Old 12-08-2013, 09:11 AM   #1
sstewart OP
sstewart's Avatar
Oddometer: 1,058
Voltmeter
Looking to install a volt meter on my 990 Adventure. I would like to have a very small meter,that can be a very neat install. Any suggestions on this?
sstewart is offline   Reply With Quote
Old 12-08-2013, 09:35 AM   #2
AndyKirby
Mostly Harmless
AndyKirby's Avatar
Oddometer: 127
I've used the Datel for years and they've proved to be very reliable.
Check out the two wire options. There are also plenty of 'clones' available on ebay shipped directly from China.
http://www.datelmeters.com
Hope that helps.
Andy
AndyKirby is offline   Reply With Quote
Old 12-08-2013, 10:29 AM   #3
gearheadE30
gearheadE30's Avatar
Oddometer: 1,001
I used one of the ebay ones and potted it with hot glue. Works fine.
This is the best pic I have atm.
2005.5 KTM 950 Adventure and 2012 KTM 200 XC-W
1991 BMW 318is turbo track car
1989 Chevrolet Caprice Classic Wagon sleeper tow car
1992 Subaru SVX daily
3 Months Exploring the US on a 950
gearheadE30 is offline   Reply With Quote
Old 12-08-2013, 02:38 PM   #4
JRod152
will work for tires
JRod152's Avatar
Oddometer: 351
HERE is my example on an SE. Works great! Love to see 14.3 volts glowing at me.
Use decent wire not far from a good source for an accurate reading.
"Never let the things you want make you forget the things you have"
JRod152 is offline   Reply With Quote
Old 12-08-2013, 03:27 PM   #5
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 962
What lights are those?
690R
Gustavo.Ramos is online now   Reply With Quote
Old 12-08-2013, 04:22 PM   #6
gearheadE30
Oddometer: 1,001
http://advrider.com/forums/showthread.php?t=931635
Old 12-09-2013, 11:07 AM   #7
CamelBill
Ride It!
CamelBill's Avatar
Oddometer: 534
Hope that helps.
Andy
+1 on the Datel. Installed for over 3 years, zero issues
Camel
KTM 1190R, 950S, 500XC-W
FJR, Wing
CO Single Track RR http://advrider.com/forums/showthrea...0#post24875020
CamelBill is online now   Reply With Quote
Old 12-09-2013, 11:21 AM   #8
6732cash
6732cash's Avatar
Oddometer: 163
You can buy LED battery monitors.. had one on my 950 they work ok and take up less room on dash
6732cash is offline   Reply With Quote
Old 12-09-2013, 12:17 PM   #9
DirtyADV
DirtyADV's Avatar
Oddometer: 2,409
Solved it with a diy aluminum bracket:
A few more pictures here.
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 12-10-2013, 12:29 AM   #10
rossguzzi
990 Adv.
rossguzzi's Avatar
Oddometer: 1,097
These look great.
How do you wire them up ?
Cheers.
990 Adv 06, Aprilia Tuono 03 Racing gen 1
rossguzzi is offline   Reply With Quote
Old 12-10-2013, 03:38 AM   #11
The Doc
Oddometer: 124
/Johan
Ive gotta say that is the ugliest, dodgiest, unprofessional modification I've ever seen on a 990.
You should me ashamed of yourself
BMW Adventure bikes..... just an excuse to go home early
The Doc is offline   Reply With Quote
Old 12-10-2013, 04:17 AM   #12
DirtyADV
DirtyADV's Avatar
Oddometer: 2,409
Have several uglier and even more unprofesssional modifications done, this might be the easiest to spot, but it worked great =)
Its off-topic but you would love my solution to access the subframe bolts and upper shock bolt, just drill holes:
Back to the topic, what about the ctek panel indicator?
Anyone used them and found a good place to mount, I myself is looking to not have anything connected to the front fairings for ease of maintenance and maybe in the future go safaritanks.
Wonder if that panel mount just show low voltage or would it indicate high voltage also? Say the rectifier starts failing?
/Johan
Old 12-10-2013, 06:27 AM   #13
Bundu
Bundu's Avatar
Oddometer: 757
/Johan
I've got the CTEK and also use it as a charge and a power point for compressor - you can see the Voltage levels at which the LEDs switch in the table below - It will not indicate over voltage
_________Vlow_______Vhigh
RED________________12.39
ORANGE___12.40_____12.63
GREEN____12.64__________
Bundu is offline   Reply With Quote
Old 12-10-2013, 06:57 AM   #14
gearheadE30
Oddometer: 1,001
So basically it is green all the time, unless the key is off or you have tons of accessories going. If you have a RR failure, which is the typical charging failure mode. it would still be green. Not sure I like that.
Old 12-10-2013, 06:01 PM   #15
PABiker
Anywhere but here
Oddometer: 3,928
Here's where I put mine:
But the bike belongs to my buddy now.
'03 Suzuki DL1000 V-Strom
'12 Suzuki DR650SE
'10 Husaberg FE450 Plated
PABiker is offline   Reply With Quote
Times are GMT -7.   It's 03:30 PM.
