Old 12-24-2013, 09:23 PM   #1
Clayclev OP
Oddometer: 33
73 rt1 360 converted to Mx360 motor help
I've got a 73 Rt1 360 and striped it down to mx. I've been racing it and it's been really enjoyable. But when I go to the bigger tracks it seems like the bike is a turd.. Is the rt1 motor the same as the mx360? The rt1 dt1 and mx bikes all look alike and all have interchangable parts. I just ordered new work shocks and circle f pipe. Trying to figure out how to post some pics of the bike. I'm on the iphone app
Clayclev is offline   Reply With Quote
Old 12-25-2013, 12:08 PM   #2
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,412
Hi Clay, welcome. More info, pics please. What has been done? Plug chops? pics of plug please. These RT's had a different feel, low -end grunt, but fell off on the top. Did you run through the crank seals? GYT pipe on hand?
Old 12-25-2013, 12:29 PM   #3
Clayclev OP
Oddometer: 33
Im on the iphone app and it only has a URL link for photos. I'm use to clicking the pic icon and just open my library and downloading pic. I'll have to learn something new.. :(. I have put lighter front wheel. Work shocks mx tank. Newer kawi seat and basonni pipe on. I went threw the motor and put new crank and rod in. It does have good low end but doesn't have good rpm rev. And falls on its face.
Old 12-25-2013, 12:39 PM   #4
Clayclev OP
Oddometer: 33
And me racing against post vintage watercooled. I won this race.
Old 12-25-2013, 06:14 PM   #5
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,412
"Im on the iphone app and it only has a URL link for photos. I'm use to clicking the pic icon and just open my library and downloading pic. I'll have to learn something new.. :(. I have put lighter front wheel. Work shocks mx tank. Newer kawi seat and basonni pipe on. I went threw the motor and put new crank and rod in. It does have good low end but doesn't have good rpm rev. And falls on its face.
That is, unfortunately, the nature of the beast. The Dt250 would rev and continue to make power way higher in the rev range. If you tune to exploit higher revs, you will lose some bottom/mid (hence power valves). What reeds are you running? That Bassani pipe may not be the best for top end. GYT Kit pipe was good, back in the day. Be careful, sneak up slowly on the power peak, that big piston WILL squeak, I can tell you from experience. The finning is marginal on that cyl. A thinner head gasket can help the squish band that's very wide from OEM.
Old 12-25-2013, 06:16 PM   #6
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,412
we'll need a WOT plug chop... if we're too fat, we're giving up TONS of power
Old 12-25-2013, 06:24 PM   #7
Clayclev OP
Oddometer: 33
I have a dt250 motor I have to redo might throw that in it. I ordered a circle f pipe. People swear by it plush I'm tires of the pipe burning my gear now.. Everything on rt1 motor is stock. I took the oil pump out.
Old 12-25-2013, 06:50 PM   #8
baloneyskin daddy
bikaholic
Oddometer: 2,100
I believe the MX ran a single ring piston that was lighter and allowed freer revving and also had a close ratio gearbox.Try taking some weight off the flywheel.
baloneyskin daddy is offline   Reply With Quote
Old 12-25-2013, 08:48 PM   #9
Clayclev OP
Oddometer: 33
Will an mx360 gearbox fit in the rt1 case?! I'm sure it will cause most everything is interchangeable
Old 12-26-2013, 07:27 AM   #10
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,261
rt1 motor is nothing like the mx360 performance wise.... you could spend a fortune to make a rt1 perform like a stock mx360. but i'm assuming you have a rt3, not an rt1 (you said 1973- rt1 is earlier). rt3 is reed valve..
either way, here are the big differences:
mx360 has bigger carb, internal rotor flywheel, cylinder/porting, head, transmission, counterbalancer (removable), bigger reed cage, better airflow, etc etc. the mx360 makes gobs more hp.
current bikes
stainlesscycle screwed with this post 12-26-2013 at 07:38 AM
stainlesscycle is offline   Reply With Quote
Old 12-26-2013, 10:07 AM   #11
Clayclev OP
Oddometer: 33
Thanks for the info. The case says rt1 and was told 73 when I bought bike. That doesn't bother me if it's a different year. I can swap out motors. Before I was gonna do that I wanted to know if the transmission for mx360 would fit in the rt1 case
Old 12-26-2013, 03:39 PM   #12
Clayclev OP
Oddometer: 33
Was wondering also, will I have to switch to a mx360 head when my circle f pipe comes in? No big deal if nobody knows I'll find out when I get pipe.
Old 12-26-2013, 06:11 PM   #13
stainlesscycle
Oddometer: 2,261
i would assume you will at least need to change the head, as the mx360 fins are shaved on right to allow pipe fit.. i'm not familiar with rt3 airbox setup, but mx360 airbox is pretty small to allow pipe crossover to the left. the rt3 pipe didn't crossover so i bet it's got a pretty good sized airbox..
current bikes
Old 12-26-2013, 06:13 PM   #14
stainlesscycle
Oddometer: 2,261
there is a big difference between rt1 and rt3 - does your bike have reeds? - it looks like it does in the pics.
i don't know if trans will swap. the mx360 cases are way different in the front half, for the counterbalancer setup. i don't know if back half is the same.
current bikes
Old 12-26-2013, 06:57 PM   #15
Clayclev OP
Oddometer: 33
I have removed the air box to save weight I have a k&n filter with sock on it now. Also the motor has reeds
Times are GMT -7.   It's 10:00 AM.
