Old 07-18-2014, 03:19 PM   #31
bobfab
bobfab's Avatar
Oddometer: 1,414
awesome!
CRF250L | KTM200SX
bobfab is offline   Reply With Quote
Old 07-18-2014, 03:29 PM   #32
J Banning OP
J Banning's Avatar
Oddometer: 154
Thank you
Current rides: '04 CR500 AF supermoto, '10 KTM 300 XC-W, '02 XR100 minimoto, '09 GSX-R 600 track, '07 VFR800
Past rides: '77 Goldwing GL1000, '86 Z50R, '86 LT250R, '86 TRX250X, '90 XR600R, '92 KX250, '98 ZX-7R, '99 TM125, '99 CR500AF, '99 TM 125MX, '01 GS500E, '04 KTM 525 SMR, '05 KTM 625 SMC, '06 KTM 250 XC-W
J Banning is offline   Reply With Quote
Old 07-19-2014, 12:15 AM   #33
pdxjim
Two Stroke Terror
Oddometer: 152
Rad,
I've been having a blast on my street titled supermoto 300exc.
Those extra 200cc's must be a hoot.
pdxjim is offline   Reply With Quote
Old 10-19-2014, 10:11 PM   #34
Fast1
Twisted Throttle
Fast1's Avatar
Oddometer: 1,884
dream bike!
What kinda of range do you get with the 500 during street us?
14 Husqvarna FE 501 10 Yamaha FJR 1300 11 Husqvarna SM630
Fast1 is offline   Reply With Quote
Old 10-20-2014, 01:33 PM   #35
J Banning OP
J Banning's Avatar
Oddometer: 154
That depends on how it's being ridden, but it's not good either way.
30 mpg if I'm riding the speed limit and no hooning. 25 mpg or less if I'm getting on it.
The stock tank is small to begin with -- 1.9 gallons -- plus it has no reserve, and I probably lost an 1/8th of a gallon of capacity pushing the bottom of the tank in to clear the spark plug and coolant lines. With all that being said I'd say that there's really only 1.25 gallons of usable fuel in the tank. If I'm street riding I carry oil with me (in a translucent Stabil container with markings) and I aim to stop for fuel every 30 miles. If I'm at the track I top off after every session.
Companies like IMS or Clarke make larger tanks, but that larger capacity comes in the sides and bottom of the tank. I assume that I'd have to do a LOT of reforming of the tank to *possibly* make it work. I have no plans to do that.
J Banning screwed with this post 10-20-2014 at 01:45 PM
Old 10-27-2014, 09:15 AM   #36
BikePilot
BikePilot's Avatar
Oddometer: 11,251
Nice project! CR5s broke pistons a lot in stock form. All three of the ones in my family years ago broke or cracked pistons. For light dirt work a forged wiseco fixed it. I think the root cause was Honda's poor head design--you may have fixed that with the cool head. Awesome to see the bike running!
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, KX100, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 10-30-2014, 10:11 AM   #37
jar944
jar944's Avatar
Oddometer: 670
I have a cracked wiseco here that proves otherwise.
Running the piston too long or with too much clearance kills the pistons. The head design isn't that bad.
jar944 is offline   Reply With Quote
Old 11-03-2014, 05:16 PM   #38
Norty01
RIDERCOACH
Oddometer: 246
Impressive work. Cutting and rewelding a frame takes skill and courage. You appear to have both.
Just how "streetable" is a modded CR 500 engine?
Lastly, what's it's wet weight?
Norty01 is offline   Reply With Quote
Old 12-15-2014, 03:58 PM   #39
J Banning OP
J Banning's Avatar
Oddometer: 154
Thanks for the compliments.
