Go Back   ADVrider > Riding > Regional forums > Australia > OZ Vendors
Old 03-11-2015, 02:08 AM   #91
xronly
xronly's Avatar
Oddometer: 258
25l safari tank,honda jacket
25L SAFARI FUEL TANK , SUIT HONDA XR , COMES WITH 2 FUEL TAPS ,DUEL FUEL LINE , CROSS BRACE , CAP GOOD CONDITION $280 + postage,AUS only
HONDA JACKET , SIZE L , ROAD/DIRT/ADV , HEAVY NYLON , SHOULDER , ELBOW , UPPER BACK PADDING , NEW NEVER BEEN WORN $110 +postage,AUS only
xronly is offline   Reply With Quote
Old 03-12-2015, 03:27 AM   #92
nry
nry's Avatar
Oddometer: 1,512
2009 Honda CRF450X GHR.
Old picture which I'll swap later.
This bike is a distraction to me and I need to focus I also need the space in my garage and the giant child needs a new bike.
This awesome beast comes with the following
GHR engine with flowed head and engine mods, valves, piston, crank etc
GHR Carb modifications
GHR airbox mods
Pro circuit full exhaust system which I was told can't be bought.
All of the above is matched and the bike is quick. Starts first time hot or cold and sounds insane. (This bike belonged to one of the mechanics)
Goodridge brake lines front and rear
TM designs chain slider kit
TM designs rear disc protector
TM designs rear brake caliper protector
Force bashplate
Force radiator guards
Big Radiators
Fastaway foot pegs
Stegz pegz
Gutz racing seat
Bark busters
Probably things I've forgotten.
DID 520 X ring racing Chain is ok as is the rear sprocket, the front will require replacement in the near future.
Spares
Head
Crank
Two new spare rear sprockets
All original road gear / exhaust system / electrics
I've mostly used this bike to ride trails. I also did Condo on it last year. Its never missed a beat. Has 289 hours on it, always serviced with Honda OEM oils / filters etc every 10 hours.
I got the pink slip today and if I rego it then it will run to late February 2016 depends if the buyer needs it to have rego. If no rego required we can take it off the price.
Looking for $6,500
nry screwed with this post 03-14-2015 at 09:04 PM Reason: dropped the price.
nry is offline   Reply With Quote
Old 03-13-2015, 12:51 PM   #93
B1
Carbon-based bipedal
B1's Avatar
Oddometer: 3,388
2 x NOLAN CLASSIC N-COM HELMETS, BOTH MEDIUM SIZE $180 Brisbane
2 x NOLAN CLASSIC N-COM HELMETS, BOTH MEDIUM SIZE $180 BRISBANE
Purchased about seven years ago but virtually never used... the old man planned on some long trips with the Goldwing that never eventuated. The intercom system was never purchased. The helmets have always been stored, never dropped and are in excellent condition but you can see on one helmet where the finish has chipped for some reason.
Available for inspection and/or pick up at Robertson (near the QEII stadium in MacGregor). Send a PM or ring Bevan on 0438 723 171.
MANUFACTURER'S BLURB
Ready for N-COM communication system.
Aerodynamic polycarbonate shell with built-in spoiler for improved stability.
VPS (Vision Protection System) - short dark shield mounted on outside of the shell and moving independently from the clear shield with 3 positions.
Fully removable and washable interior on snaps and tabs.
Removeable cheek pads.
Top vent operated by rubber slider and chinbar vents operated by rotating dial.
Optically correct, tool-less quick-change Lexan faceshield, offers UV 400 Protection.
Multi-position anti-scratch shield accepts NFR antifog insert (included).
Velour chin strap padding.
B1 is offline   Reply With Quote
Old 03-13-2015, 12:55 PM   #94
B1
B1's Avatar
Oddometer: 3,388
2 x Airhawk motorbike seat cushions, rider & pillion $180 Brisbane
2 X AIRHAWK MOTORBIKE SEAT CUSHIONS, RIDER & PILLION $180 BRISBANE
Purchased a few years ago for $350 and barely used. Available for inspection and/or pick up at Robertson (near the QEII stadium in MacGregor).
Send PM or ring Bevan on 0438 723 171.
Manufacturer's blurb
Patented system eliminates painful pressure points and promotes consistent blood flow for a longer, more comfortable ride. And it's fully customizable and portable use it on any bike, for any rider.
Handcrafted from soft, pliable, non-hardening neoprene and features a breathable, stretchable outer cover with a non-skid bottom, as well as tie-down straps. It'll stay where you put it.
