Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 01-19-2014, 08:13 PM   #166
dewaynehasty
Oddometer: 126
yep
Originally Posted by Nowwhat View Post
2014 boys...
you buy it...then ride the piss out if it....
I am at 650 miles....no oil loss....on a closed course yesterday the bike may have gone north of 120mph....
I like your thinking! However I'm trying to keep the RPMs below 6500 for the first 600 miles as recommended.
dewaynehasty is offline   Reply With Quote
Old 01-19-2014, 08:18 PM   #167
OrangeV
OrangeV's Avatar
Oddometer: 757
Shift Light 1 and 2
Hi Guys
What would be the best rpm to set the two shift lights.
I think its kind of cool to have the lights set early.
what are your thoughts.
RPM 1 =
RPM 2 =
75° V perky peak power from around 5000rpm and loves to be worked through the gears.
When you hit that sweet spot, it is simply electrifying. Stoner
A smile is a curve that sets allot of things straight..
OrangeV is offline   Reply With Quote
Old 01-19-2014, 08:42 PM   #168
FootLB
Oddometer: 115
Yeah exactly. The manufacturer wouldn't specify break in procedures unless they were the best for the machine.
FootLB is offline   Reply With Quote
Old 01-19-2014, 08:53 PM   #169
kag
Wander Lust
kag's Avatar
Oddometer: 1,791
A different "Break" in proceedure
Well.....my new 1190 has its own break in procedure.....for me
Its called a Distal Fibular Fracture
“Always drink upstream from the herd”
2007 Yamaha TW 200 / 2008 Buell Ulysses
2013 Triumph Tiger 800r / 2014 KTM 1190 EDS
kag is offline   Reply With Quote
Old 01-19-2014, 09:08 PM   #170
PatSmith
Oddometer: 391
Ouch. Been there done that. Hope recovery goes well. Do you need surgery
09 GSA
11 F800gs
PatSmith is offline   Reply With Quote
Old 01-19-2014, 09:26 PM   #171
Fuzzy.Wuzzy
Fuzzy.Wuzzy
Oddometer: 11
Canisterectomy
Pretty easy.... rip out the canister and bracket.
Follow the hose back to the PCV valve (under gas tank on left)
Pull the hoses off the valve.
The one from the canister.... ditch it.
The one from the Y connector to the canister comes from the cylinder heads. plug it with a bolt and clamp or similar.
Rearrange the venting from the gas tank.... two vents (one is in, one is out) T them on top of the tank and drain to left side of engine with other tubes.
Cap off the PCV valve hose nipples. But leave the electrics plugged into the PCV valve or you'll get a fault code. (ask how I know!)
That's it.... lots of room now in the tail for tools plus.
Fuzzy.Wuzzy is offline   Reply With Quote
Old 01-19-2014, 09:27 PM   #172
Fuzzy.Wuzzy
Fuzzy.Wuzzy
Oddometer: 11
Workshop manual
Anyone know where to get a workshop service manual? (not the operators manual)
Old 01-20-2014, 01:53 AM   #173
OrangeV
OrangeV's Avatar
Oddometer: 757
TechSpec Installation
Hi
As you all know the black plastic where your knees lock into is very shiny and slippery, and when pinched by the knees does not induce confidence or comfort.
I therefore installed the TechSpec product called snake from the RC8 model. They have not produced one for the 1190 yet.
This product allows you to anchor yourself to the bike and also while cornering will give good grip and confidence so you dont need to hang hard on the bars.
Its not a perfect fit, but will do the job that it needs to do..
Old 01-20-2014, 07:32 AM   #174
harryzgnilek OP
Oddometer: 377
Rigid Industries 6" Single Row LED Light
Hi all
what do you guys think of the 6 inch Rigid LED lights 3340 Lumens
http://blackdogcw.com/black-dog-shop...-r-detail.html
thinking its a good aux light alternative.
harryzgnilek is offline   Reply With Quote
Old 01-20-2014, 07:50 AM   #175
Tjeu
Oddometer: 143
Originally Posted by harryzgnilek View Post
Hi all
I think it is very ugly
Tjeu is offline   Reply With Quote
Old 01-20-2014, 08:08 AM   #176
harryzgnilek OP
Oddometer: 377
are you satisfied with the amount of light the stock lights give you?
Old 01-20-2014, 08:20 AM   #177
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 5,053
Hi all
great set up...Rigid products are amazing...
KTM 1190R...Adventure Beast, 950SE......Desert Beast, KTM 690 Quest...Rally Beast, Husqvarna 501...Trail Beast, KTM 300xc...Woods Beast
Nowwhat is offline   Reply With Quote
Old 01-20-2014, 08:57 AM   #178
Espada
Oddometer: 99
Hi all
I think that is a great set-up! I will definitely order one when I finally get my 1190 R
Espada is offline   Reply With Quote
Old 01-20-2014, 09:15 AM   #179
DirtJack
DirtJack's Avatar
Oddometer: 1,606
2014 boys...
I thought I saw similar speeds till I hooked up my GPS.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 01-20-2014, 10:13 AM   #180
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 5,053
That was GPS.....hahahahaha.....amazing how far off it is....good news is that the when you think you need an oil change....you don't yet....
Times are GMT -7.   It's 10:20 AM.
