Old 12-11-2013, 12:55 AM   #16
Bundu
Bundu's Avatar
Oddometer: 730
Originally Posted by gearheadE30 View Post
So basically it is green all the time, unless the key is off or you have tons of accessories going. If you have a RR failure, which is the typical charging failure mode. it would still be green. Not sure I like that.
I think the CTEK items purpose is more to monitor the battery when the bike is parked for extended periods and to then easily connect the charger
The 1190 has a Volt meter in its console display already
Bundu is offline   Reply With Quote
Old 12-11-2013, 10:41 AM   #17
CamelBill
Ride It!
CamelBill's Avatar
Oddometer: 526
Datel Voltmeter
Originally Posted by rossguzzi View Post
These look great.
How do you wire them up ?
Cheers.
Originally Posted by PABiker View Post
Here's where I put mine:
Mine is in same location as PABiker's. I used quick plug in connectors to make for easy removal of side panel. Use a relay on it, or just wire to the switched accessory connection behind your dash, so it is only on when the bike is switched on. Easy-peasy, positive to positive, negative to negative anywhere in the system.
Camel
KTM 1190R, 950S, 500XC-W
FJR, Wing
CO Single Track RR http://advrider.com/forums/showthrea...0#post24875020
CamelBill is offline   Reply With Quote
Old 12-12-2013, 11:05 AM   #18
jonz
Miles are my mantra
jonz's Avatar
Oddometer: 2,439
Some Garmin GPS units have the option to show voltage. I know my ancient III+ did and my current 478 shows voltage. Just a possible option if you're thinking about a gps as well.
JONZ
KTM 950 SE, KTM640 ADV ( Hibachi, risen from the ashes)
KTM520EXC (broken), KTM 400XC (the replacement)
Honda ST1300 ABS (newest addition to the stable)
STOC #326 IBA #217
jonz is offline   Reply With Quote
Old 12-12-2013, 11:52 AM   #19
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,484
My Zumo 450 has this feature, but the voltage it shows is always different from what is shown at the same time on my multimeter.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is online now   Reply With Quote
Old 12-12-2013, 04:04 PM   #20
Afry
Why hike?
Afry's Avatar
Oddometer: 621
Originally Posted by JRod152 View Post
FYI - You need fuel...and probably a rear tire....
KTM 950 SE
Yamaha TDR250
CRF450 flat tracker
Get on with riding or get on with dying - one or the other
Afry is offline   Reply With Quote
Old 12-12-2013, 08:17 PM   #21
JRod152
will work for tires
JRod152's Avatar
Oddometer: 339
LOL! Don't remind me.
...always taking donations for the latter observation!
The 908 fund is getting low.
"Never let the things you want make you forget the things you have"
JRod152 is offline   Reply With Quote
Old 12-13-2013, 11:21 AM   #22
Michhub
Major Medical
Michhub's Avatar
Oddometer: 3,891
ADVMonster
HERE is one cheaper then the Datel that I use...
Mike
Reinheitsgebot
'07 990ADV '08 530EXCR '04 XR650L
Bonsai Elephant - "
Life without a 990 is no life at all!"
Michhub is offline   Reply With Quote
Old 12-15-2013, 11:26 AM   #23
Xmoto
Death Race
Xmoto's Avatar
Oddometer: 2,107
Parts catalogs for electric golf carts will have some nice small gauges.
Opinions are like butt holes. Everyone has one and there's is the only one that doesn't stink.
Xmoto is offline   Reply With Quote
Old 12-31-2013, 06:25 PM   #24
Balsta
Oddometer: 400
Originally Posted by The Doc View Post
Ive gotta say that is the ugliest, dodgiest, unprofessional modification I've ever seen on a 990.
You should me ashamed of yourself
Real men care about performance...lesser men care about cosmetic features...
950 SE -06 with 2009 SDR 130 hp motor (but carbed...120 hp?)
Balsta is offline   Reply With Quote
Old 01-01-2014, 12:23 AM   #25
DirtyADV
DirtyADV's Avatar
Oddometer: 2,372
What about this?
Found some really small cheap meter from china, glad I had to buy 4 since I broke the tabs off the first while test fitting:
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 01-01-2014, 07:57 AM   #26
charlie264
charlie264's Avatar
Oddometer: 8,372
Originally Posted by DirtyADV View Post
What about this?
/Johan
Is it waterproof, got a link?
A bit Heath Robinson, cheap voltmeter from flea bay, thinking how to make it waterproof, so I got two pieces of perspex and a load of clear silicon...left it to dry and pealed off the perspex and trimmed...not very well.
Can't read in direct sunlight but under cloud or shade its ok.....14.1V all day long. Keeps an eye on R/R.
Old 01-01-2014, 08:34 AM   #27
Hipster
Hipster's Avatar
Oddometer: 1,816
How do you display the voltage on the Zumo 450?
2008 KTM 990 Adv & 2007 KTM 640 Adv
Hipster is offline   Reply With Quote
Old 01-01-2014, 10:43 AM   #28
renogeorge
Oddometer: 1,425
http://roadstercycle.com/Motorcycle%...%20monitor.htm
If you don't care about a an actual reading and can get by with warning lihgts, this is an easy stick on option.
FWIW
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Old 01-01-2014, 10:51 AM   #29
NoVa Rider
Oddometer: 2,938
Not a KTM, but I have a Datel voltmeter on my ride, fitted inside a Radio Shack project box, with some window tint over the screen to cut the glare:
http://www.datelmeters.com/cgi-bin/w...oltmeters.html
Works well for me.
(and kudos to jimvonbaden for the slick install. . ..)
NoVa Rider screwed with this post 01-01-2014 at 02:47 PM
NoVa Rider is offline   Reply With Quote
Old 01-01-2014, 02:18 PM   #30
DirtyADV
DirtyADV's Avatar
Oddometer: 2,372
Listed as waterproof.
Here is an amazon link.
Bought mine from www.aliexpress.com and got a set of 4 for $20 shipped to Sweden, bought one of each color, lucky I did, the ears a quite fragile and damaged one during mockup.
Time will tell if it will hold up, will give it a small bead of black silicone around it.
/Johan
Times are GMT -7.   It's 03:50 PM.