Regarding how streetable it is, I guess everyone has a different idea what that means. What I can tell you is that it will easily cruise at 70 mph without a problem. At WOT it'll do between 115-117 mph. However, the thin MX seat and no wind protection make extended periods on the bike tough... plus the small stock gas tank (about 1.6 gal) and having to mix fuel make fuel stops a pain in the ass. There's no reserve and if I'm hauling ass with the bike I'll only get about 25 mpg, meaning I'll want to be dam close to a gas station when the odometer hits 30. Because I ride it hard I mix my fuel/oil at 32:1, so for a full day on the bike I gotta bring a lot of oil in my backpack. I've found that a 64oz Gatorade bottle helps too, so I can always top off the gas tank. Carrying all that stuff sucks though. A different carb (Smartcarb or Pulse Injected Air Striker) could help the fuel mileage, as could a larger tank, but the larger tank usually comes at the expense of less space around the top of the motor... so I'm sure that would mean a lot of heating and reshaping to make it fit, *if* it'll fit.
With all that being said, this bike isn't as streetable as I had hoped for. It's kinda like meeting up with all your Mustang driving buddies for a Sunday drive and you're driving a track prepped Corvette with a small fuel cell. It's loud, not very comfortable, and gets shitty gas mileage... but damn, is it a rush to drive!
With that being said, I'll be keeping this bike for track days and short hooligan rides, but I'm looking for a used DR-Z400SM as a cheap & reliable "daily supermoto" (i.e.: my Mustang) for gravel roads and and longer day rides.
J Banning screwed with this post 12-15-2014 at 04:06 PM
Old 12-16-2014, 11:17 AM   #40
Fast1
Twisted Throttle
Fast1's Avatar
Oddometer: 1,884
Just toss it on a trailer and head for a week of riding in the dunes of Glamis and you will realize that it is "king" of all bikes (which you most likely know) in that environment.
I believe there is an oversized tank available but it does impede access to the plug and most likely will require some heat/shaping to fit according to Service Honda.
Old 12-16-2014, 05:19 PM   #41
jar944
jar944's Avatar
Oddometer: 670
Banning, you could always drop in in a KTM roller. Easy carb access (you can pull the slide without rotating the carb) and change all jets with a factory 2.5g tank installed. Up to 3.2 gallon tank without interference.
Still sucks as a commuter though.
Old 12-24-2014, 12:02 AM   #42
tacky1
Oddometer: 2
Hats off to you, this is a great build, I am in the middle of something similar, What jetting and needle did you end up using.
Im at a loss for jetting on my 41mm PWK, I'm running a CPI pipe.. Any help would be great, :)
tacky1 is offline   Reply With Quote
Old 12-24-2014, 08:42 AM   #43
J Banning OP
J Banning's Avatar
Oddometer: 154
Yeah, that's a good idea. I've been a KTM guy for a while now (525SMR, 625SMC, 250XWC, 300XCW) and if I were to do the project again I'd give it very serious consideration. Also, with the steel KTM frame I would have been able to do 100% of the welding with my Lincoln Mig.
Old 12-24-2014, 09:31 AM   #44
J Banning OP
J Banning's Avatar
Oddometer: 154
Thank you Tacky.
Regarding jetting, what I have isn't perfect but it works and is safe. I feel it might be a bit rich on top and it "blubbers" at part throttle in turns. Not sure yet if I can tune that part throttle issue out by changing the slide, or just the needle diameter or taper, but plan to work on that in the Spring. Might try finding a competent 2-stroke dyno tuner too.
Street: (something like Tail of the Dragon)
- 48 pilot
- 190 main
- DEJ needle, clip in #2 or #3 spot with temps between 75-85*.
Track: (road race track, 90+ mph)
- 50 pilot
- 190 main
- DEG needle, clip in #2 or #3 spot with temps between 75-85*
Old 12-24-2014, 04:03 PM   #45
tacky1
Oddometer: 2
Originally Posted by J Banning View Post
Thank you Tacky.
- 48 pilot
- 190 main
- 50 pilot
- 190 main
Thanks a million for this, I was really stuck with which needle and piliot etc to go with, Glad I found this thread, My PWK has a 175, 45 and a CEL needle, I'm still at the build stage, Just finished welding the frame, Motor is still in boxes,
I can throw a Pic on here if that's ok with you, Dont want to thread crap on ya :)
Times are GMT -7.   It's 11:28 PM.
