Old 12-29-2013, 12:09 PM   #1
chill622 OP
Oddometer: 32
Is Acc1 on '13 990 "baja" used for LED lights?
Working on wiring up Garmin and heated grips and only find the Acc2 wires. It looks like the Acc1 leads are used for the LED lights that came on this bike. Is this true? I'm pretty sure the Acc2 is un-switched so this should be best place to plug in for both heat and gps. What do folks usually use the Acc1 leads for?
chill622 is offline   Reply With Quote
Old 12-29-2013, 02:43 PM   #2
chill622 OP
Oddometer: 32
I'm an idiot. Found it, the acc1 powers the 12V cig outlet on the dash.
Old 12-29-2013, 02:52 PM   #3
wheeler23
wheeler23's Avatar
Oddometer: 78
Acc2
Just put on heated grips today and the Acc2 "hot with key on" leads are behind the left turn signal panel just above some relay blocks on my Baja. The ground was the brown wire and the hot was red with a black stripe (I think it was black?) they both had clear rubber boots on them with a female spade connector. Not sure where Acc1 is located? When I pull the 15A high beam fuse my LED lights go out so I don't think they are on Acc1. Looks like Acc1 would be a "hot all the time" since it also says clock?
Ride it like you stole it!!!!!
KTM 990 Baja Edition, KTM 250SXF, KTM 150XC
wheeler23 is offline   Reply With Quote
Old 12-30-2013, 11:14 PM   #4
Sikorsky
The Man.
Sikorsky's Avatar
Oddometer: 222
Gotta hook up a set of KTM grips on mine ........ subscribed to find out the truth, I know it's out there.
Sikorsky is offline   Reply With Quote
Old 12-31-2013, 12:10 PM   #5
chill622 OP
Oddometer: 32
The ACC1 leads power up the 12V power outlet and the Hazards.
Old 01-01-2014, 07:58 PM   #6
Zuber
Zoob
Zuber's Avatar
Oddometer: 1,984
On the Baja, KTM powers the LED lights using the 15a light fuse. They do a slight of hand using the Euro light switch. The switch used to have OFF/Parking/Lights. Now it has Lights/LED with HIGH Beam/LED ON?
They use exactly the same switch, but add a small relay.
"Son, you can't do both"
Times are GMT -7.   It's 01:18 PM.