Open mesh side panels allow air to circulate between the air cells and out the side of the cushion, reducing heat build-up and keeping you cool and dry. The cushion is waterproof, and the cover material is made of quick-dry material, just in case it gets rained on.
Small interconnected air cells evenly distribute your weight and pressure over the whole cushion, reducing the "hot spots" that cause pain.
Old 03-13-2015, 04:25 PM   #95
nry
nry's Avatar
Oddometer: 1,512
Fastway series 5 steering damper and under bar mounting kit.
Fits CRF450R 2005 - 2008 and CRF450X 2005 on.
Bolts straight on.
http://www.dirtrider.com/tests/parts...damper_review/
Retails between $700 - $800
$450
Old 03-13-2015, 06:38 PM   #96
THE GAV
The Gav
Oddometer: 486
Bump
Originally Posted by the gav View Post
price drop
$12 500
i have my 950 for sale,
got 18000 on clock, wings pipes safari tank etc
2006
Had buyer that stuffed me around, now I need the cash hence forth the big price drop. Good condition
call 0754427548 or 0415538429
advertised elsewhere for more, they also won't get all the other stuff in my shed for the se.
gwbasil@bigpond.net.au
or pm me
http://nevgriff64.smugmug.com/other/...ownload-xl.jpg
[/quote]
THE GAV screwed with this post 03-15-2015 at 02:04 AM
THE GAV is offline   Reply With Quote
Old 03-14-2015, 12:51 AM   #97
willows
Oddometer: 301
2005 Kawasaki KLR 650
$3500.
74,000ks. Yes, it has been used.
Wossner piston, rings and rebore done at 64,000. (receipts).
"doohickey" upgraded.
3 mths rego.
Trailwing front and Anakee 2 rear tyres.
Cogent Dynamics suspension front and rear.
Heated grips.
Throttle lock.
Alloy radiator (new).
Vapor dash (original supplied as well).
26lt plastic tank. (over 500ks before reserve).
Alloy bash plate.
Regularly serviced. (service history available).
Located near Grafton, nth NSW.
0409 119 228.
can email pics.
2005 KLR650
willows screwed with this post 03-14-2015 at 03:21 AM
willows is offline   Reply With Quote
Old 03-15-2015, 01:19 AM   #98
SafariBerg
Oz Safari Addict
SafariBerg's Avatar
Oddometer: 3,049
Bimota db1 1985 framed factory poster bellissimo
for sale BIMOTA DB1 1985 FRAMED FACTORY POSTER BELLISSIMO extremely RARE !!!!
DUCATI ENGINED BIMOTA DB1 750, genuine factory limited edition poster produced at the time of the original DB1 release in 1985, framed and glass mounted......................a must for any Bimota or Ducati man cave !!!
880mm high x 600mm wide
large & very fragile, local pick up in Perth is best
$250
2013 Husaberg FE501
2014 Arctic Cat Wildcat Z1 1100T Rallye
SafariBerg is offline   Reply With Quote
Old 03-15-2015, 01:52 AM   #99
B1
B1's Avatar
Oddometer: 3,388
2013 BETA 300 EVO TRIALS BIKE FOUR STROKE excellent condition $6500
2013 BETA 300 EVO TRIALS BIKE FOUR STROKE EXCELLENT CONDITION
Carefully maintained trials bike only used at clubman level, still on original tyres. Extremely reliable bike and gentle power delivery for beginner riders and clubman but plenty of power still with a big handful of throttle for higher grades. Extremely quiet, you can practise in the backyard and the neighbours will barely be able to hear the bike.
- Lanyard killswitch fitted (required for club riding)
- Swingarm, front disc, CDI and fork protectors
- S3 bar ends
- alloy bashplate
- Manual in hard copy and CD
- sidestand
- Headlight & horn (not in pics).
$6500 and available for inspection at Highgate Hill in Brisbane. No offers by phone or email, please come to inspect first. Can email more photos if needed.
Ph 0407 109 218
Old 03-15-2015, 03:35 AM   #100
TopDogDave
Manly, NSW, Australia
TopDogDave's Avatar
Oddometer: 164
1973 bsa b50mx
Been restored by PO probably 10+ years ago.
Since then largely unused. Excellent condition.
I bought it 5 years ago-been in storage till 6 months back.
Oil and fuel systems cleaned out, stuff adjusted.
She starts first kick and goes well!.
Not registered ever - no docs.
Currently on a mates farm near Mudgee NSW so it can be exercised.
Will bring it back to Sydney next month.
Comes with 2 fuel tanks - both alu polished - one is tiny peanut sized the other a bit bigger.
Expressions of interest around $9K.
