Old 12-04-2013, 06:07 PM   #46
mookymoo
Mookish Mook
Oddometer: 4,396
Originally Posted by crazybrit View Post
Slight tangent, are there any more pics of the holed case with the TT plate still installed and/or the offending rock I'm mentally pivoting the skidplate up (via the picture you posted above) and not seeing how the case got holed. There are a couple of different pics on licascurtu's winter rebuild thread but those aren't clueing me in either. I see mention that the TT plate was "too soft".
+1 I havent read what actually happened - or how the case got hit - or by what?
BTW, I banged my blackdog plate - not that hard I thought - and it deformed so much that the lip bit into the stator cover. When I tried to straighten it, I got a big sledge hammer and a 4x4 block of wood to use as a punch. I was mentally prepared for quite a bit of hammering to straighten it out. And bugger me ... one hit and it was straight.
I've generally been of the opinion that the TT - with the steel subframe + Alu plate was going to be stronger. Thats what Ive got now. I sold the BD.
mookymoo is offline   Reply With Quote
Old 12-04-2013, 06:16 PM   #47
mookymoo
Mookish Mook
Oddometer: 4,396
Originally Posted by rburkat View Post
1. Disable the kickstand switch before it kills you. Most don't realize that they hit it down with their heel, or that the kick stand swings down when you hit g outs or hard bumps. The kick stand moving down slightly makes the bike cough or stall and lose power. This can cause you to crash badly. You just have to remember not to ride away with your kick stand down from now on.
FWIW the SE has a little rubber loop to keep the kickstand up - which I managed to fit to my adv....
Old 12-07-2013, 04:01 AM   #48
charlie264
charlie264's Avatar
Oddometer: 8,371
It does the trick on the SE, even though the side stand switch pee's me off...It is a good safety feature for the occasional absent minded like me.
Old 12-07-2013, 09:00 AM   #49
satrider
Oddometer: 69
rburkat mentioned "disabling the kickstand switch" in his first post above. How is this done, and if done incorrectly will it screw up anything else?
satrider is offline   Reply With Quote
Old 12-07-2013, 09:17 AM   #50
kelds OP
mostly right-side-up
kelds's Avatar
Oddometer: 128
If I'm not mistaken, the 990 needs a little module that you plug into the wiring harness where the sidestand switch would've.
Mine is on order from CJ with my sidestand relocator, which is currently back-ordered. They're probably available elsewhere too.
Not sure if the 950 is the same.
kelds is offline   Reply With Quote
Old 12-07-2013, 09:23 AM   #51
kelds OP
kelds's Avatar
Oddometer: 128
Charlie264 - I didn't know that there was another option for a sidestand locator beyond Blackdog & CJ or I would've taken a closer look at yours.
Old 12-07-2013, 09:41 AM   #52
Apple Jam
Forest Flyer
Apple Jam's Avatar
Oddometer: 6,637
When I had the HOLE in my motor, we had to remove the kickstand for obvious reasons. In the morning, when the JB Weld had properly set, I tried to start it up.........Oh crap, forgot about the stupid SS sensor. 3 wires on the 990 (mine's an '07) and not knowing anything about how it worked, I tried touching any/all wires together, grounding combinations,....nothing worked. We thought it might be some type of mass sensor, and tried everything we could think of.
Then we took the little magnet off my riding partner's front wheel for his TrailTech speedo sensor, and taped it up to the 990's sensor, and,......VVROOOOOM . So the 990 sensor is apparently triggered by a magnet embedded in the sidestand???? Couldn't see indicator of that, but our magnet trick got me the 400+ miles home
Sure did suck getting a fully loaded 990 on the center stand every single time I stopped, but not as bad as walking.
"got no problem with keeping truly roadless areas as wild....
On the other hand, if it has been logged or mined and roads already exist,,
...then that land should be open for public use" (peterman)
Apple Jam is offline   Reply With Quote
Old 12-07-2013, 10:13 AM   #53
charlie264
charlie264's Avatar
Oddometer: 8,371
No worries, its just a simple solution done in small numbers...no advertising just word of mouth.
Old 12-07-2013, 10:45 AM   #54
kelds OP
kelds's Avatar
Oddometer: 128
I can't picture what your version connects to......do you have a close up from a different angle or can you descibe it? Will it fit with all skidplates?
My preference was the CJ one as sometimes I climb on via the left footpeg and theirs seems strong enough, so I'm wondering if your version is mounted and sized to take that abuse.
Edit: charlie264 - no need for pictures - found the thread.
kelds screwed with this post 12-07-2013 at 11:53 AM
Old 12-07-2013, 06:13 PM   #55
tedmarshall
tedmarshall's Avatar
Oddometer: 557
What I Did
Black Dog skid plate.
Bar risers.
Seat Concepts seat mod.
CJ Designs xl pegs.
Scorps or Heidi's.
Ride the piss out of it.
Ted
tedmarshall is offline   Reply With Quote
Old 12-07-2013, 10:43 PM   #56
Qwik
Adrenaline Addict
Oddometer: 6,905
It's not. You can connect the wires on the 950 and it's a done deal.
Topes never seem to make me go any faster.
Qwik is offline   Reply With Quote
Old 12-07-2013, 11:14 PM   #57
Nailhead
Free at last!
Nailhead's Avatar
Oddometer: 6,256
1. Knobs on strong (Woody's or the equivalent) wheels.
2. Suspension rework, something like Superplush does.
3 A burly skidplate like the Weld 86 I've been saved by.
4. A G2 throttle cam for sanity's sake (if applicable).
5. More fuel capacity, like my Adv Tank.
That's a good start, anyway.
6. And maybe include a Rekluse EXP clutch-- I haven't tested it yet, but I have a hunch it will be a boon off-road.
-Chris
'7? Benelli 650S, '80 BMW R100 RS, '93 Ducati 900 SS, '07 KTM 990 Adventure
Nailhead is offline   Reply With Quote
Old 12-08-2013, 04:14 AM   #58
Apple Jam
Forest Flyer
Apple Jam's Avatar
Oddometer: 6,637
Love mine.
Ever kill your motor trying to tractor up a steep loose trail?
I know that feathering the clitch works here, but the Rekluse does it for you, and better. Starting out on that loose steep hill after you kill it is very hard to avoid wheelspin. Rekluse makes it easy.
Going down the steep and loose? Rear brake all you want, and never kill the motor. It simply makes everything easier. But if you rode it and if I didn't tell you it had a Rekluse, you likely wouldn't know. You CAN use your hand clutch like normal if you want.
Just do me a favor, buy it from CJ.
Old 12-08-2013, 06:30 AM   #59
satrider
Oddometer: 69
Bar risers.
CJ Designs xl pegs.
Scorps or Heidi's.
Ted
Can you put bar risers (~30mm) on the 990 ADV without changing out cables?
Old 12-08-2013, 06:43 AM   #60
Zander
Zander's Avatar
Oddometer: 194
I have Rally Connex riser on my 950 with a Pro Taper Carmichael bar. I think they are around 1 1/4" high. Cables are long enough. Should be the same for the 990.
Beginner's mind !
KTM 950
Zander is offline   Reply With Quote
Times are GMT -7.   It's 09:04 AM.
