Old 12-16-2013, 10:26 PM   #16
Dustodust
Dustodust's Avatar
Oddometer: 865
this sounds a lot like like loose battery terminals
from a cloud of dust we race, through it we ride on a narrow dangerous trail, then into the dust we return faster than ever, across the finish line
04 KTM 950 S
04 KTM 525 EXC street plated
Old 12-16-2013, 10:27 PM   #17
BigNastybrp
Big Nasty
BigNastybrp's Avatar
Oddometer: 679
broken wire where the three wires come out of the sleeve for the pick up on the fork tube right under the triple clamp. cheap fix and very common. its in the HOW
XR650 parts for sale. http://www.advrider.com/forums/showthread.php?t=1038286
BigNastybrp is offline   Reply With Quote
Old 12-16-2013, 10:52 PM   #18
Pistolero OP
W. F. O.
Pistolero's Avatar
Oddometer: 709
Originally Posted by brents347 View Post
Just an observation, but I don't think you should be doing any more wiring!
I really appreciate your smart ass comment ...
The switch was on the bike when I got it, and has been for 50,000 miles..
Just an observation, but I don't think you should make any more ignorant comments.
Pistolero screwed with this post 12-16-2013 at 11:28 PM
Pistolero is offline   Reply With Quote
Old 12-16-2013, 10:57 PM   #19
Pistolero OP
W. F. O.
Pistolero's Avatar
Oddometer: 709
Thank you for your input
I'll check this out tomorrow!
I hope that's all it is.
Old 01-30-2014, 08:30 AM   #20
bikepsych
Oddometer: 162
Pistolero,
What did you find with your speedo? Mine acted weird yesterday morning on my way to work. Was all over the place, 145-0-92-40-75-2 within about 5 seconds . This went on for about 4 miles then all was well. Have been keeping an eye on it but nothing else weird.
However, it was VERY cold yesterday morning. It must have gotten down to 42 so maybe that had something to do with it.
BG
Bruce
Camarillo, CA
2011 KTM Adventure 990
2009 Harley Road Glide
2006 Buell Ulysses
bikepsych is offline   Reply With Quote
Old 01-30-2014, 11:29 AM   #21
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,161
Originally Posted by bikepsych View Post
Pistolero,
BG
It was exactly was mine was doing
I posted earlier
"Have you checked your ground wires above the water pump/ clutch cover?
Right side. Two black ground wires bolted in a vertical position directly into the engine casing. "
You can get to from standing behind the right tank. You don't need to take anything off and you can bring up a wrench in there.
Fixed it for me
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 01-31-2014, 05:49 PM   #22
Pistolero OP
W. F. O.
Pistolero's Avatar
Oddometer: 709
Problem found but not fixed...
It was not the grounds..
I inspected all of them and they were all fine.
I tested the regulator/rectifier...
18+ V with the high beam on @ 5k RPM
This explains why the.. sensitive sensors.. were acting up with relation to RPM.
also explains why my headlight blew when I reved it to 5k ....
I ordered, and have since received, all the parts needed to do the MOSFET R/R conversion... but...
The semester started shortly after I ordered the parts..
Alas, engineering school is difficult at times ....
So she sits.. dismantled.. and awaiting my return...
Times are GMT -7.   It's 11:46 AM.
