Old 12-03-2014, 01:01 PM   #1
Mr. Carts OP
Oddometer: 394
1982 CR480 Lighting coil.
I am looking at a 1982 Cr480 engine for a right side drive frame I have.
I have been looking for a KTM 495 engine but have not been able to find one.
I am looking to see if anyone has done light setup for this engine.
Called Rick Stator but they did not have one.
Any suggestions.
Mr. Carts is offline   Reply With Quote
Old 12-04-2014, 10:55 AM   #2
chaddhamilton
Just the tip
chaddhamilton's Avatar
Oddometer: 246
I have a cr480 going through a resto and I looked for a lighting coil a while back with no luck. :(
Chadd
chaddhamilton is offline   Reply With Quote
Old 12-05-2014, 08:53 AM   #3
Mr. Carts OP
Oddometer: 394
I have had no luck on finding one.
I will just continue looking for a KTM495 engine.
Old 12-12-2014, 12:12 AM   #4
ereksonj
ereksonj's Avatar
Oddometer: 6
I've searched as well with no results. Although I did find some pretty sweet lithium batteries that would fit in my airbox and power a headlight for an hour or two... I have fantasies of making my 480 a pretty sweet retro supermoto
ereksonj is offline   Reply With Quote
Old 12-27-2014, 05:12 PM   #5
LWC3077
Oddometer: 27
Do a search for 'E-line external stator' or 'Baja Designs external stator'
They are NLA, well at least from those places but the parts to DIY are available. The coils and rotor used by E-line/baja Designs are actually Ducati parts
http://www.electrexworld.co.uk/acatalog/RO93.html
and
http://www.electrexworld.co.uk/acatalog/G93.html
you may also find them on ebay and maybe www.hpi.be
you will need to fabricate a new stator cover/housing to hold the coils and also an extened nut for the rotor. Do a google image search to get an idea of what you need to make. Example
http://www.southbayriders.com/forums...125282/page-12
These set up will give something in the region of 150-200w from memory. They sold these kits for CR500's back 10 or so years ago. You retain your your stock stator/ignition. You may need an aftermarket IMS gear lever with a bend in it to clear wider stator set up.
So lights on CR480 is definitely do-able but its gonna come down to the dollars you have available, your DIY ability or finding a place to do the job for you.
Also try contacting www.bajadesigns.com and they may have some old doccuments on the external stator kits they used to sell for CR500.
LWC3077 screwed with this post 12-27-2014 at 05:18 PM
LWC3077 is offline   Reply With Quote
Old 12-27-2014, 06:15 PM   #6
Mr. Carts OP
Oddometer: 394
Thanks for the info.
I pasted on the CR480 motor.
Going with plan A KTM495.
If I can find one.
Old 12-27-2014, 07:19 PM   #7
brucifer
brucifer's Avatar
Oddometer: 2,463
http://honolulu.craigslist.org/big/mcy/4771854839.html
The shipping would probably be a deal killer.
2014.5 Kawasaki KLR650 NE-2006 Buell XB12SS-2001 Husaberg FE650E-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F-1977 Yamaha TT500
brucifer is offline   Reply With Quote
Old 12-27-2014, 09:38 PM   #8
Mr. Carts OP
Oddometer: 394
I do not need the whole bike just the engine.
Thanks for the heads up though.
Times are GMT -7.   It's 04:11 PM.
