Old 12-07-2013, 12:22 AM   #16
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,004
Maybe you should try some checks
Battery voltage, R/R voltage output, battery connections...
Old 12-07-2013, 04:28 AM   #17
kareblak OP
Oddometer: 83
Originally Posted by Boatman View Post
Hmmm,,,, went back and reread and watched the vid again... are you keeping the start button depressed the whole time and it's making those attempts on it's own or are you repeatedly pressing the button?
I'm holding it in. Here's another vid. Is the pump/primer sound kinda off, or is it just me?
https://www.dropbox.com/s/22xt14duzn...207_131354.mp4
Originally Posted by Leodis41 View Post
Hmm, watching the video after each half turn the instruments dim and the rev counter does a full sweep like when you first turn on the ignition.
I would check your battery connections and voltage, it looks like too much current draw for the battery.
Originally Posted by Qwik View Post
Weak battery?
The battery seems ok. It's stable on 12.3V and drops very little after repeated tries. Also, isn't it hard to see how this would change from one day to the next?
'07 KTM 990 ADV
kareblak is offline   Reply With Quote
Old 12-07-2013, 05:15 AM   #18
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,394
As others have suggested,,,, I think your issue is voltage. A fully charged battery at rest should be 12.6-12.8 volts. I think in that vid I can hear the starter relay clicking after each attempt. Fuel pump would have nothing to do with the engine spinning over. Initially I was leaning toward hydrolock because I didn't realize you were keeping the button depressed.
What is the light I see flashing near the handlebar clamp?
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Old 12-07-2013, 06:55 AM   #19
kareblak OP
Oddometer: 83
I'll try to charge the battery over-night and see what happens. I guess I was too unpatient the last try.
The blinking light is the heated grips control.
'07 KTM 990 ADV
Old 12-07-2013, 10:36 PM   #20
Qwik
Adrenaline Addict
Oddometer: 6,855
Turn the grips off. And anything else that pulls power besides the engine.
Topes never seem to make me go any faster.
Qwik is offline   Reply With Quote
Old 12-08-2013, 08:04 AM   #21
Hootowl
Oddometer: 1,258
Check the battery voltage under load. Put the volt meter leads across the battery terminals and then hit the starter and note the voltage drop.
Keep it Wild, Keep it Free
'07 990A
'12 Super Tenere
Hootowl is offline   Reply With Quote
Old 12-08-2013, 09:41 AM   #22
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,394
Correct,,,, also it would be better to use an analog meter rather than digital. The numbers change so fast on a digital that its sometimes hard to get a reading. Unless you have a DMM that has a hold feature.
Times are GMT -7.   It's 05:57 AM.
