Old 02-17-2014, 06:40 AM   #121
COXR650L OP
Oddometer: 1,495
Originally Posted by StevenD View Post
Correct, points to exhaust. Also visible by the size of the valve indents on most pistons.
Verstuurd vanaf mijn LG-D802 met Tapatalk
Thanks !!
Got the case halfs back together last night. It was kind of a bugger getting the counter shaft through the seal. I hope I did not mess up the seal I put electrical tape around the splines, but I see KTM has a special cap, similar to a fork bullet, to protect the seal.
Anyone had problems with the countershaft seal after splitting the cases?
COXR650L is offline   Reply With Quote
Old 02-17-2014, 07:59 AM   #122
DELTATANGO
Motorcyclist and Dog Walk
DELTATANGO's Avatar
Oddometer: 13,834
Originally Posted by COXR650L View Post
Thanks !!
I bet it's fine. Rubber is resilient, as long as you didn't cut it or stretch it too much.
DELTATANGO is offline   Reply With Quote
Old 02-17-2014, 08:24 PM   #123
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 5,207
Good luck with the rest of the build. I finished mine up a couple days ago and did a short test ride, everything seems ok so I am taking it on a 6,000 mile test ride this Saturday.
Michael
AES Racing - Crow Canyon Riding Park
mgorman is offline   Reply With Quote
Old 02-17-2014, 08:29 PM   #124
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,074
Sounds like a long day.
Zak
ktm
old bmw
others
slackmeyer is offline   Reply With Quote
Old 02-18-2014, 06:36 AM   #125
COXR650L OP
Oddometer: 1,495
Good for you!!
Well I guess I will be re-splitting the cases. I cannot get it to shift gears, so I must have got something put in the wrong way.....
Old 02-18-2014, 12:31 PM   #126
charlie264
charlie264's Avatar
Oddometer: 8,273
Good for you!!
Check the shift mechanism is pushed all the way home and the spring roller leaver thing is properly located...
Old 02-18-2014, 08:09 PM   #127
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 5,207
Thanks, should be an interesting ride, heading to Pahrump, Nv to the ALtrider Dakar ride with Jimmy Lewis. It's in the 20's F here and a foot of snow, supposed to be in the 40's when we leave.
I saw that happened on here somewhere and when I was putting mine back together, I made sure I checked that.
Michael
Old 02-22-2014, 06:53 AM   #128
COXR650L OP
Oddometer: 1,495
Ok cases are all back together and going smooth till the inevitable......I have an extra part
This washer was in the bag of clutch stuff and it only seems to fit the transmission main shaft, but I dont see where it is supposed to go, nor find it on the laserfich.
It is a hardened washer and seems to fit perfect on the trans main shaft, it has marking NTN 204E/220.
The large washer for the clutch basket collar has a perfect mark that is the same size as this washer, but it does not seem right......
Any help or ideas??
Old 02-22-2014, 07:43 AM   #129
charlie264
charlie264's Avatar
Oddometer: 8,273
Did you disassemble the main shaft? What's the dimensions?
Old 02-22-2014, 07:53 AM   #130
COXR650L OP
Oddometer: 1,495
No, and it will only fit over the threaded portion of the main shaft, not the splines.
Dimensions:
29.5x22.2x2.45
Its hard to see in the picture, but the inside radius of the washer is tapered on the numbered side at about a 45 deg angle, but not the other side.
Thanks for the help
Also, I am now installing the piston rings and the manuel says to install with the "mark" facing the piston head. The oil ring has a mark on it and the middle ring say "top" so that is pretty clear, however the top ring has no marks. Is the top ring installed with the shoulder face of the ring up or down?
COXR650L screwed with this post 02-22-2014 at 08:00 AM
Old 02-22-2014, 08:06 AM   #131
charlie264
charlie264's Avatar
Oddometer: 8,273
Dimensions:
29.5x22.2x2.45
Thanks for the help
You always go internal first for search reference. I can't find nothing that size in the manual. 22.2 x 30.2 x 1.5 only on the main shaft. The spacer behind the roller bearing has splines...and the other washer is for the nut on the clutch booster.
Old 02-22-2014, 08:10 AM   #132
COXR650L OP
Oddometer: 1,495
Hummmm, I wonder where it came from. I have been looking at parts diagrams and I can find anything that looks similar
Old 02-22-2014, 08:16 AM   #133
charlie264
charlie264's Avatar
Oddometer: 8,273
Does the top ring ends butt up flat? Normaly the shoulder slanting down on the top ring and up on the second.....
Old 02-22-2014, 08:22 AM   #134
COXR650L OP
Oddometer: 1,495
I's assuming the shoulder has to point down on the compression ring. However on the middle ring if installed per the manuel and based on how the old piston ring is installed (top one has been removed to check end gap) the middle ring has the shoulder facing down as well.
Do you think both rings should have the shoulder facing down?
Old 02-22-2014, 08:30 AM   #135
charlie264
charlie264's Avatar
Oddometer: 8,273
Can you see a small dot on the top ring? The dot faces up. Normally the top ring has the \| < piston. and the second ring /| < piston if that makes sense. Did the rings not come with a diagram? .
charlie264 screwed with this post 02-22-2014 at 09:24 AM
Times are GMT -7.   It's 05:17 AM.
