Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 07-25-2014, 04:15 PM   #3106
silverdog
silverdog's Avatar
Oddometer: 569
Any one change there cigarette receptacle to a power let , or use an adaptor?
silverdog is offline   Reply With Quote
Old 07-25-2014, 04:39 PM   #3107
alongat
alongat's Avatar
Oddometer: 1,231
Haha, so true...
Originally Posted by reenmachine View Post
Unless you're going reeeeeaaaaalllly slow the lighting turns opposite the direction of travel!
Toronto, Canada
KTM 1190 ADV, KTM 530 EXC
Gone: Ducati 999R, KTM 530EXC, KTM 990ADV-R, KTM 950ADV, KTM 690, KTM 640ADV, kTM RC8R, Ducati 996S, Yamaha R1
And how can this be? For he is the Kwisatz Haderach!
alongat is offline   Reply With Quote
Old 07-25-2014, 04:42 PM   #3108
alongat
alongat's Avatar
Oddometer: 1,231
Why would anyone bother using an adaptor to the powerlet socket. My understanding is that the powerlet socket and plugs are designed to keep accessories plugged in with the snap rather than relying solely on the cigarette lighter style friction and spring tension. If you inserted a powerlet adaptor into the cigarette socket, couldn't the powerlet adaptor simply pop out from vibrations / bumps?
Toronto, Canada
Old 07-25-2014, 06:01 PM   #3109
Simonhantler
Oddometer: 315
Line up
Nowwhat I was looking at your bikes, and I'm impressed at your line up. Perfect bikes.
QUOTE=Nowwhat;24690716]It is magic....Love Rigid products
Have them everywhere...
[/QUOTE]
Simonhantler is offline   Reply With Quote
Old 07-25-2014, 07:22 PM   #3110
JBird
Retriever
JBird's Avatar
Oddometer: 856
Yes. I used a couple big stainless washers to center the Powerlet since the cigarette style is larger. After I did this I saw somewhere on here where an inmate was making delron washers that match the dash.
Used the adaptor for a couple months until I got around to the changeover. There was a lot of corrosion between the adaptor and the cig plug. I guess dissimilar metals along with the current caused this pretty quickly?
JBird
KTM 1190R
KTM 950SMR
'08 Goldwing
'98 Golden Retriever
JBird is offline   Reply With Quote
Old 07-25-2014, 09:38 PM   #3111
TDsurf
Orange Flyer
Oddometer: 98
Kickstand
Does anyone have information on a relocation kit for the kick stand, so it's not mounted to the motor?
I kind of remember it being talked about.
Any information would be appreciated.
TDsurf is online now   Reply With Quote
Old 07-25-2014, 11:39 PM   #3112
XsilverGS
XsilverGS's Avatar
Oddometer: 164
Have you a link to these washers as this is on my list of "Things to do"
XsilverGS is offline   Reply With Quote
Old 07-26-2014, 02:52 AM   #3113
ebrew
Motorcycle A.D.D.
ebrew's Avatar
Oddometer: 1,414
Yes
Look in vendors or on ebay ( USA) and you will find his kit .
ebrew is online now   Reply With Quote
Old 07-26-2014, 06:25 AM   #3114
alongat
alongat's Avatar
Oddometer: 1,231
Galvanic corrosion...
Toronto, Canada
Old 07-26-2014, 07:31 AM   #3115
XsilverGS
XsilverGS's Avatar
Oddometer: 164
@ ebrew
Many thanks and here's the link for others http://www.advrider.com/forums/showt...owerlet+washer
Old 07-26-2014, 04:02 PM   #3116
silverdog
silverdog's Avatar
Oddometer: 569
Originally Posted by XsilverGS View Post
@ ebrew
Thank you......
Old 07-27-2014, 03:29 AM   #3117
CHRIS_D
CHRIS_D's Avatar
Oddometer: 966
Originally Posted by DirtJack View Post
Use something like a Skene relay/dimmer circuit, triggered by your high beam switch (full power with high beam), and a programmable (off to full power in 10% increments) for low beam. Here's how I used a Skene IQ-175 to control my aux LED lights.
I appreciate the info and that's exactly what I'm looking for. Do you know if anyone has run a dimmer with a Rigid product? A while back I had Kurt at BD check into running a PWM dimmer with a Rigid product. He contacted the manufacture and Rigid claimed (at the time) their LED weren't designed to be able to dim. This was many years ago, so it may of change. I currently use Cyclops 10 Watt rounds driving LED with a dimmer on my other bike. Great product and seem to be durable, however I really like the Rigid light bar for the KTM.
2014 KTM 1190 Adventure R
2011 Victory Cross Country
CHRIS_D is offline   Reply With Quote
Old 07-27-2014, 10:10 AM   #3118
KawiPhil
KawiPhil's Avatar
Oddometer: 21
Tie Down setup for 1190 ADV R
Has anyone transported their 1190 ADV and if so what tie down set up did you use? I have a few trips planned this summer and will be hauling my 1190 in a toy hauler. I have always used a Canyon Dancer Strap (original) on my sport bike and KLR650 but it tends to put pressure on the controls and twist the grips. Plus the KTM has the hand guards attached to the bar ends which none of my previous bikes had.
I have a Bolt It On set up in the TH. I ordered a Canyon Dancer II and a High Roller Bar Harness to see which works better but would like to get feed back from those that have been there. Thanks!
14 KTM 1190 ADV R, 10 KLR 650, 09 Ural Gear Up, 81 KZ750, 78 KZ650B, 79 KZ650C, 74 Yamaha DT360
KawiPhil is offline   Reply With Quote
Old 07-27-2014, 10:51 AM   #3119
BHoward
BHoward's Avatar
Oddometer: 122
I transported my 1190 from LA to NYC (3000 miles) on this trailer http://www.scandipacific.com/product...roduct=Folding with the aluminum deck and extra tie downs.
I removed the hand guards and used the Canyon Dancers on the bars, 2 tie downs on the crash bars, 2 tie downs on the passenger pegs and 2 on the rear deck.
Overkill I know, but I want to feel like if I held the trailer upside-down the bike will still be secured.
The trailer and the bike made the trip with zero issues.
Removing the hand guards and using the Canyon Dancers is the way to go.
BHoward is offline   Reply With Quote
Old 07-27-2014, 10:58 AM   #3120
Jim Colombotos
Jim Colombotos's Avatar
Oddometer: 321
1190R BDCW light bar measurement request
Anyone install light bar kit (Picture of a install on page 206 ) on their 1190R . Can one of you take a measurement...bottom of light bar top of fender. Im having some clearance issues, possibly due to my install or maybe 1/4" lower triple clamp? Measurement of 1190 standard; Givi bar setup measurement (on page 207) would be great too.
Guess on the R we need about 8.6"?
Thx
Jim
2013 KTM 500 EXC
2009 KTM 990 Standard
2014 1190 R
2015 350 EXC
Jim Colombotos screwed with this post 07-27-2014 at 11:08 AM
Jim Colombotos is offline   Reply With Quote
Times are GMT -7.   It's 10:08 AM.
