Old 12-26-2013, 06:06 PM   #16
Clayclev OP
Oddometer: 33
I most be confused. The block has Rt1 stamped on it and has reeds so this makes it a 73 rt1 360 correct. What is a rt2 and rt3?
Clayclev is offline   Reply With Quote
Old 12-27-2013, 07:33 AM   #17
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,270
all the motors were stamped rt1. the rt2 and rt3 have reeds. i believe rt1mx/ rt2/rt3 came with 21" front wheel. the regular rt1 and maybe early rt2 came with 19" front wheel. there's a vin chart somewhere to decode the rt models.
1973 would be an rt3.
more info
http://articles.superhunky.com/4/109
http://www.flattrack.com/index.php?o...c&limitstart=0
current bikes
stainlesscycle screwed with this post 12-27-2013 at 07:39 AM
stainlesscycle is offline   Reply With Quote
Old 12-27-2013, 11:15 AM   #18
Clayclev OP
Oddometer: 33
Ok that's where the confusion is!! Bike is a 73 rt3. Dumb yamaha doesn't make since they mark it a rt1 when it's a rt3. I just bought a pair of 75 mx250 forks.
Old 12-27-2013, 02:05 PM   #19
stainlesscycle
Oddometer: 2,270
awesome upgrade. now you have suspension! throw a mx360 top end at it, and a bigger carb(i'm assuming you have a 32 or 34 on there.) /reeds to match that pipe/cylinder and it'll be a rocketship.
current bikes
stainlesscycle screwed with this post 12-27-2013 at 03:18 PM
Old 12-27-2013, 05:03 PM   #20
Clayclev OP
Oddometer: 33
What would be a good choice of reeds. Boysen? I've got the circle f pipe coming. I'm sure that will work.
Old 12-27-2013, 05:17 PM   #21
stainlesscycle
Oddometer: 2,270
boyesen works. either way you're gonna be jetting quite a bit.
current bikes
Old 12-27-2013, 08:36 PM   #22
Clayclev OP
Oddometer: 33
I looked into the boysen reeds. They have them for the rt360. $32.50. Will there be any difference for that price?
Old 12-28-2013, 08:49 AM   #23
stainlesscycle
Oddometer: 2,270
sure, there will be a difference - there's always conflicting opinions though... if you plan on swapping a mx360 top end these reeds are probably smaller. if your intake will take a bigger carb (i think your reedcage has bolt on/flange mount carb, and not clamp on type - which makes a finding a bigger carb tougher usually...) a bigger carb for $100 or less would make more top end power than a change in reeds will... a 36mm carb (or maybe a 38) could make a big difference..
i think your reedcage takes 603 reeds - they can be had for about $25 usually. the bigger reeds for the other cage are around $30 (606)
either way you're gonna need to reject both pilot and main for that pipe... i would do 1 step at a time, rejet for the pipe, then install reeds and rejet again for the reeds. changing everything at once is a harder jetting task.. and you can feel the difference each mod makes....
current bikes
Old 12-28-2013, 01:34 PM   #24
Clayclev OP
Oddometer: 33
As I only race the mo vintage series and 2 arhma nationals a year. I will just keep the rt1 motor with circle f pipe a boysen reeds. I will be getting some work done to the cylinder and I'll have a mx360 head as the rt1 head doesn't have the fin cut out for the circle f pipe. Hopefully these mods will wake up the top end and rev quicker.
Old 12-28-2013, 01:52 PM   #25
advNZer?
advNZer?'s Avatar
Oddometer: 2,903
dt3 and rt3 were tractors.My dt3 had a bottom end to match my mates xl250,it was pretty flat up top,rt3 was the same but with more grunt everywhere
aka BMWST?
advNZer? is online now   Reply With Quote
Old 12-28-2013, 02:05 PM   #26
Clayclev OP
Oddometer: 33
By what everyone says. I have a rt3. Just confusing when the block says rt1 lol
Old 12-31-2013, 07:51 AM   #27
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,856
rt1 motor is nothing like the mx360 performance wise.... you could spend a fortune to make a rt1 perform like a stock mx360. but i'm assuming you have a rt3, not an rt1 (you said 1973- rt1 is earlier). rt3 is reed valve..
either way, here are the big differences:
mx360 has bigger carb, internal rotor flywheel, cylinder/porting, head, transmission, counterbalancer (removable), bigger reed cage, better airflow, etc etc. the mx360 makes gobs more hp.
Oh Yeah,the Omni Phase balancer. I had one of those engines sitting here,just the bottom end.
I remember a near 70lb shipping weight,just the bottom of the engine,good lord how can they stuff that much weight in a 2 stroke?
If the OP is winning races against CR500's on a fluffed up 360 enduro,he may not need more power. The handling is a little suspect on those enduros.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 12-31-2013, 12:31 PM   #28
Clayclev OP
Oddometer: 33
That pic with the cr is a 250. Track was short with lots of turns. Haven't raced any 500s yet.
Old 12-31-2013, 09:02 PM   #29
MaicoMan490
Poach it or Lose it
Oddometer: 9
Thumbs down 360 cc, rt1 mx
The only Bike i ever had that would switch over & Run Backwards !
Imagine Climbing a Big Hill, Down Shifting to get over the Top ? Bang !
And Switch-a-Rue , Your now Charging down Hill Backwards !!
We checked everything ?? Timing, Jetting ???
It happened when the engine was Hot ! Not Good !!
Sold that Sucker , FAST !
MaicoMan490 is offline   Reply With Quote
Old 01-01-2014, 12:00 AM   #30
Clayclev OP
Oddometer: 33
Bahaha. Gotta know how to ride 😂. Can't just go out there and try to be a pantie dropper. You'll it up like this ^^^^^. ✌️
Times are GMT -7.   It's 12:00 AM.
