddometer: 156
oil
Just make sure that you check the oil level after you run the bike. when the oil settles cold it will all drop to the lower tank so the sump has to pull it back up to the upper tank when running to get a proper reading.
travelsomewhere is offline   Reply With Quote
Old 11-29-2013, 07:21 AM   #3
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,856
Read the manual,everything it has to say about oil changes.
Yours is just the same as all other KTM's of that model.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 11-29-2013, 07:44 AM   #4
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,322
http://www.ktm950.info/
Chuckracer is online now   Reply With Quote
Old 11-29-2013, 07:49 AM   #5
DELTATANGO
Motorcyclist and Dog Walk
DELTATANGO's Avatar
Oddometer: 13,866
I hate checking the oil in a dry sump motor.
The technique seems so inaccurate.
DELTATANGO is offline   Reply With Quote
Old 11-29-2013, 08:27 AM   #6
Mowster
Stressed Member
Mowster's Avatar
Oddometer: 462
My suggestions for dry-sump motors:
After putting in the recommended quantity - go for longer than a 'leak-check' ride.
They seem to require more/longer operation, before the indication becomes correct.
(if you overfill, dont tell anyone )
"No, it's not, it's all about you and your content-free word slurry. "
Mowster is offline   Reply With Quote
Old 11-29-2013, 09:06 AM   #7
john_aero OP
john_aero's Avatar
Oddometer: 1,173
currently has bang on 3l and did standard ktm oil check but still nto showing u
now i know its similar to the bmw rotax engine and i worked on idea that once all old oil out, correct quantity in and not leaking then leave it and ride bike
Old 11-29-2013, 11:24 AM   #8
dgardel
Orange contaminated
dgardel's Avatar
Oddometer: 67
http://sdrv.ms/1aelQS4
Daniele (Italy)
KTM 1190 Adventure S Gray
dgardel is offline   Reply With Quote
Old 11-29-2013, 11:50 AM   #9
john_aero OP
john_aero's Avatar
Oddometer: 1,173
Cheers for link but its 950 not 1190
Old 11-29-2013, 12:03 PM   #10
KaytM
Just a fella.
KaytM's Avatar
Oddometer: 202
Agreed. Too many variables.
2006.5 990 ADVENTURE.
KaytM is offline   Reply With Quote
Old 11-29-2013, 12:05 PM   #11
JK1
JK1's Avatar
Oddometer: 116
Mine takes more than 3L from an oil change, I like mine to read on the half way mark on the stick. If you have put 3L in and ran it for a while and it don't show add some more until it does. Make sure your run it for a bit, then wait a bit to get the reading.
Current KTM 950 Adventure S 03
Old Suzuki TS50, Aprilia Chesterfield RS125 , Honda NC30, Cagiva Elefant 750
JK1 is offline   Reply With Quote
Old 11-29-2013, 12:08 PM   #12
dgardel
Orange contaminated
dgardel's Avatar
Oddometer: 67
Daniele (Italy)
Old 11-29-2013, 12:32 PM   #13
john_aero OP
john_aero's Avatar
Oddometer: 1,173
Ill go for short ride over weekend and give it check
Cheers
Old 11-29-2013, 01:23 PM   #14
Masa
Masa's Avatar
Oddometer: 300
It's not rocket science, just have oil in it, and it will run.
Masa is offline   Reply With Quote
Old 11-29-2013, 05:31 PM   #15
Dan950ser
NW Shredder
Oddometer: 472
Put in 3L warm up and go ride it for 15 minutes. Then come back and put it on the center stand and fill till it's at the appropriate level. Mine usually takes 3.6L when I do filters and all.
2015 KTM 690 Enduro R, 2007 KTM 990 SuperDuperEnduroR For Sale http://www.advrider.com/forums/showthread.php?t=1046431, 2014 KTM 250 XC-W
Dan950ser is offline   Reply With Quote
Times are GMT -7.   It's 05:35 PM.
