Old 12-03-2013, 01:49 PM   #1
HiOctaneOverland OP
Oddometer: 20
LC8 Clutch Cover
Hello Chaps,
As the new owner of a 2011 KTM Adventure Dakar I wonder if I could trouble you for some advice regarding the clutch cover?
I have upgraded the standard (cast) version to the KTM genuine replacement CNC part (600.30.126.200), the black anodised one.
So, my question is this - when removing the original I discovered it has a round metal insert bolted to the inside face, approx 1 3/4" in diameter, but the replacement (a genuine KTM part) doesn't. So, what's it for? Why have the KTM engineers designed it into the standard part but not into their own replacement?
Further, do I need one? Obviously they thought it was required on the original, but not the replacement, why not?
Any insight from someone cleverer than me who knows the answer would be gratefully received.
Thank you.
HiOctaneOverland is offline   Reply With Quote
Old 12-03-2013, 04:51 PM   #2
crazybrit
crazybrit's Avatar
Oddometer: 8,556
vibration dampener. The cj-designs clear replacement cover also does not include it (for obvious reasons).
I didn't even know ktm made a hardparts cover. My recollection is that you are not supposed to ever unscrew the vibration dampener from the OEM cover (one time use screw/thread) so you couldn't transfer it over even if the hardparts allowed. Supposedly there is little discernible difference if it's removed but I agree since KTM chose to include one originally, it's odd that they didn't provide one for the hardparts. Maybe they had a change of opinion regarding it's effectiveness/necessity?
Anyways, HTH.
crazybrit is offline   Reply With Quote
Old 12-03-2013, 05:45 PM   #3
mdfehrmann
mdfehrmann's Avatar
Oddometer: 338
If I understand it correctly you had to remove it for the old Recluse Z-Start pro clutch too, and plenty of people did that without issue. That's probably why the hard part comes without one.
Matthew
Only when you take 520lbs of motorcycle and snake it through the woods as slow as you can, will you begin to learn just how much you never knew about motorcycling. -Dieseljo-
2006 KTM 950 ADV S - 2004 Sherco 2.9
http://www.mdfeditions.com/
http://www.cjdesignsllc.com/
mdfehrmann is offline   Reply With Quote
Old 12-04-2013, 04:26 PM   #4
ABuck99
0.0
ABuck99's Avatar
Oddometer: 595
Ive got the same powerparts cover- I found no noticeable difference between the two with or with out dampening. Install it- ride it- forgetaboutit
KTM: 06 KTM950S & 10 KTM450EXC
ABuck99 is offline   Reply With Quote
Old 12-04-2013, 07:36 PM   #5
Orangecicle
Orangecicle's Avatar
Oddometer: 2,570
Early bikes like my June 04 build bike did not have the dampener. My bike works fine without it. Put the cover on and ride it.
Orangecicle is offline   Reply With Quote
Old 12-05-2013, 04:19 AM   #6
RedRupert
Brit in the Soviet Union
RedRupert's Avatar
Location: Riga, Latvia / Bergerac, France / Colchester, UK
Oddometer: 581
I found that the damper makes a considerable difference.
I've recently installed a 2008 990 motor into my 2004, and was struck by how quiet the newer motor is. Immediately after installing the 990 I had a friend visit me with a 2004 950 so that we were able to compare the differences. Running side-by-side the extra noise coming from the 950 is obvious - especially when there is a wall or car on the right to reflect the sound back at you. Place the palm of your hand over the clutch casing to experience a similar effect to that of the damper.
The damper is an improvement, but you don't need one.
KTM 970 Adventure (2004 with carbed 2008 SD 990)
Yamaha WR 450 F
Honda 650 Dominator (1988)
Kawasaki KLR 650 (1988)
Yamaha RD 350 LC (1984)
RedRupert is offline   Reply With Quote
Old 12-05-2013, 12:00 PM   #7
EastSideSM
Isn't that dangerous?
Oddometer: 1,490
Or better yet, get one of CJ Racer's (CJ Designs) see through clutch cover. They are awesome!!!!
EastSideSM: '06 950SM Black
EastSideSM is offline   Reply With Quote
Old 12-06-2013, 09:27 PM   #8
AJ990R
motorcycle guy
AJ990R's Avatar
Oddometer: 216
no more dampner was a concern for me too...
but a CJ cover vs OEM cover "felt" the same in weight
could tell no difference on my 11' 990
"saddle up or shut up"
KaTooM North
AJ990R is offline   Reply With Quote
Times are GMT -7.   It's 10:13 AM.
