Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 12-02-2013, 04:44 PM   #1
Okie Preacher OP
Okie Preacher's Avatar
Oddometer: 882
1190R Suspension
Made the expensive mistake of sitting on an 1190 while riding through Arizona earlier this fall.
Currently riding an '09 GS that has been a great bike--particularly after I ditched the stock electronic suspension and installed a set of manual Ohlin TTX shocks sprung for my weight (235#) and riding.
How is the suspension set up on the 1190R? Is there a suggested rider weight for which they are configured out of the box ,and what would it take to make it fit me? The change on my GS was dramatic to the point that I would consider making a change before rolling off the lot on a new bike.
Thoughts?
Okie Preacher is offline   Reply With Quote
Old 12-02-2013, 04:54 PM   #2
LowSpeedHighDrag
KTM Dealer
LowSpeedHighDrag's Avatar
Oddometer: 148
Thoughts?
There will be a "recommend weight" from KTM. I do not have the service/owners manual on an R model at this moment or else I would be able to tell you what that weight would be. I just might have something available on my dealer site tomorrow when I return to my office.
Setting up the R models suspension will be pretty straight forward (pending parts availability). There will be a recommended spring rate for your weight and you can fine tune with the clickers. Unless you are way off the chart I would recommend breaking in the suspension and deciding what you don't like about it before changing it up. It's much easier to fix a problem when you know what that problem is :) Also take into consideration what you will be doing with your machine.
Hope that helps!
Derek
2014ish KTM 1190 Adventure
LowSpeedHighDrag is offline   Reply With Quote
Old 12-02-2013, 05:05 PM   #3
LowSpeedHighDrag
KTM Dealer
Oddometer: 148
Just checked KTM's site and the US spec 1190 R's owners manual is posted. Reading now to see if I can find the weight.
Here is some of the technical info (spring rates and settings) but no weights. I'll make some calls tomorrow and see what I can turn up.
LowSpeedHighDrag screwed with this post 12-02-2013 at 05:17 PM
Old 12-02-2013, 05:55 PM   #4
Okie Preacher OP
Oddometer: 882
I appreciate the effort! I see that in the documentation both the forks and the shock quote a "Spring Rate Medium (Standard)." Makes a guy wonder if a set of "heavy" springs might be an available option from the factory.
Old 12-02-2013, 06:38 PM   #5
LowSpeedHighDrag
KTM Dealer
Oddometer: 148
Normally yes. Usually sold right from the fiche.
Old 12-02-2013, 07:52 PM   #6
GZERO
Fixing stuff around
GZERO's Avatar
Oddometer: 265
In theory i guess the suspension might be a little too soft or right in the limit for you.
But did you know that if you send your suspension to superplush and spend less than 1k it will be worlds appart from your GS?
I usually send my clients suspension to superplush (and im in Venezuela) and they always end up with very big smiles on their face.
I guess you could drive the bike as is for a while and then send it to superplush if you think it could be better.
Either way i can guarantee that the superplush setup will be a lot supperior than your gs
Having some time off bikes.....family first :(
GZERO is offline   Reply With Quote
Old 12-03-2013, 04:21 PM   #7
Okie Preacher OP
Oddometer: 882
Nice! Thank you.
And if you will, PM me the info on your dealership in AZ.
Old 12-03-2013, 04:30 PM   #8
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,779
I believe ken (powercell) was developing a TTx kit for the 1190 if you like the ohlins that much. not sure how this is going tho???
Pete
Turtleshell5@icloud.com
For those who sit at home and dream-let them...Meoni
Pete640 is offline   Reply With Quote
Old 12-03-2013, 05:01 PM   #9
LowSpeedHighDrag
KTM Dealer
Oddometer: 148
Nice! Thank you.
PM sent.
Old 12-03-2013, 06:34 PM   #10
The Walrus
Gone and back again.
The Walrus's Avatar
Oddometer: 8,997
I'll step out......or in.......and make a SWAG.........based on the KTM bikes I'm familiar with......990, 690e, 500exc.....
