Old 01-02-2014, 05:58 AM   #31
charlie264
charlie264's Avatar
Oddometer: 8,547
Originally Posted by DirtyADV View Post
Listed as waterproof.
Here is an amazon link.
Bought mine from www.aliexpress.com and got a set of 4 for $20 shipped to Sweden, bought one of each color, lucky I did, the ears a quite fragile and damaged one during mockup.
Time will tell if it will hold up, will give it a small bead of black silicone around it.
/Johan
Cheers. I though they were flat, so you needed to cut a hole.
Old 01-02-2014, 07:15 AM   #32
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,550
Originally Posted by Hipster View Post
How do you display the voltage on the Zumo 450?
I am away from my Zumo right now, so I can't check, but IIRC you press and hold in the upper right corner of the screen. I don't remember which screen you need have showing, but I am sure you can Google exact instructions.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is offline   Reply With Quote
Old 01-02-2014, 01:52 PM   #33
DirtyADV
DirtyADV's Avatar
Oddometer: 2,420
Yes a hole is required, dremel tool and a sharp knife.
Wanted it as high as possible also so needed to trim a little on the back side also to make room for the M3 bolt, a little further down and a little more to the right and that might not have been required:
First wanted the bolt head rather then the nut on the outside but was to hard to get the nuts in place so turned it around.
Will add a small bead of black silicone around it later also.
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is online now   Reply With Quote
Old 01-02-2014, 04:32 PM   #34
charlie264
charlie264's Avatar
Oddometer: 8,547
/Johan
Old 01-03-2014, 07:31 PM   #35
RoundOz
Plenty of seasoning
Oddometer: 1,019
any small meters out there?
I would prefer a much smaller meter and preferably a backlit lcd...these are all too big and too bright for night use for me....
I have done some googling with filters like...tiny...micro...mini...
One that plugs in the lighter socket eould be very convenient, but these are all pretty big...
2009 KTM Adventure
RoundOz screwed with this post 01-04-2014 at 08:17 AM
RoundOz is offline   Reply With Quote
Old 01-04-2014, 08:45 AM   #36
gearheadE30
gearheadE30's Avatar
Oddometer: 1,008
I looked a long time for something smaller. I couldn't find anything, except for a few that had 3 LEDs: a red, yellow, and green, which doesn't really tell you a whole lot. Also, mine isn't any brighter than the stock instruments are at night, and red is low wavelength and really doesn't affect your vision much. If it were blue or something, that would be a different story.
2005.5 KTM 950 Adventure and 2012 KTM 200 XC-W
1991 BMW 318is turbo track car
1989 Chevrolet Caprice Classic Wagon sleeper tow car
1992 Subaru SVX daily
3 Months Exploring the US on a 950
gearheadE30 is offline   Reply With Quote
Old 01-04-2014, 03:17 PM   #37
DirtyADV
DirtyADV's Avatar
Oddometer: 2,420
Aouch what I installed is blue, to go with the blue S model bodywork I will have on the bike =)
Well still have a red and yellow I can change to (damaged the green during mockup).
Might add that the plastic around the headlight needed a little trimming also when installing it as high up as I did.
/Johan
Old 01-05-2014, 07:11 AM   #38
RoundOz
Plenty of seasoning
Oddometer: 1,019
After hours of searching and looking at specs...
found these from Murata:
http://www.murata-ps.com/en/news/new-products/1967
Just need a holesaw and small file to install. -25 to 60 deg C operating range, fuse protected, fair accuracy claimed and the face at least is IP67 raintight. $45 is best price I can find.
Also found some 4 digit on ebay, 30mm wide package but not weatherproof, so would need some kind of mounting solution...have thought about putting it in my tankbag (my electrical accessory distribution center) where it would only be visible (i.e., annoying at night) if I look down.
...however...I am also considering these:
http://www.veisystems.com/products/d...o-l-voltmeter/
...thanks to ktm950se on the "oil sender options" thread.
They are larger (~2") but are two gauges in one, in this case oil pressure and volts. They are dimmable and have user settable alarms...really pretty fancy...I am waiting to hear back from company as to whether they are raintight and how much the pressure sender is but depending on color (Atomic Orange anyone?) they are around $90 for the gauge.
BTW...they do have single input gauges for about $25 less and have a wide range of input options...temps, AFR etc
2009 KTM Adventure
RoundOz screwed with this post 01-05-2014 at 07:21 AM
Old 01-05-2014, 08:08 AM   #39
Hipster
Hipster's Avatar
Oddometer: 1,815
Here's another voltage display option that has an auto dimming feature http://www.motorcycle-superstore.com...-battery-gauge
2008 KTM 990 Adv & 2007 KTM 640 Adv
Hipster is offline   Reply With Quote
Old 01-05-2014, 08:15 AM   #40
RoundOz
Plenty of seasoning
Oddometer: 1,019
stop press on the VEI gauges
cincy performance has the oil sender listed for $29. And also has a VEI voltmeter that is only 1 5/8" diameter:
http://www.cincyperformancestore.com/vei-v1-vom-s.html
2009 KTM Adventure
Old 01-06-2014, 11:56 AM   #41
DirtyADV
DirtyADV's Avatar
Oddometer: 2,420
It is a bit bright might dim it down with some kind of paint or some some window tint or something:
/Johan
Old 01-06-2014, 11:59 AM   #42
charlie264
charlie264's Avatar
Oddometer: 8,547
/Johan
I went for red for that reason. Translucent or windscreen tint tape....look on the bright side, I cannot read mine in direct sun light.
Old 01-06-2014, 12:04 PM   #43
DirtyADV
DirtyADV's Avatar
Oddometer: 2,420
Have a red I can change to should I find it to annoying or mess this one up.
/Johan
Old 07-12-2014, 10:52 AM   #44
canadasax
canadasax's Avatar
Oddometer: 348
This is the new round voltmeter from datel.
Very nice
canadasax is offline   Reply With Quote
Old 11-06-2014, 02:57 AM   #45
Masa
Masa's Avatar
Oddometer: 303
Installed a Datel voltmeter and relocated the power outlet. Had to trim pieces here and there, but not too bad.
Masa is offline   Reply With Quote
Times are GMT -7.   It's 04:03 PM.
