Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 12-20-2013, 09:48 AM   #1
ehteigland OP
Oddometer: 9
ABS/MSC on KTM Adventure 1190
Hi :-)
I have some questions on how the ABS/MSC are working.
I know when pulling the front break handle the rear brake force is also applied, but if I brake only with the rear brake will the ABS/MSC apply brake force also to the front?
Does it work like this?
Apply front brake force, brakes both wheels
Apply rear brake force, brakes both wheels
ehteigland screwed with this post 12-20-2013 at 09:53 AM
ehteigland is offline   Reply With Quote
Old 12-20-2013, 12:47 PM   #2
spencergt66
Oddometer: 784
From what I was told at the Ktm rally yes both applied regardless unless you have off road settings selected
spencergt66 is offline   Reply With Quote
Old 12-21-2013, 12:43 AM   #3
OrangeV
OrangeV's Avatar
Oddometer: 673
Thumb Msc explained
here are videos explaining MSC and the benefit they give the rider.
All 2014 KTM 1190 Adventure will have it standard from the factory.
2013 models can have it fitted for about $300 to $500 not sure on that.
The 1190 Adventure will be one of the safest bikes on the market.. worth a test ride for sure..
http://www.visordown.com/road-tests-...rol/23615.html
75 V perky peak power from around 5000rpm and loves to be worked through the gears.
When you hit that sweet spot, it is simply electrifying. Stoner
A smile is a curve that sets allot of things straight..
OrangeV is offline   Reply With Quote
Times are GMT -7.   It's 09:48 PM.
