Old 07-16-2006, 08:06 PM   #16
rjf
SBS's #1 fan in January
rjf's Avatar
Location: Gosford, NSW, Aust. Scrambler, 640Adv, 300EXC
Oddometer: 4,376
Originally Posted by warewolf
(btw I can't find the diagram in this thread - broken link?)
This diagram ?
Central Coast ADVenture bike training courses and 1 on 1 lessons - For details Click HERE
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadslide, thoroughly used up, totally worn out and loudly proclaiming- WOW-WHAT A RIDE!
rjf is offline   Reply With Quote
Old 07-17-2006, 12:29 AM   #17
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,598
Originally Posted by rjf
This diagram ?
Yep, thanks.
Cheers,
Colin
KTM LC4 640 Question? Check here first --> KTM LC4 (640) Index Thread
The Stable
warewolf is offline   Reply With Quote
Old 07-23-2006, 11:16 PM   #18
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,598
Cool2 This mod rocks!
Finally managed a test ride last night.
The "Plus 50s" definitely throw out enough extra light to be worth while.
Adding low beam to high is great. When you dip your lights your eyes don't have to adjust to a different patch of light thrown on the road; you just lose some of the distance illumination (which is not where you are looking if you are forced to dip your lights by oncoming traffic) to the point that a couple of times I had to check that I'd dipped my lights.
However, no amount of forward lighting shines around corners so you still have to slow down more for the tight stuff or use moonlight to pick out the road ahead of your lights...
Cheers,
Colin
The Stable
Old 11-22-2006, 01:14 PM   #19
Mulga
Mulga's Avatar
Oddometer: 112
Thumb Cheers
Cheers, I wired the lights on the weekend. AUD$20 and about one hour of my time.
Dan
Mulga is offline   Reply With Quote
Old 01-04-2008, 09:34 PM   #20
paddythesmith
paddythesmith's Avatar
Oddometer: 216
another way?
My winter electrical project is still a work in progress, but here's what I've found so far on my 02 640 adv:
Ran 12g wire x2 (+/-) from battery to front of bike, with pos. with 30amp fuse near battery and 40amp relay bolted into tubular frame hole on either side of headlights. Relay is powered by one of the unused molex style connectors facing forward of the headlights; these come on with the ignition. When I take the rear rubber cap off the low beam and disconnect the stock pos. lead, it reads about 0.5V less than a 12g. wire coming off my new relay (with a fuse block between). That is, e.g. 12.4V vs 12.9V. I was expecting worse, as that molex style connector is putting out about 11V.
In any case, I made good use of our nanny and brought her out in the garage to decide which lighting she liked better. The 12g wire with the additional 0.5V made for much better lighting. In addition, when you go to highbeam, the lowbeam does not turn off (i.e. they both stay on). I'm planning on replacing the stock wiring to both high and low beam with this new wiring setup. For the highbeam, I'll use it's pos. lead to trigger an additional relay; that way I'll be able to make use of the stock highbeam switch.
In short, I wouldn't have thought 0.5V would make a bit of difference, but it does.
02 KTM 640 Adventure
06 BMW R1150GS ADV
heard at work:
''everything was going great, until it wasn't"
paddythesmith is offline   Reply With Quote
Old 09-04-2008, 01:01 AM   #21
makazica
makazica's Avatar
Oddometer: 749
Is it possible that somebody posts an actual picture of the things that need to be done for the lights to be on together. Is it necessary to get a relay to do this?
Thank you, electrics is not my thing.
makazica screwed with this post 09-04-2008 at 01:47 AM
makazica is offline   Reply With Quote
Old 09-04-2008, 07:57 AM   #22
PlavaKuca
xxx
PlavaKuca's Avatar
Oddometer: 0
Evo, nadjoh u garazi...
PlavaKuca is offline   Reply With Quote
Old 09-04-2008, 09:22 PM   #23
KTM_Paul
Sans KTM
KTM_Paul's Avatar
Oddometer: 1,399
Cut which wire?
Royal Enfield MotoGP rider
KTM_Paul is offline   Reply With Quote
Old 09-04-2008, 09:56 PM   #24
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,237
Anyone have a aftermarket supplier of the bomb squad gear? I don't want to pay KTM prices for that!
meat popsicle is offline   Reply With Quote
Old 09-04-2008, 10:06 PM   #25
KTM_Paul
Sans KTM
KTM_Paul's Avatar
Oddometer: 1,399
I wonder what that stuff would do if the bomb exploded? I don't expect you'd be getting up and walking away, and if you did survive it you'd probably wish you were dead anyway!?
Old 09-04-2008, 11:01 PM   #26
meat popsicle
Ignostic
Oddometer: 14,237
I don't really know, but ballistic Kevlar is supposedly bad ass shit, so if it is designed properly not much should get through it.
Old 09-04-2008, 11:26 PM   #27
makazica
makazica's Avatar
Oddometer: 749
First of all,
thank you Plava Kućo! You are the man!!
Hvala ti i za sve drugo! Razgovarao sam s jednim tapetarom i kaže da bi mi mogao malo podići Renazco sic koji ti imaš, pa kad skupim lovu javim se, kaže da bi me to koštalo cca 200kn.
Ballistic kevlar....helps, but this close, he might as well be naked dancing a funky chicken.
Check Plava Kuca's garage sale, the man has loads of goodies.
Old 09-05-2008, 05:56 AM   #28
PlavaKuca
xxx
PlavaKuca's Avatar
Oddometer: 0
First of all,
Page deleted, post was to old...
Inace ono gore moze i bez osiguraca, ja ih nisam stavljao, samo spojis zice...
Onako treba izgledati kada je gotovo.
Sto se tice tapetara, nema problema, ako ti to pase...
PlavaKuca screwed with this post 09-05-2008 at 06:03 AM
Old 12-21-2008, 11:39 PM   #29
makazica
makazica's Avatar
Oddometer: 749
As electrics are not my thing, I need a little help with wiring both headlights together....I own a 2001 Adv. model and even though I have seen the diagram I cant figure out what I need to do, so please help....step by step....
Here's the pic of how It looks on my bike.....
I don't plan on including a fuse, I have info it is going to work without it as I don't use heated grips or heated west's...
Thank you!
Old 12-22-2008, 12:26 AM   #30
PlavaKuca
xxx
PlavaKuca's Avatar
Oddometer: 0
Heba ga patak....
1. utikač na fotki desno
2. poanta je struju sa smeđe-zelene žice, gornji red 2. (srednja) žica
spojiti na žutu, donji red 1. (lijeva) žica
znači npr. odrežeš žutu malo dalje od utikača, dio te žute koji je ostao na utikaču spojiš nekako na smeđe zelenu žicu, (stopicom ili skineš izolaciju na smeđe zelenoj pa pričvrstiš žutu, ostatak žute u glavnom kablu izoliraš i zaboraviš.
Times are GMT -7.   It's 06:18 AM.
