Old 12-01-2013, 08:47 PM   #1
kelds OP
mostly right-side-up
kelds's Avatar
Oddometer: 124
990 Mods for Offroad
I've been riding my new-to-me 2010 990 Adv for around 4 months now and, other than adding a pair of heated grips, have been running it as I bought it. I figure it's time to add some protection before I break the stock skidplate and cause some expensive damage.
I'd also like to have a plan for the rest of the changes, and I know others out there have already figured out what works well offroad.
Please chime in if you have any suggestions for setting a 990 up right for reasonably hard offroad riding.
March 30, 2014 update. I've made it down the list of mods a bit, have found a few more weaknesses.
Diet
Remove one front caliper/rotor (possibly replace stock cylinder with SE version) In the mail, including the se cylinder....looking forward to seeing how this changes the feel of the suspension
2-1 exhaust (cj + fmf)
Lithium ion battery (not sold on this item at the moment)
Canisterectomy (tunecu + cover plates etc.) Done
Lose the crash bars - plus rburkat noticed that his had started to kink the frame eventually (find carbon guards if vanity demands) Done....too many scratches already to worry about vanity, lol
Armour/Protection
Skidplate (Motoventure - checking to see if they provide a rubber spacer) Installed and no complaints. Haven't decided about the centre mounts, may cut them off this week before the Desert 100
Rear brake master cylinder guard (Blackdog)
Handguards (still like Barkbusters)
Side stand relocation + switch bypass Done...no complaints
Steering
Steering damper- (mostly sold on Rallemoto RM1, have some questions into them) This will be the next thing I get after my front wheel is sorted. I'm going to get the Rallemoto RM-2 as it has more adjustments and will work with my risers.
Suspension
Go see Konflict or Riders Edge.Had it done by Konflict. New heavier spring in the front and re-valve. Tried it out in Squamish last weekend and it felt good in the rocks, big improvement. Will see how it feels with more speed next weekend
Lighting
Look at the Brittania Composites fairing with the projector HID's when it comes out. I've seen the prototype up close on Lica's bike and it looks great..I'm completely sold on this solution.
Gear Ratio
Go from the 990R stock 16/42 to 16/45 when replacing chain and sprockets in the spring. Buy a 17 for highway trips. Look at dirttricks. Done...used the stock sprockets and a heavy DID chain. It turns out the last owner was running 17/42, so 16/45 is a massive improvement offroad
Range
ADVRALLYTANK - Plastic aux. tank Bought the tank on flea market, waiting till some more pressing mods are done
[/B]Misc[/B]
Better mirrors, doubletake or similar. Done
SE swingarm chainguide.
More aux lighting, depending on base set-up.
Air bleeders for forks (have shock sox). Done
Better footpegs. Done...went with SW Motech. I really like the lower position compared to stock (maybe 3/4"lower. They're cast aluminum and I found that the outside edge is a bit slippery, so might square of the outside row of teeth a bit
Cooling fan sensor + 2nd stock fan (summer upgrade)
Improve if Broken
Rims Argh....discussed below
Handlebars (or if starting to get sore wrists - my heated grip is jb'd to it, so not happening right away!!)
High fender......ya, it'll have to go eventually, or risk being torn off. Keeping the nice white one for a while, though. In the mail with my single disk parts
I've broken the turn signals a couple of times now and will be looking for something more durable to replace them, too.
kelds screwed with this post 03-30-2014 at 09:13 AM Reason: Updated!
kelds is offline   Reply With Quote
Old 12-01-2013, 09:01 PM   #2
munstro
Oddometer: 25
One word. Knobbies.
munstro is offline   Reply With Quote
Old 12-01-2013, 09:03 PM   #3
kelds OP
kelds's Avatar
Oddometer: 124
Originally Posted by munstro View Post
One word. Knobbies.
Running Michelin Desert front and TKC80 rear.
