Old 12-16-2013, 09:24 PM   #1
NortwestRider OP
TRIPOD ADVENTURER !!
NortwestRider's Avatar
Oddometer: 3,957
2600 replacement ??.
I have been using a 2600 for several years and the screen is finally delaminating.
I need to replace it and was wondering what a good option would be.Here is what I want to do with a GPS.
1..Be able to load tracks like BDR maps.
2..Be able to chart my own path to find my way back out.
3..Be under $300.
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
GS500ADV..THE PURPLE EXPLORE
[B
NortwestRider is offline   Reply With Quote
Old 12-16-2013, 09:52 PM   #2
Canuman
Crusty & Unobliging
Canuman's Avatar
Oddometer: 4,634
Sounds like you want the GPSmap 78. Although the screen is small, it's very durable, extremely waterproof, does tracks and routes nicely, handles a lot of different map formats, including many of the open-source formats, and most importantly, does not rely on a stupid micro USB for external power. It has a proper four-prong external charging plug that will not fail after a month. Even on batteries, it gets about 12-16 hours out of a set of alkalines.
Best of all, it's under $200. The big disadvantage is that it uses a patch antenna, which may become an issue if you do a lot of riding in the Arctic, but it does feature an external antenna port, so if you're riding in fringe areas, you can connect a helical antenna. It's also easy to use with gloved hands.
The Rock 2013 RR
http://advrider.com/forums/showthread.php?t=915172
Dual Sport Luggage Racks: http://www.moto-racks.com
hONORARY mEMBER fIRST aMERICAN cHAPTER tEAM nONGA (pROVISIONAL wING)
Canuman is offline   Reply With Quote
Old 12-16-2013, 10:46 PM   #3
NortwestRider OP
Oddometer: 3,957
Yup , sounds like what I need. !!.
What's a patch antena. !?.
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
[B
Old 12-16-2013, 11:17 PM   #4
Canuman
Crusty & Unobliging
Canuman's Avatar
Oddometer: 4,634
There are several flavors of GPS antennas. The best is a helical antenna -- which will pick up signal wherever signal is to be found. I've got a General Dynamics "spookbook" laptop with GPS that was designed for military vehicle mounting with a built-in helical antenna. It will obtain a fix within seconds sitting in my basement, and get eight or more satellites in those conditions. But that's military hardware. . . not easy to find, and not the thing to mount on your dash.
A patch antenna is a little simpler, and is not as powerful in fringe areas. The 78 is designed for marine use. These units work best mounted at between 45 degrees of flat or nearly flat. I've never had a problem getting signal on the bike with mine in reasonable conditions. If I was going up to the Arctic, I guess I'd invest in an external antenna, which Garmin offers for a fairly reasonable price. There are ports for an external on the 78.
For most of us, the patch antenna will work fine. The big issue with most of the available units is that the micro USB port is total crap for charging. USB is simply too fragile for reliable motorcycle use. The 78 has the very reliable four-pin plug that was such a feature on the Garmin 60 series.
Trust this helps.
The Rock 2013 RR
Canuman screwed with this post 12-17-2013 at 05:04 PM
Old 12-17-2013, 07:08 AM   #5
NortwestRider OP
Oddometer: 3,957
This all helps.
Thanks guys !!.
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
[B
HTML code is Off
Times are GMT -7.   It's 01:06 AM.
