Old 12-15-2013, 08:06 AM   #31
Apple Jam
Forest Flyer
Apple Jam's Avatar
Oddometer: 6,553
Originally Posted by FastEddieB View Post
Made exclusively from virgin Italian babies...
...or so I hear.
Twin babies: Johnson & Johnson
Not very Italian sounding, tho....
9 years seems like normal seal replacement time, so Mort's cylinder seems to have been well lubricated enough to keep it from wearing. So really though, plain old J&J style baby oil from a Supermarket?
I will/do replace my fluids that often also. Now that I learned the hard way a couple years ago. I just assume 2-3 months of abuse on Punkin is similar to 2-3 years of use for many.
"got no problem with keeping truly roadless areas as wild....
On the other hand, if it has been logged or mined and roads already exist,,
...then that land should be open for public use" (peterman)
Apple Jam is offline   Reply With Quote
Old 12-15-2013, 08:24 AM   #32
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,399
J&J is good if you want to impress people with the designer label, but...
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is online now   Reply With Quote
Old 12-15-2013, 08:30 AM   #33
Apple Jam
Forest Flyer
Apple Jam's Avatar
Oddometer: 6,553
If that was important, I'da bought one a these:
Old 12-15-2013, 09:04 AM   #34
FastEddieB
FastEddieB's Avatar
Oddometer: 638
Does Walgreen's count as a designer label?
FastEddieB is offline   Reply With Quote
Old 12-15-2013, 09:43 AM   #35
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,391
Plain ole vegetable cooking oil works also.
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Old 12-15-2013, 10:00 AM   #36
Dusty
Dusty's Avatar
Oddometer: 1,300
Originally Posted by Apple Jam View Post
But didn't you have a leaking/weeping Master, Mort?
You had mentioned once that you had tried the master rebuild kit, did it get the job done for you?
I've had two masters leak out the lever end. One met pavement fate before I had a chance to try and fix it, the other one got a rebuild kit that stopped leaking for all of a couple weeks. Always black goo leaking out even though I have refilled regularly with fresh red blood. I've been putting up with it leaking, since I have CJ's extender/cooler that hold lots more fluid, and fluid (even Magura Blood) is cheaper than a new Master. I've been waiting to try a different fluid until I take it all apart to clean the whole system when I get a new Master.
But it's time this Winter to buy a new master. I might go with a Magura 9.0 that some say works better (with a small switchgear mod for proper fit) or I might just buy the stock replacement at the big $ they want for it. But I don't want to put Magura blood back into it just to have black goo by next Winter again.
Seems as if there might be logic to what many have said about the mineral oils reacting with the aluminum master cylinder and making it black, while wearing the cylinder even more. It seems that is what I'm experiencing. Does the pure baby oils do this, or just the blood with it's additives? I realize my clutch lever likely gets more use/abuse than many, so maybe just that is the main issue with any fluid I use.
So my next question is for ATF users, the ones that use the clutch a LOT off-road like I do.....Is your ATF turning black after a year or two of use/abuse?
This is the only place after extensive research that will resleeve the stock master... http://www.applehydraulics.com/brakes.htm
I had my original honed somewhere, and worked fine, but that was after i put in several rebuild kits. I end up buying a new one before my hone job. The honed one worked fine, but it now sits in the parts cabinet waiting for the new one to act up.
Gefr got it right in a thread in here that it's the pivot of the push on the plunger that put a wear on the bore on one side, nature of the leaver mechanics.
After all that i now use 2.5w shock fluid for the last 3 years and it never turns grey and has uber lite lever action.
Originally Posted by d0gWateR
Vagrant, vagabond, transient, hobo, bum. But park a motorcycle next to him and PRESTO! He's an advrider!
Dusty screwed with this post 12-15-2013 at 10:11 AM
Dusty is offline   Reply With Quote
Old 12-15-2013, 02:16 PM   #37
Bowser
Oddometer: 168
Originally Posted by charlie264 View Post
Been using cheap ford ATF for year......Citroen suspension fluid is also good, I mean cheap.
When are these companies going to wake up, you cant charge 16 quid for 1/2L of clutch mineral oil and expect everyone to blindly follow...
+1 for the Citroen suspension fluid, its a high temp oil, and over here dirt cheap, I think I paid about 3 for 1.5 ltr.
Bowser is offline   Reply With Quote
Old 12-15-2013, 03:45 PM   #38
MortimerSickle
Semi-Adventurer
Oddometer: 12,399
I didn't hone my cylinder. I just wiped it out, and stuck in the kit.
So, I guess I'll see how that goes for a while, before I say that is a good idea.
G.H.W.S. 1878-1962
Times are GMT -7.   It's 09:28 PM.