Old 12-01-2013, 10:13 PM   #4
AJ990R
motorcycle guy
AJ990R's Avatar
Oddometer: 227
welcome
-I would go down one tooth on the front sprocket(16/42?), still can cruise hwy speeds & better for the tight off-road stuff. Wish I would have done it sooner. I know the Mounties don't mess around up there I'm running a 17/45 set-up, fun wheelies with the shortest wheel base...but I do like to hold 85mph on those big trips too & only feel comfy @ 75mph with my set-up now
-installed a SE swingarm chain guide(helps went its loose to not hit your rear shock, free lil upgrade)
-replace your cooling fan switch with the lower activated one, been working well for me vs needing a second fan
-neoprene "shock sox" covers with air bleeders(never deal with blown fork seals)
-larger pegs help on single track stuff
+1 on no crash bars(i've never owned a bike thats hit the ground so much & still looks good)
CJ is the man to talk too
CHEERS
"saddle up or shut up"
KaTooM North
AJ990R screwed with this post 12-01-2013 at 10:50 PM
AJ990R is offline   Reply With Quote
Old 12-01-2013, 11:59 PM   #5
Bowser
Oddometer: 168
You also NEED Touratech stickers otherwise it wont handle off road, and you will some kind of "Racing" sticker as that "adds" BHP at least 10 possibly 15
More importanly if you ride like me, +1 for Proper handguards for when you fall off, and different mirrors that dont bolt to the clutch and brake, and move when they hit the ground/tree/sombody else etc. I have HDB guards and mirrors, but there are loads of other good makes. I personaly also like the mirrors that fit the ram mount ball but cant remember the name for the moment.
Bowser is offline   Reply With Quote
Old 12-02-2013, 12:50 AM   #6
kave
Gravel rules
kave's Avatar
Oddometer: 529
I would get proper rims first so you can run proper tires.
The standard rim/tire setup is way too wide for any serious riding.
The fact that the rims are made of butter doesn't make it better either :)
KTM 1190R 2015:
Previous bikes: KTM 690 Enduro, KTM 950SE 2006, BMW R1200GS 2004
kave is online now   Reply With Quote
Old 12-02-2013, 01:16 AM   #7
Qwik
Adrenaline Addict
Oddometer: 6,855
And PLEASE do the side stand relocation bracket before you crack your cases.
Topes never seem to make me go any faster.
Qwik is offline   Reply With Quote
Old 12-02-2013, 02:29 AM   #8
rburkat
rburkat's Avatar
Oddometer: 293
Here is my list from most important to least.
Must
1. Disable the kickstand switch before it kills you. Most don't realize that they hit it down with their heel, or that the kick stand swings down when you hit g outs or hard bumps. The kick stand moving down slightly makes the bike cough or stall and lose power. This can cause you to crash badly. You just have to remember not to ride away with your kick stand down from now on.
2. Skid plate. I think the blackdog one is good primarily because it has a big rubber block between the skid plate and the engine in addition to being solid. If you take a hard enough impact you can't have empty space between the plate and engine.
3. suspension. get it setup for yourself. you might as well do this early as it will let you enjoy the bike better, ride faster and safer. Alex at Konflict Suspension did mine
4. Get rid of stock exhaust. It's heavy and almost any other will make it breath better. You will probably want the advtank later so might as well get the 2:1. I would go for the fmf because it has a solid welded mounting tab, unlike many others that have some strap that then mounts to the bike. I have broken those straps more than i can count.
5. Handle bar with a lot less sweep. The stock one puts your hands in an unnatural position and if you're doing hard off road and standing lots it takes a toll on the wrist.
Nice to have
5. advtank. almost more 50% fuel which is needed on the 990 if you like to explore
6. gearing. you have the 990r so you are already running 16:42 stock, which is better than the A with is 17:42. You can go 16:45 as it's a good sweet spot and if you optimize for dirt might as well have the fun there. It's fine on the hwy unless you want to be cruising at 90mph for 100s of miles. If you "really" need the taller gearing, you can easily just put in a 17 front and you'll be basically where you started. dirttricks sprockets seem to last the longest for me.
7. scotts stabilizer. I believe one feature of the scotts unlike others is that the return is not dampened. That is if you get your steering bumped sideways you can turn/return without fighting the dampening. I have another brand on my other bike and it does not do this and I like it less.
8. wheels. A 1.6 or 1.85 front is a nice upgrade. Stronger and still fits all tires for the bike. I got talked into getting smaller 2.5 rear wheels but I realized that they round out the tires too much and you get a lot less contact area on the ground. It's particularly noticeable when climbing loose stuff at slow speed.
I still run my stock rear, but it does square a 140 tire a lot. I think an idea compromise would be a 3.5 rear.
9. lights/screen - wait till the britannia composites light/screen comes out early int he new year.