Medium KTM springs are set for 75-85 kg weight. That's 165-187 lbs for rider and gear. Way lower than most riders with gear. They then give you 4 levels of adjustment to accommodate riding.
Comfort is the soft setting, Standard is that weight range, Sport and Full Payload will take you another level higher maybe 15-20%? Either way, it's best to get springs that take you into the middle of their range.
On the bikes I know about, the KTM heavy springs will bring the weight range up to 85-95 kgs or 187-209 lbs, still short of where a bigger American will land with gear. I've had to go to aftermarket springs to get above that range but the KTM adjustments of Sport and Full payload will stretch into my real world weight.
Physics being what it is, I'm really curious how many of the Standard Adventures will be properly fitted to their owners with the correct process. That's a huge advantage of that bike to me, if properly set up you have a great range of weights to electronically adjust the bike to it's load which has a huge impact on ride and performance.
I am really intrigued by these bikes and hope to acquire one.......
Everbody's preachin' at me that we all wanna git to heaven, trouble is, nobody wants to die to git there.-BB King
Reality is what does not go away when you stop believing in it. -Philip K Dick
I wanna be skinny, but my ass is too big. - Charles Barkley
When choosing between two evils, I always like to try the one I've never tried before. - Mae West
Experience is what keeps a man who makes the same mistake twice from admitting it the third time around.
The Walrus is offline   Reply With Quote
Old 12-04-2013, 01:01 AM   #11
Toors
Toors's Avatar
Oddometer: 120
Front was way to soft standard and dove under braking and bottom out in the tech stuff, replaced it with progressive springs and a revalve (I am a big boy though)
Toors is offline   Reply With Quote
Old 12-04-2013, 05:36 AM   #12
Okie Preacher OP
Oddometer: 882
I weigh 110-115 kgs in riding gear and it is real easy to have another 20-25 kgs of gear in the panniers. When I slapped on the Ohlins sprung for my weight it was as if the heavens opened and the angels sang. Completely transformed the bike--in corners, on dirt and fire roads. And, it no longer chews up my backside on long days chopping across highway seams and bumps.
Getting the suspension right is EVERYTHING.
Old 12-04-2013, 04:57 PM   #13
Bigem
Bigem's Avatar
Oddometer: 2,565
I weigh about 90kg wringing wet with gear, and so far I have found the standard spring weight to be ideal.
I reckon there is enough 'adjustment' in the standard bike to take me and my luggage without too many issues.
"I'm a thousand miles from nowhere,
Time don't matter to me,
Cause I'm a thousand miles from nowhere,
And there's no place I'd rather be!!
Bigem is offline   Reply With Quote
Old 07-22-2014, 10:17 PM   #14
speed_racer
speed_racer's Avatar
Oddometer: 707
I weigh about 95kg Plus gear (maybe 105 to 110kg?) and found in offroad the rear spring was a bit too stiff and wouldnt bog down enough and allow me to throw more weight across the back etc.. I'm probably pushing it where you would take a motoX bike rather than an adventure bike though..
I think I need to wind off more preload than it says for comfort mode. (why do they call it comfort mode instead of offroad mode? Even the BM's call it the same)
13' KTM 1190 Adventure R
KLX650R
RIP - BMW F650 GS Twin
speed_racer is offline   Reply With Quote
Old 07-23-2014, 03:47 AM   #15
scudrunner82
combustion addict
scudrunner82's Avatar
Oddometer: 2,472
You really should measure the sag instead of using the suggested settings for an "average" rider. I had to wind out the preload all the way, front and rear to get it close to where it should be. I'm only 73kg plus gear. I also backed out the high speed comp on the back quite a bit. It makes a huge difference. The bike works really well now.
Hungry Tenere TripTeam Ghetto Does a Hot Lap of America
350, 450, 848, 900, 1190r
My Youtube channel----- https://www.youtube.com/channel/UCXo...kdER0Y5QfoE9gQ
scudrunner82 is offline   Reply With Quote
Times are GMT -7.   It's 12:18 AM.
