Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 12-15-2013, 02:42 AM   #1
Jensdccom OP
Oddometer: 59
Scottoiler/Tutoro oiler on a 1190 ADV
Has anyone installed an oiler on their adventurer?
I just started to read some reviews and it looks promising. With my old bike I did always make a big mess of the chain oiling procedure.
I would like to make it easier for myself and install an automatic oiler.
Any tips, reviews,... ?
Jensdccom is offline   Reply With Quote
Old 12-15-2013, 03:10 AM   #2
mousitsas
mousitsas's Avatar
Oddometer: 2,992
It has to have electronic management with ambient temperature sensor to adjust flow, otherwise pretty messy if you ride across a broad range of temperatures.
mousitsas is online now   Reply With Quote
Old 12-15-2013, 03:53 AM   #3
6732cash
6732cash's Avatar
Oddometer: 163
I fitted the Tutoro nice and easy to fit no wiring or vacuum problems started off with the twin oilier which soon got eaten by the chain so fitted the single which seems adequate.... the capacity is small... I have it on a very low setting and give the chain a blast with aerosol lube from time to time
6732cash is offline   Reply With Quote
Old 12-15-2013, 04:41 AM   #4
GrenDesb
Oddometer: 331
Had a Scottoiler on my previous 950.
It's been pretty much useless for anything else than asphalt rides.
Either too low of a setting to wash of the grit or too high and it's always empty.
GrenDesb is offline   Reply With Quote
Old 12-15-2013, 06:55 AM   #5
mitch96
Oddometer: 138
HI,
I had a turturo on my 650 wee. Kinda sorta worked, but not in the dirt. Got torn up like the other poster said.. I did the dual to single also. Got torn up…
The other problem is if you set it up for fast highway it's not enough for slow dirt and visa versa. I also sprayed on occasion, like after rain…
Would not buy again…
ymmv
mitch
I'm doing so good, I can't stand it!!
mitch96 is offline   Reply With Quote
Old 12-15-2013, 07:39 AM   #6
DELTATANGO
Motorcyclist and Dog Walk
DELTATANGO's Avatar
Oddometer: 13,934
Someone should make one with a manual button that you push.
DELTATANGO is offline   Reply With Quote
Old 12-17-2013, 07:19 PM   #7
paturoa
paturoa's Avatar
Oddometer: 270
I installed a Tutoro on my R and threaded the tube through the hole in the middle of the swing arm. It took me less than an hour for the whole thing including working out how to fit it.
Will take some photos and attach to this post later.
paturoa is offline   Reply With Quote
Old 12-18-2013, 12:58 AM   #8
Tafella
Tafella's Avatar
Oddometer: 126
Check out the OSCO
www.osco-chainoiler.com/en/‎
can be filled with cheap chainsaw oil also!
CARPE DIEM, But not without my KTM !
KTM Adv. 990R '10
KTM Enduro 690R '14
www.lc8.nl
Tafella is offline   Reply With Quote
Old 12-18-2013, 01:30 AM   #9
Jensdccom OP
Oddometer: 59
Please do :)
Old 12-18-2013, 03:33 AM   #10
Stromcat
Stromcat's Avatar
Oddometer: 38
Had a Scottoiler fitted to my 1190 by the dealer before I picked the bike up.He did a nice neat job.1300 miles so far,so good.Had one on a previous bike from new,a Vstrom 1000,which did 24000 miles on the original chain and sprockets before I swapped the bike.I reckon it would have done at least 30000.
Stromcat is offline   Reply With Quote
Old 12-18-2013, 03:49 AM   #11
Womble_CH
dribbling baboon
Womble_CH's Avatar
Oddometer: 345
I have a Tutoro in a box at home, waiting with a few other items for the x-mas holidays to get attached. I had a Scotty on my late Varadero for 10 years and never changed the chain kit. But that was a carburetor bike and I didn't want to play around with the KTM hoses so I chose the Tutoro.
Womble_CH is offline   Reply With Quote
Old 12-18-2013, 04:40 AM   #12
AJAdvRider
Oddometer: 30
Hello All
I am new to the forum and bikes with chains...belts and shafts yes but only a Schwinn with a chain. Waiting on my 1190 (latest is 2nd week of January). My apologies if this should be asked in a new thread but how critical is chain lubrication? Appreciate any input as some friends have told me that they just spray a little WD when the chain starts to look a little rusty and that's it.
Thanks much
AJ
AJAdvRider is offline   Reply With Quote
Old 12-18-2013, 05:55 AM   #13
Womble_CH
dribbling baboon
Womble_CH's Avatar
Oddometer: 345
Originally Posted by AJAdvRider View Post
Hello All
Thanks much
AJ
I would estimate a normal lifespan of a chain / Sprocket to roughly 20000 miles/30000 kms. Do little maintenance or none (like your friends) and you may reach half that distance. Do regular cleaning and greasing or use a oiler and you can double it or more. A Chain kit is abt 250$ + workmanship so up to you how often you want to have that added on your service bill.
Old 12-18-2013, 05:57 AM   #14
steveWFL
steveWFL's Avatar
Oddometer: 1,404
You could install a BMW shaft. You'll only gain 20-30 pounds, lose HP efficiency to the rear wheel, and replace splines
KTM EXC - in 530 flavor
'10 Concours14 with >85,000 miles and ticking'
'99 ZX9R Ninja - rolling retro style
'99 ZX9R - because I like the other one so much
'08 ZZR600 minty
steveWFL is offline   Reply With Quote
Old 12-18-2013, 03:30 PM   #15
paturoa
paturoa's Avatar
Oddometer: 270
Originally Posted by Jensdccom View Post
Please do :)
Mounted the tank on the rhs so that it doesn't get too hot (was in the instructions). It is out of the way and easy to fill there too.
Hard to see in the pic, but the tube tucks nicely behind the brake and subframe where it can't get hooked.
Next pic is from the lhs where I threaded it through the hole in the swing arm and only used one of the little stick-on things. There is no sign of wear on the tube from vibrations that I can see so far.
Back along the top of the swing arm, again where it is less likely to get hooked by shrubs etc. I took off the chain cover and threaded it under that. It then loops back and the single outlet touches the sprocket on the inside of the lip of the sprocket itself. In this position there is very little flick onto other parts of the bike and none onto the tyre wall either.
The tube / outlet sits nicely under the rear part of the chain guard mount and can slide forwards or backwards easily as the chain is adjusted or sprockets changed. It moves easily also to remove the rear wheel.
I also use castrol chain saw bar oil. It sticks well and doesn't flick. It is also a fraction of the price of branded auto oiler oil in a 4 litre container.
paturoa screwed with this post 12-19-2013 at 10:14 AM
Times are GMT -7.   It's 04:17 PM.