'90 R100GS PD - large
'94 XR600R - medium
'73 BSA B50MX - small
TopDogDave is offline   Reply With Quote
Old 03-15-2015, 04:48 PM   #101
FatBoyCrash
Buckle up SpankY!!
FatBoyCrash's Avatar
Oddometer: 1,130
45mm Marzocchi front end
Gudday,
I've got a 45mm front end from a 2005 Husqvarna TE/SM 610 for sale. I'll post it here for a few days and if no interest off to flea bay we go. It's in superb condition for it's age. The SM and TE front end are exactly the same. Someone might have a project or something? $300 beer tickets plus postage. Being originally a SM610 front end it's done very little dirt work. They are sprung pretty heavy in the .48 sorta range. PM me.
#BUMP#
Built In Shed
Because chrome don't get ya home.
FatBoyCrash screwed with this post 03-27-2015 at 03:17 AM
FatBoyCrash is offline   Reply With Quote
Old 03-15-2015, 04:56 PM   #102
Tony T
Oddometer: 1,438
Kawasaki 1000GTR
1992 Kawasaki 1000GTR. 65500km, but that may go up as I continue to ride it. Rego until May 8. Front tyre done only 1000km. Rear tyre 40% left.
Generally scruffy, but reliable. L/H fork seals leaks. Fuel tank has had pin holes repaired. Fairing had crack repaired. Weirdo seat cover.
General scrapes and bumps. Looks better in the photos than in the flesh, but starts first time, every time. $1750.00 located in Tanunda SA.
Please send me a pm or email if interested.
Tony T screwed with this post 03-15-2015 at 10:39 PM
Tony T is offline   Reply With Quote
Old 03-15-2015, 10:13 PM   #103
angryad
Don't drop the soap.
angryad's Avatar
Oddometer: 1,451
POD MX Knee Brace
I have for sale a XL Right Knee, Pod MX knee brace for sale. bought it in 2009. has been well used. been to NZ and Cambodia. pretty sure I've sweated and crashed wearing it. works fine has scuff marks and stains on it, but nothing broken. I've lost a heap of weight, so it's too big for me now.
how does $100 posted anywhere in Oz sound?
itwm located in Busselton WA
oh, it's the first generation brace too i'm pretty sure
I can/t post pics on here, cause im too tight to pay for a smugmug account, but text me on 0467 613 056 and i'll send ya pics.
cheers
Ads
our latest Goldfields trip
http://www.youtube.com/watch?feature...&v=pQk4k_xXC3k
angryad screwed with this post 03-17-2015 at 08:20 PM
angryad is offline   Reply With Quote
Old 03-17-2015, 07:02 PM   #104
nazza
Trouble
nazza's Avatar
Oddometer: 2,295
Cry dr650
After much thought I have decided to sell Charlie. I havent ridden him much in the last 2 years and its waste for him to be sitting in the garage when someone else could be having fun with him. He does have high kms (73000 or so) but they were definitely girly ks! Not a lot of it was off-road and when it was it was me riding slow and carefully. If you wish to have a look we are located in Nambour, Qld. I am after $3000 for him.
2007 Suzuki DR650
Gear / Mods
New battery, cdi, stator and pickup
Mitas e-07 tyres with at least 3/4 tread left
30L Safari Tank
Has been single seat regoed so no rear pegs
Custom seat which is a bit lower and heaps more comfortable
Bike is lowered 20mm
Intiminators in the front forks
Custom racks for panniers and rear luggage. (Work fine but will probably need new bolts and some paint.)
Cigarette socket in front dash
Screen
Bark Busters
BNB bash plate
Lowering kit on pegs
After-market front guard
Adjustable brake and clutch levers
2 oil filters, owners manual and front tube.
The luggage is not included
$3000 AS IS
dr650: Charlie
My Adventure Riding Blog | Adventure Riders Blogs |
nazza screwed with this post 03-17-2015 at 07:57 PM Reason: added stuff
nazza is offline   Reply With Quote
Old 03-17-2015, 07:40 PM   #105
MymoJoe
Ride Ride Ride
MymoJoe's Avatar
Oddometer: 2,936
Cheng Shin Trials Tyres
For Sale Cheng Shin 3.00-21" front Trials Tyre
Brand new
$40
Pick up Ipswich QLD
Simpson Trip 2008
http://www.advrider.com/forums/showt...33#post7397233
Life should NOT be a journey to the grave with the intention of arriving safely in a well-preserved body, but rather to skid in sideways, body thoroughly used up, totally worn out and screaming "WOO HOO - what a ride!"
MymoJoe is offline   Reply With Quote
Times are GMT -7.   It's 06:40 AM.
