Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 01-31-2014, 07:47 AM   #391
Black Hills
Oddometer: 1,183
My '11 990R seat was an inch or two higher than my 1190R. The 1190 seat seems a bit more comfortable but I haven't ridden more than 100 miles at a time yet so not sure?
Black Hills is online now   Reply With Quote
Old 01-31-2014, 08:07 AM   #392
gregdee
Motocampist
gregdee's Avatar
Oddometer: 448
Originally Posted by Fredii View Post
You don't have to grind that tab. Just loosen the switch housing screws and the whole thing will rotate on the bars. The tab only keeps the mirror in the same position in relation to the brake lever and throttle housing.
I don't like having my ignition switch not being vertical so I don't want to rotate both parts if I don't have to - but maybe I'll get over that.
I tried separating the two but you have to rotate the mirror/brake fairly far forward if you don't, or separate the two parts by about 3 mm horizontally (the size of the tab). I was just fuzting around for a bit last night when I looked at this - didn't spend more that a few minutes. I've set aside all day today to work on fit issues and to get my GPS and Escort mounted and powered. Supposed to be blowing 65 mph out today so that should keep me inside working instead of out riding.
gregdee is offline   Reply With Quote
Old 01-31-2014, 08:19 AM   #393
DirtJack
DirtJack's Avatar
Oddometer: 1,525
I'm 6'4" (34" inseam). My 990 had a built up Renazco seat and was perfect for my size (2" bar risers on a wider higher ProTaper). The 1190R seems lower to me but the foot pegs are higher and more forward than my aging knees like. Also, the cut-out stock seat is impossible for me, so James is making a new level seat which will be higher and not too wide between the knees. Will look something like this (not my bike):
I have a wider, higher ProTaper for the 1190R which will go on when my heated grips come in. I may try some foot pegs which are about 1/2" lower.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is online now   Reply With Quote
Old 01-31-2014, 12:19 PM   #394
harryzgnilek OP
Oddometer: 361
Why are so many KTM accessories back ordered.
Didn't they know people want them when they pick up their bikes
:o
harryzgnilek is offline   Reply With Quote
Old 01-31-2014, 03:18 PM   #395
gregdee
Motocampist
gregdee's Avatar
Oddometer: 448
Originally Posted by Fuzzy.Wuzzy View Post
Pretty easy.... rip out the canister and bracket.
Follow the hose back to the PCV valve (under gas tank on left)
Pull the hoses off the valve.
The one from the canister.... ditch it.
The one from the Y connector to the canister comes from the cylinder heads. plug it with a bolt and clamp or similar.
Rearrange the venting from the gas tank.... two vents (one is in, one is out) T them on top of the tank and drain to left side of engine with other tubes.
Cap off the PCV valve hose nipples. But leave the electrics plugged into the PCV valve or you'll get a fault code. (ask how I know!)
That's it.... lots of room now in the tail for tools plus.
I'm new to this "canisterectomy" thing. I pulled out the cannister and mount then couldn't find any electrical connections to the cannister. Started to trace the hoses under the tank but I just spend all day working on getting my electronic gismo's hooked up so not really ready to tackle another project. Anyway, started the bike then removed the smaller hose from the side. Bike still runs - no errors. Then I unplugged the bigger hose from the center. Still not errors. Turned off bike. Restarted bike. Still runs, no errors. I plugged up the two hoses. Is that it? Can't be that easy. Do we not have the same systems in place if we're outside of CA? Fuggit - I'm going for a ride.
Old 01-31-2014, 03:38 PM   #396
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 4,867
One hose is the vent from the gas tank.....do not plug...
'14 1190R...Adventure Beast
'13 690 Quest...Rally Beast
'15 Husqvarna 501...Trail Beast
950SE......Desert Beast
Nowwhat is offline   Reply With Quote
Old 01-31-2014, 03:54 PM   #397
PowerCell
Manufacture
PowerCell's Avatar
Oddometer: 2,368
Originally Posted by DirtJack View Post
The 1190R seems lower to me but the foot pegs are higher and more forward.
It looks like your pegs might be installed in the higher position. You can flip the mounts upside down for another 10mm. I also added a set of Fastway Adventure pegs to make it 20mm down and 10mm back. Also increased my travel from 220mm to 265 which raises the bike about another inch...
~ Ken
www.powercellperformance.com
PowerCell is offline   Reply With Quote
Old 01-31-2014, 03:59 PM   #398
Black Hills
Oddometer: 1,183
I simply removed the canister, stuck small lawnmower fuel filter on each hose so the tank vent doesn't suck dust into the tank and tucked them back in the rear section out of the way. took about 3 minutes.
Old 01-31-2014, 05:27 PM   #399
KTM Pilot
KTM Pilot's Avatar
Oddometer: 439
Longer legs
Ken, any chance that you can share what's involved in extending the suspension?
Do you think that the increased angle on the rear (at full extension) are likely to cause wear/bind issues?
PS - I also find the 1190 ergo's (footpeg to seat) more cramped than my 990 - pegs are set low. Thinking about the Radegarrage pegs.
Konrad
Smugmug $5 discount coupon # 2ucrtCWwf7D7A
KTM Pilot is offline   Reply With Quote
Old 01-31-2014, 05:29 PM   #400
PowerCell
Manufacture
PowerCell's Avatar
Oddometer: 2,368
PS - I also find the 1190 ergo's (footpeg to seat) more cramped that my 990 - pegs are set low. Thinking about the Radegarrage pegs.
Konrad
I'm running full Öhlins TTx suspension on both ends. No problems with rear binding but a few mods needed to be done to allow the full travel.
~ Ken
Old 01-31-2014, 05:31 PM   #401
KTM Pilot
KTM Pilot's Avatar
Oddometer: 439
I look forward to the pictures!
Cheers
Old 01-31-2014, 05:45 PM   #402
gregdee
Motocampist
gregdee's Avatar
Oddometer: 448
I like this solution. On a quick spin over to a friends to show off my new toy the bike ran fine with both lines plugged. However, my friend (an old KTM guru of sorts) told me it would work "for a while". I'll go look for some lawnmower filters tomorrow.
Old 01-31-2014, 05:57 PM   #403
DirtJack
DirtJack's Avatar
Oddometer: 1,525
No, the foot peg mount is in the low-rear position. In that position, they seem to be higher and more to the front than the mounts on my 990. Just a recollection now as I no longer have the bike. The Fastway peg may be what I need.
I've been following your 1190R stuff. Are you going to be giving information on the 220 to 265 changes?
2008 KTM 690 Enduro
Old 01-31-2014, 06:02 PM   #404
Wonway
KTM Fanboi #2
Oddometer: 425
My vent line had fuel in it. Doing it the way you said could lead to fuel soaked tools and rear tire.
1994 Ducati 888 LTD #61
2008 Husqvarna TE610
Wonway is offline   Reply With Quote
Old 01-31-2014, 06:02 PM   #405
PowerCell
Manufacture
PowerCell's Avatar
Oddometer: 2,368
We'll be selling the conversion, but as with all our Öhlins conversions, it won't be cheap...
~ Ken
Times are GMT -7.   It's 08:41 AM.
