Old 11-30-2013, 01:06 AM   #16
john_aero OP
john_aero's Avatar
Oddometer: 1,174
seems like same as old rotax, bit of pain.
will take for longer run maybe hadnt it up fully temp
women are like clouds.......
once they fuck off it is a really nice day.......
john_aero is offline   Reply With Quote
Old 11-30-2013, 11:20 AM   #17
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,178
I always put 3,2lt with a filter swap.
More than that results in oily airbox.
Cheers.
Old 12-24-2013, 07:14 AM   #18
john_aero OP
john_aero's Avatar
Oddometer: 1,174
meant get back on this
3l then 20min ride, 1min idle on centre stand and it took 0.5l extra and its not between 1/2 and 3/4 up the dipstick so am happy with it
Old 12-25-2013, 07:11 AM   #19
HarryEye
Oddometer: 37
From the manual, pretty sure...
I'm new here, but the manual says to keep the bike level to check the oil (the bike is not level on the center stand), and to screw the dip-stick all the way in to check the level (and, of course to run it till the temp. reads at least 4 bars).
So that might be the problem?
HarryEye is offline   Reply With Quote
Old 12-25-2013, 08:35 AM   #20
john_aero OP
john_aero's Avatar
Oddometer: 1,174
Well maybe off stand and held up level may be oart the reason so will re check off stand and held level by someone
If over full will rak 200ml out
Ah was curious thats all see if others had similar issues with oul not shoeing up after bike warmed up on stand but not driven
Read ok after driven
Old 12-25-2013, 09:06 AM   #21
Tancakar
Tancakar's Avatar
Oddometer: 370
Ktm got nearly 20 models of bikes , which one you are talking about ? Why do you people got common sense , I don't need to know your bloody bikes model. Just let us know so we can write what we thinking. This is like a guessing game .
Tancakar is offline   Reply With Quote
Old 12-25-2013, 09:08 AM   #22
Dan Diego
Oddometer: 1,090
Question
Originally Posted by HarryEye View Post
I'm new here, but the manual says to keep the bike level to check the oil (the bike is not level on the center stand)?
The bike appears level on the center stand. Not on the side stand, for sure, but it looks level on the CS, no?
I have no interest in living a balanced life. I want a life of adventure.
Dan Diego is offline   Reply With Quote
Old 12-25-2013, 09:21 AM   #23
HarryEye
Oddometer: 37
Well, with my 990 on the center stand, the back tire is about 5 or 6 inches off the ground (and keep in mind that's with the rear shock fully extended, and the front end mildly compresed). I have no idea if it makes any difference. I just said that because somebody mentioned "on the center stand". Obviously, it's level side-to-side.
It's too bloody cold here to go out to the shed and check it.
Old 12-25-2013, 11:39 AM   #24
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,178
Try to go with the flow... no need to get frustrated...
We seem to get along with each other. Try to get along... you don't need to write anything if you feel you do not understand which model they are talking about.
Cheers.
Old 12-25-2013, 11:56 AM   #25
Tancakar
Tancakar's Avatar
Oddometer: 370
Cheers.
Yes but the forums supposed to help plopped and let everyone to understand . May be I don't have the capacity you have ? Why is so difficult to write that which bikes you are talking about . This is bullshit
Old 12-25-2013, 02:49 PM   #26
charlie264
charlie264's Avatar
Oddometer: 8,543
Dry sump engine, add approximate amount of oil. Run till full operating temperature, ie 20 min ride. Switch engine off, check level, add oil to lower mark. Run to temp and recheck.
If you put too much oil in, syringe or turkey baster..
Done.
charlie264 screwed with this post 12-25-2013 at 02:55 PM
Old 12-25-2013, 03:44 PM   #27
brents347
Trusting my Cape...
brents347's Avatar
Oddometer: 3,927
I haven't seen you post one of these in at least a week!
Jeez, and I thought maybe you were over it...
07 Yamaha R6
07 KTM 950 Super Enduro
04 KTM 250exc- plated two-stroke
01 Kawasaki KE100
74 Honda MR50
brents347 is online now   Reply With Quote
Old 12-26-2013, 02:45 AM   #28
john_aero OP
john_aero's Avatar
Oddometer: 1,174
well now bike fine only posted follow up post let others know
thanks for help and will check oil on both center stand and off stand balanced upright just too see if huge diff
i wonder is there bigger diff on the r/s adv models compared standard height bikes
yes i forgot add bike but as i posted this along with another 950 adv question most new bike.
someone must have got lump coal in this years stocking did they
and here was me hoping there be less grumpiness on ktm section compared all years a spent helping others on thumpers, beasts and bmw sectiom
anyway more riding less moaning time wear the rear tyre out
Old 12-26-2013, 07:29 AM   #29
geometrician
let's keep going...
geometrician's Avatar
Oddometer: 1,034
The difference in angle between both wheels on the ground & on the centerstand isn't that much, esp relating to oil level on the dipstick.
Set your oil level (per the manual) and note where the oil level appears on the disptick when not fully threaded in to the tank- it's only going to be the 12mm or so (length of the threads) different. Once you know your bike & can quickly check it to make sure you aren't losing/using any it's easy to keep up. No helpers required, no time spent turning the dipstick.
FWIW I always check the level right when I get home after a ride. You can check before you ride next time to see how much oil leaks past the check valve in the tank; in the "bad old days" dry sump engines could fill the crankcase creating hydraulic lock and it can happen to us, if to a usually lessor degree.
The 950/990(Adv/S/R) barely gets the rear off the ground (with stock 21"/18" wheels)... pictures?
Originally Posted by Masa View Post
It's not rocket science, just have oil in it, and it will run.
Agreed. Just don't run it empty or overfill it; it doesn't take much to keep these engines running. Most of the oil capacity of these engines is to allow air in the oil to escape & to cool the oil.
Britt
'06 KTM 950 Adv 'S'
'03 KTM 250 EXC
'87 KLR650 - <200K miles "Like the Energizer Bunny, just keeps going & going..."
geometrician is offline   Reply With Quote
Old 12-26-2013, 07:35 AM   #30
pfdskipper
Westside Trash
pfdskipper's Avatar
Oddometer: 1,121
http://youtu.be/NSqXdg7ZDLc
pfdskipper is offline   Reply With Quote
Times are GMT -7.   It's 05:37 PM.
