Old 12-10-2013, 10:50 AM   #1
DELTATANGO OP
Motorcyclist and Dog Walk
DELTATANGO's Avatar
Oddometer: 13,750
Bent Wheel
The front wheel on my 950 is bent a little. I thought it was the tire but a can see it when running. It's not bad but who wants a bent wheel?
What is the best way to fix it? Get a new rim and lace it back? Where?
What kind/size, I want to stay with the 21".
DELTATANGO is offline   Reply With Quote
Old 12-10-2013, 10:51 AM   #2
gearheadE30
gearheadE30's Avatar
Oddometer: 851
I got mine back into round with a few blocks of wood and a deadblow hammer. Otherwise, time to get and excel rim or something, or have Woody's build you a rim. Seems like that's what most people go with.
2005.5 KTM 950 Adventure and 2012 KTM 200 XC-W
1991 BMW 318is turbo track car
1989 Chevrolet Caprice Classic Wagon sleeper tow car
1992 Subaru SVX daily
3 Months Exploring the US on a 950
gearheadE30 is offline   Reply With Quote
Old 12-10-2013, 10:56 AM   #3
DELTATANGO OP
DELTATANGO's Avatar
Oddometer: 13,750
Did you take it off before you beat on it?
Mine's not bent much.
Old 12-10-2013, 12:30 PM   #4
el queso
toda su base
el queso's Avatar
Oddometer: 686
Do you have a flat spot or is it out of true? If it's a truing issue it can be fixed with a spoke wrench.
el queso is offline   Reply With Quote
Old 12-10-2013, 12:35 PM   #5
PS-RagE
PS-RagE's Avatar
Oddometer: 610
When I finally changed it, my original OEM wheel looked like a Canadian nickel.
A. Dale McLean
aka PS-RagE
2007 Beta REV3 270
2012 KTM 350 EXC-F
2014 KTM 1190 Adventure R
PS-RagE is offline   Reply With Quote
Old 12-10-2013, 12:48 PM   #6
rburkat
rburkat's Avatar
Oddometer: 281
I take my wheel off and remove the tire, then i put the rime in a big ass vice and apply pressure at the bent out lip, while applying some heat with a torch.
Straightened out many dings small and large this way.
rburkat screwed with this post 12-10-2013 at 01:03 PM
rburkat is offline   Reply With Quote
Old 12-10-2013, 03:04 PM   #7
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,161
+1 works like a charm
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 12-10-2013, 03:26 PM   #8
DesertSurfer
Tail sprayin
DesertSurfer's Avatar
Oddometer: 1,369
The long and short of it...
With the earlier Behr front rim it's soft enough I was able to "message" several smaller flat spots with a 5 lg. rubber coated dumbbell, which had better close proximity impact leverage then my rubber mallet.
But at a certain point I switched out that rim for the stock SE 1.85mm DID Dirt Star. It relaced to my hub reusing the stock spokes just fine. Just an FYI.
'"This whole memory lapse is gett'in to me. Hopefully I think I'll outgrow it."
DesertSurfer is offline   Reply With Quote
Old 12-10-2013, 03:32 PM   #9
gaspipe
Wandering Soul
gaspipe's Avatar
Oddometer: 11,352
+1 - That Dirt Star SE rim is a tough SOB and works great on an ADV.
gaspipe [the original]
Hair of the dog....
gaspipe is offline   Reply With Quote
Old 12-10-2013, 06:13 PM   #10
gearheadE30
Oddometer: 851
I took it off, and the tire off too. Only takes about a half hour to strip it that far and makes it a ton easier to pound on.
Old 12-10-2013, 06:38 PM   #11
Off Road Ryder
Off Road Ryder's Avatar
Oddometer: 2,446
A stock SE wheel does wonders on the ADV. easy lace up, and pretty damn tough.
I'm not so sure about heating a wheel, if you heat Alu you will soften it up,. making it much easier to be bent again in the future.
I cant remember the last time I had a round wheel on my bike, Oh ya I do, it lasted for about an hr after I put on the Se wheel. Some things just aren't worth worrying about.
When Quality matters,Its all about choices.
Cyclops Performance LED Vendors thread
http://advrider.com/forums/showthread.php?t=839163
www.cyclopsadventuresports.com
1-800-624-0278
Off Road Ryder is online now   Reply With Quote
Old 12-10-2013, 09:14 PM   #12
BigNastybrp
Big Nasty
BigNastybrp's Avatar
Oddometer: 678
if its not bad just go ride it. It will bend more and again. check your spokes are tight. if you are only going to ride street and it bad I would change it. the more you bend them back, the weaker it will get. I would not put heat to it. that my .02
XR650 parts for sale. http://www.advrider.com/forums/showthread.php?t=1038286
BigNastybrp is offline   Reply With Quote
Old 12-10-2013, 09:23 PM   #13
DELTATANGO OP
DELTATANGO's Avatar
Oddometer: 13,750
No it's true. It's a little flat spot.
I cant' spin the wheel very well because the brakes are dragging, another thing I have to fix.:loll
Thanks.
Old 12-12-2013, 09:48 AM   #14
superpimp
Oddometer: 59
Yeah tell me about it, its my 3 rd dirtstar rim bent on my superenduro in 3 years.Next i will have have to fork out the cash and go with a woodys version.
On the pavement it feel like i got and oval wheel in front the front ends jumps.
superpimp is offline   Reply With Quote
Old 12-12-2013, 09:25 PM   #15
sven520
Oddometer: 94
After the stock one was hammered I got the 1.60 from Woody's, best money I've spent
sven520 is offline   Reply With Quote
Times are GMT -7.   It's 10:13 AM.