Other
kickstand relocator.
ditch the canister and disable the error with tunecu. really easy
go with one disk in the front. you keep the left calliper and you just buy a new brake line at a moto shop with proper banjo bolts. ( harley shops seem to have them ) You could use your stock master cylinder but it will feel really stiff. To get the right feel you want to buy the 950SE master cylinder.
high fender. sooner of later you're going to rip it off so might, with a chance of screwing you your brake line in the process or crashing. might as well get it over with.
lithium battery. nice to save some weight but more prone to issues in the cold or if you discharge it fully. I had the shorai for a year and it was fine until it died.
double take mirrors work well. not as large and stable as the stock, but you wont have to worry about screwing up something in a crash or having to pull out tools to adjust the mirror when it loosens
rburkat screwed with this post 12-03-2013 at 09:26 AM
rburkat is offline   Reply With Quote
Old 12-02-2013, 07:38 AM   #9
kelds OP
kelds's Avatar
Oddometer: 124
Thanks for the great responses Radek, AJ990R and others. Hopefully other 990 owners benefit from having all this in one spot, too.
Rebecca
Old 12-02-2013, 07:53 AM   #10
kelds OP
kelds's Avatar
Oddometer: 124
That was exactly my concern with getting the wrong damper. Anybody know if the Rallemoto dampers can be set up this way?
Old 12-02-2013, 08:53 AM   #11
Off Road Ryder
Off Road Ryder's Avatar
Oddometer: 2,661
I heard you cant ride a 990 off road.
Do a skid plate and ride the thing, youll figure out what works for you. Thing is, for the most part you really don't know whos on the other side of the keyboard or their "idea" of Off road.
here's mine.
When Quality matters,Its all about choices.
Cyclops Performance LED Vendors thread
http://advrider.com/forums/showthread.php?t=839163
www.cyclopsadventuresports.com
1-800-624-0278
Off Road Ryder screwed with this post 12-02-2013 at 10:35 AM
Off Road Ryder is offline   Reply With Quote
Old 12-02-2013, 10:03 AM   #12
crazybrit
crazybrit's Avatar
Oddometer: 8,554
Originally Posted by kelds View Post
Handguards (had Barkbusters before and they seemed ok, suggestions?)
I always end up buying used dirt bikes with Cycra's pre-installed and they always work "well enough" that I'm not tempted to ditch them and start over. The 950 was the first bike I'd bought new ones for and I went for the Highway Dirt Bikes setup. Paul is a member here.
I was considering a european headlight with twin 55w HID's, as I had on my KLR. I understand that there may be a version in the works that addresses both lighting and the windscreen issue, where the windscreen can be adjusted in height for both offroad and highway and lighting is by a pair of HID projectors. I think I'll wait for awhile and see if that makes it to market.
Any pictures of this? I couldn't find anything searching and don't see it on their website. Seems there are lots of competing designs all of a sudden.
crazybrit is offline   Reply With Quote
Old 12-02-2013, 10:30 AM   #13
rburkat
rburkat's Avatar
Oddometer: 293
This is still in proto stages, but the guys putting it together have more info here. I took all my lights there ( 8" hid, diablo, BD squagons, onyx, rigid, cyclops ) and we had a shoot out agains hellas and some others to try to find what will work/fit in the best. This might have the option to bolt on an led option as one of the lights...like a squadron)
http://www.advrider.com/forums/showp...3&postcount=30
rburkat screwed with this post 12-02-2013 at 10:54 AM
Old 12-02-2013, 10:41 AM   #14
crazybrit
crazybrit's Avatar
Oddometer: 8,554
Thanks, I'd not seen that. Interesting. I just bought a pair of Hella 90mm and was going to make my own screen copying what SheepShagger did. I'm vain and like the one piece laminated look
Seems like lots of interesting rally headlight options popping up all of a sudden to challenge the $touratech$ one. I'm one of those not bothered by the stock screen but for those who hate it, I think the adjustable height feature will be a big seller!
Range
I'm a bit of a downer on the AdvTank. Always seemed like a product that needed more R&D (especially for the bracket) before it was released. The jig that is used to weld up their 2:1 badly needs to be redone also as fitment is annoyingly poor. This said, when you run out of gas and have to push, such things will likely become far less annoying
Old 12-02-2013, 12:13 PM   #15
rburkat
rburkat's Avatar
Oddometer: 293
I hear ya. The tank plate can bend and start rubbing on the swingarm when compressed, but a nice quick fix seems to be to put some kind of a brace between the passenger foot peg area and the tank plate.
Ex.
Some just put a straight bolt through both and secure it with nuts, or even some zip ties between those points prevent the rubbing and ad rigidity.
Times are GMT -7.   It's 04:09 AM.
