Old 12-18-2013, 08:17 AM   #1
mountainguy OP
Oddometer: 529
Trail Bike Recommendation Needed
I'm planning to buy a 400-450 size trail bike for some overnight mountain riding. Older guy. I weigh 230 and would be packing some gear. 30" inseam. I would like to spend no more than $5000. Please recommend a good choice that would fit these needs.
Should have said before. I am in Colorado.
mountainguy screwed with this post 12-18-2013 at 12:26 PM
mountainguy is offline   Reply With Quote
Old 12-18-2013, 11:33 AM   #2
onewoodsrider
Oddometer: 172
Yamaha wr450 sounds like a bike that will fit your needs. Regardless of what you buy the suspension is going to need some work for your weight and what you plan on packing on it for a weekend.
onewoodsrider is offline   Reply With Quote
Old 12-18-2013, 11:46 AM   #3
smitty141
smitty141's Avatar
Oddometer: 623
KTM 400-450-525-530 EXC, easy to plate. Easy to jump on the road and ride extended road mile to tie trails together. I have done 50-60 miles at 70mph on my 400 EXC.
Perfect off road, dual-sport, trail bike.
Smitty
RIP.. Skinny Dave...RIP.. Chester
2011 Prudoe bay, Dalton Hwy. 2014 Inuvik, NWT Dempster
2013 Yamaha FJR 1300..2010 BMW 800GS..
1999 Yamaha YZ250.. 2008 Suzuki DRZ400SM
smitty141 is offline   Reply With Quote
Old 12-18-2013, 12:03 PM   #4
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,804
OP did not state his state, so I didn't make the same suggestions.
If he's in CA, it's NOT easy to plate within his budget. He'd need on '07+ or previously plated bike.
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Old 12-18-2013, 01:31 PM   #5
Zuber
Zoob
Zuber's Avatar
Oddometer: 1,987
30" inseam means all those bikes are out the window, unless you spend $500 lowering them.
It's more to the street side and heavier (350 lbs) but the DR650 is hard to beat. You can touch the ground, reliable, cheap, lots of accessories. It needs a bigger tank and a good luggage rack, then you can tour the world.
"Son, you can't do both"
Zuber is online now   Reply With Quote
Old 12-18-2013, 01:54 PM   #6
el queso
toda su base
el queso's Avatar
Oddometer: 689
It's not real new or sexy, but a Honda XR 400 might be a good choice. If you want something newer, a CRF 450X.
el queso is offline   Reply With Quote
Old 12-18-2013, 02:00 PM   #7
akarob
Green Cantern
akarob's Avatar
Oddometer: 7,720
KTM 500exc.
akarob is offline   Reply With Quote
Old 12-18-2013, 02:38 PM   #8
Shunka
Supervision Required
Shunka's Avatar
Oddometer: 3,957
Not really. I have a 30' inseam and ride a 08 530EXC. Is it a little tall? Sure, but not unmanageably so and only in a few situations. 99% of the time it isn't a problem.
Shunka is offline   Reply With Quote
Old 12-18-2013, 06:45 PM   #9
Zuber
Zoob
Zuber's Avatar
Oddometer: 1,987
I have a 37" inseam, so I don't see how you walk around with those things.
Old 12-28-2013, 08:45 AM   #10
BikePilot
BikePilot's Avatar
Oddometer: 11,251
I wouldn't sweat it too much, most anything you could end up with will do the job just dandy. Focus on getting something clean and reliable and have fun!
I've trail ridden in colorado, including some pretty long day trips (always went back to the truck or cabin at night so far) on a CR250R (with a big tank and toted extra fuel), XR650R (great option really, bomb proof tank of a bike and not actually that heavy, power similar to a modern 450 but harder to kill and more grunt off the bottom).
In colorado I like to have something that's pretty grunty or fuel injected, otherwise once you go up or down a mountain things get boggy. Bikes I'd look at:
Bike/Pros/Cons
XR650R: Bulletproof, massive grunt at all RPMs, very simple, so much grunt and generally uncaring motor that it runs great even if carb settings are not perfect, insanely easy to start for a kick start big bore thumper; carb, not street legal without a conversion, a bit dated, 5spd gearbox
XR400R: Also pretty bulletproof, grunty off the bottom, very manageable. carb, not street legal without a conversion, a bit dated, 5spd gearbox, sorta flexy for high speed hammering, a bit inconstant starting--overal harder starting than the 650R as weird as that is.
DRZ400S: Pretty durable, factory street legal, very smooth, slim feel; not a lot of power, heavy, carb'd and get boggy if jetting is off (which it will be for at least part of your ride)
KTM RFS dual sport: Light, great performance, factory street legal; pain to work on, picky about maintenance, don't like to be pushed really hard.
70 degree 'berg: sorta the ultimate RFS--steers better, seems more durable, fuel injected. Very smooth and easy to ride. Probably my top pick. Downsides are that there are a few weird things that need sorted to make the fuel injection totally reliable and the ultra-trick and near-mandatory "70 degree" tanks are now out of production.
WR450F, KLX450F, CRF450F: All awesome performance, all need lots of modding to be street legal and never will be all that great on the street.
TE610: Very reliable, smooth, 6spd gearbox. Sort of like a more polite, smooth, factory street legal XR650R. Would be very high on my list. Just a bit heavy and long-feeling for gnarly, technical off road. Probably the simplest, most practical option.
Something like this is 530 is very commonly available and would do just dandy
http://denver.craigslist.org/mcy/4223013539.html
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, KX100, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot screwed with this post 12-28-2013 at 08:52 AM
BikePilot is offline   Reply With Quote
Old 12-29-2013, 10:06 AM   #11
Shooter1
Shooter1's Avatar
Oddometer: 466
[QUOTE=BikePilot;23080964]I wouldn't sweat it too much, most anything you could end up with will do the job just dandy. Focus on getting something clean and reliable and have fun!
KTM RFS dual sport: Light, great performance, factory street legal; pain to work on, picky about maintenance, don't like to be pushed really hard. <--- ????, Please elaborate....
-Harvey
#1017
'00 FXDX SG Sport, '06 300XCW,
'07 EXC450, '01 640 Lc4E
Shooter1 is offline   Reply With Quote
Old 12-29-2013, 10:22 AM   #12
refokus
Just Learning
refokus's Avatar
Oddometer: 2,432
I have a 30" inseam as well, ride a KTM450 with no problems. You don't have to be 6ft tall to ride the KTM's but it would help.
"Single Trac is like Scotch, you have to aquire a taste for it!"
refokus is offline   Reply With Quote
Old 12-29-2013, 10:23 AM   #13
refokus
Just Learning
refokus's Avatar
Oddometer: 2,432
Old 12-29-2013, 12:54 PM   #14
LittleRedToyota
Yinzer
LittleRedToyota's Avatar
Oddometer: 2,232
Smitty
+ 1.
i have a plated 450 xc-w (pretty much the same as an exc). it's an awesome trail bike. and i've done multi-hundred mile road trips on it as well. i actually prefer it over my DRZ for that because of the wide ratio 6-speed.
weighing only 250 lbs (dry) is really nice on long days on technical trails.
it's a great bike for what the OP describes.
LittleRedToyota is offline   Reply With Quote
Old 12-29-2013, 04:26 PM   #15
F250Pal
F250Pal's Avatar
Oddometer: 272
I have a plated WR450F and love it.
I have a XR650L and love it, for different reasons.
F250Pal is offline   Reply With Quote
Times are GMT -7.   It's 11:54 PM.
