Old 02-22-2014, 07:33 AM   #136
COXR650L OP
Oddometer: 1,544
Originally Posted by charlie264 View Post
Can you see a small dot on the top ring? The dot faces up. Normally the top ring has the \| wall. and the second ring /| wall if that makes sense. Did the rings not come with a diagram?
No, they are just the OEM rings in individual packages and not a single mark or anything on the top ring.
The middle ring has the words "top" stamped into it, which position the shoulder down.
Ill check the other new ring, maybe they forgot to mark it
Ben
COXR650L is offline   Reply With Quote
Old 02-22-2014, 07:37 AM   #137
charlie264
charlie264's Avatar
Oddometer: 8,401
Ben
OK, Sounds like the ring with the mark is the top compression ring. Need to get this right.
Old 02-22-2014, 07:48 AM   #138
COXR650L OP
Oddometer: 1,544
I just double checked the part numbers and I for sure have the rings in the correct places. Also the other piston still has the old rings on from when I took it apart and the middle ring definitely has the shoulder facing down. Unfortunately I took the top ring off to check the end gap so I cant reference its orientation.
Old 02-22-2014, 08:05 AM   #139
charlie264
charlie264's Avatar
Oddometer: 8,401
Are we talking inner or outer shoulder or chamfer? If outer and its marked top.....edit..that's right then...I'm getting confused.
charlie264 screwed with this post 02-22-2014 at 08:29 AM
Old 02-22-2014, 09:11 AM   #140
COXR650L OP
Oddometer: 1,544
Hey Charlie, both shoulders are on the outside of the rings and are 90 square edges. The middle is a recessed 90 shoulder and the top ring has a protruding 90 deg shoulder. Similar to the picture. I cant see any taper on the inside.
What do you think?
Old 02-22-2014, 09:16 AM   #141
COXR650L OP
Oddometer: 1,544
Also I just figured out where the washer goes from Pydons earlier post.......it is actually part of the split inner race on the right side balancer shaft bearing.
Whew....
Old 02-22-2014, 09:31 AM   #142
charlie264
charlie264's Avatar
Oddometer: 8,401
What do you think?
Second ring is correct. Top ring, never seen one that shape, piston recess must be the same . Sorry mate...don't know. Someone here will. Peanuts?
charlie264 screwed with this post 02-22-2014 at 09:37 AM
Old 02-22-2014, 09:38 AM   #143
charlie264
charlie264's Avatar
Oddometer: 8,401
Whew....
Old 02-22-2014, 10:18 AM   #144
DirtyADV
DirtyADV's Avatar
Oddometer: 2,375
From manual regarding piston rings:
Assembly instructions for piston rings
– Mount the oil scraper ring in the lower piston ring groove with the mark facing the piston head.
– Mount the compression ring in the middle piston ring groove with the mark facing the piston head.
– Mount the compression ring in the upper piston ring groove with the mark facing the piston head.
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 02-22-2014, 10:27 AM   #145
COXR650L OP
Oddometer: 1,544
The other two are marked but there is no "mark" that I can see at least on the compression ring
Old 02-22-2014, 11:08 AM   #146
Peanuts
Peanuts's Avatar
Oddometer: 1,703
The piston has a shallow groove for the L part of the ring just above the normal ring groove.
Maybe look closer at the piston?
Oil ring has an O on it, that goes towards the top of the piston, middle ring says TOP on it, L shaped top ring has no marking.
Peanuts is offline   Reply With Quote
Old 02-22-2014, 11:12 AM   #147
Peanuts
Peanuts's Avatar
Oddometer: 1,703
Whew....
The clue is in the engraving on the "washer" just like a bearing is engraved.
Old 02-22-2014, 07:01 PM   #148
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 5,273
I just rebuilt mine and all marks, be letters or an "o" were to face upward. The top ring can only go in one way. A used ring may have the "o" rubbed away.
I just broke mine in today, made 505 miles to Nashville, 500 more tomorrow. Looks like I didn't get the lower headset (steering) bearing in tight enough, the triple tree was loose by the time I got here from the pounding. Took some creativity to tighten it since I didn't bring a 32(?)mm open end with me, luckily I had a tiedown.
Michael
AES Racing - Crow Canyon Riding Park
mgorman is offline   Reply With Quote
Old 02-22-2014, 07:15 PM   #149
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,154
I've always used the larger of the two box end wrenches in the toolkit, I think it fits the countershaft nut. Put it over the steering stem nut, then shim the extra space with the smaller of those two wrenches. Fits well enough. And wedge open the fork leg clamps on the upper triple, as I'm sure you know. . . .
Zak
ktm
old bmw
others
slackmeyer is online now   Reply With Quote
Old 02-22-2014, 07:59 PM   #150
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 5,273
The idiot who owns the bike left that box wrench on the work bench so it didn't get lost I'm firing him when I get home
Michael
Times are GMT -7.   It's 09:28 PM.
