Old 05-28-2014, 12:30 PM   #1
attaboy OP
Let's go for it!
attaboy's Avatar
Oddometer: 40
Question Bizarre Valve Noise -video- KTM 950 ADV
Calling your wisdom Inmates
My 950 ADV is noisy as hell. Here's a video to better demonstrate, Please suggest your best fix but read below before:
I just did all this:
- I read the Wisdom of the 950.info website, along with possible causes...
- Valves are in spec
- Oil Screen clean
- Oil filter clean, no coolant, no distortion
- Check-valve below oil reservoir is very clean, small filter as well, and ball-spring seems ok (!!)
- Fresh oil Motul 5100 15w50, proper level 50% mark
- Cam Chain tensioners are both at 48 mmm
- New Oil sensor has been screwed in
- New NKG iridium spark plugs CR8EIX
- Water pump has 2000 km, doesn't leak, running Engine ICE and no foam pudding in crank vent tube.
Idiot OIL light still blinks... is it the oil "by-pass" ?? I am getting tired at changing everything in hope to find the culprit !!!!!
http://youtu.be/uDUcLyVq_-w
Orange Aficionados
attaboy is offline   Reply With Quote
Old 05-28-2014, 02:00 PM   #2
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 886
That sounds like my 950 when the locking clip of the oil pressure valve came off (under the clutch basket). In +4k ervs, would be ok, but under that would rattle like crazy... since the locking clip came off, the spring came off too, and the piston that acts as valve was letting the oil pass when in normal conditions would be closed thus making more oil go to the heads.
Remove the oil screen and see if there is a spring pointing at it. don't worry too much the spring wont come off totaly neither the piston. the locking clip and washer... thats another story!
690R
Old 05-28-2014, 02:03 PM   #3
charlie264
charlie264's Avatar
Oddometer: 8,235
New oil filter? What make?
Old 05-28-2014, 02:23 PM   #4
attaboy OP
Let's go for it!
attaboy's Avatar
Oddometer: 40
I'll have to check for the filter. I still have a new K&N green box on my bench, but also a pink-red one.
Also thanks Gustavo, the screen is clean, i don't see anything near or in it. Do you mean the little spring hiding behind the main cover, close to the oil pump?
Orange Aficionados
Old 05-28-2014, 03:38 PM   #5
Gustavo.Ramos
Oddometer: 886
The spring+piston is contained where the red arrow points
690R
Old 05-28-2014, 08:00 PM   #6
charlie264
charlie264's Avatar
Oddometer: 8,235
Go buy an OEM filter, put on side stand...you wont lose much oil, and any contaminants will run out. Throw the K&N filter in the bin.....They are too restrictive for the LC8....
http://www.ktmforum.co.uk/adventure/...ml#post1749066
charlie264 screwed with this post 05-29-2014 at 04:57 AM
Old 05-29-2014, 06:53 AM   #7
attaboy OP
Let's go for it!
attaboy's Avatar
Oddometer: 40
K&N to restrictive? damn...
I also have an HiFlo model 158 (green-black box) on the bench. Its been sold to me by ADV experts apparently, should I trust this one will work?
***EDIT: Charlie I read all you other thread... Maaaan. I will give it a shot. Talk about ripping a freakin' bike apart when the filter is guilty? I'll follow up with the results, because other than the by-pass spring everything else has been changed. Also, do you guys put 10w50 or 15w50 in? right now here its 15 celcius outside.
Orange Aficionados
attaboy screwed with this post 05-29-2014 at 07:01 AM
Old 05-29-2014, 07:04 AM   #8
charlie264
charlie264's Avatar
Oddometer: 8,235
Read the thread, K&N are better quality, that's the problem. Order an OEM, stick the Hi-fo in....if it eliminates the problem....there is your solution, good till OEM turns up. If not then it could be the pressure release valve....I doubt very much....
Old 05-29-2014, 08:01 AM   #9
OrangeDevil37
OrangeDevil37's Avatar
Oddometer: 311
i could be wrong but it sounds like a cam chain to me? when my 250f KTM cam chain tensor was going out it sounded just like this. keep in mind my computer speakers suck so I could be far off on the sound.
2013 990 adventure baja
2009 250sx
2008 690 Duke
2006 250sx-f
OrangeDevil37 is online now   Reply With Quote
Old 05-29-2014, 08:14 AM   #10
attaboy OP
Let's go for it!
attaboy's Avatar
Oddometer: 40
mmm yeah but the Cam Chain Tensioners are both in spec at 48 mm each.
Orange Aficionados
Old 05-29-2014, 08:51 AM   #11
uk_mouse
Aquatic adventurer
uk_mouse's Avatar
Oddometer: 1,464
My original 950 engine kept stretching cam chains. I've no idea why, but every 20,000 miles it'd get horribly noisy, the oil light started flickering at idle, classic symptoms that most people would say indicate a failed water pump seal.
I changed the cam chains twice, but then I got sick of it and bought a newer engine - a 2008 model I think. This engine is much quieter and I've put another 40,000 on it without any similar problems.
My theory is that if the cam chains stretch, the tensioners will protrude a bit further into the engine, and maybe that allows oil to leak past them, hence the oil pressure light flickers. Or maybe it's the chains flapping around (as they are not properly tensioned) that causes the CCTs to move and thus causes fluctuations in the oil pressure. Who knows? But the point is, it seems to be possible that low oil pressure at idle is a symptom, not a cause.
As for the oil filter ... it won't do any harm to run it without a filter for 5 minutes, that'd tell you whether the K+N is at fault. Oh, and I always use HiFlo HF158 filters, simply because they are what the local bike shop sells, never had any problems with them.
"When compared to other motorists attempting to escape a zombie outbreak, dirt bike riders have a 23-to-1 survival rate." - The Zombie Survival Guide by Max Brooks
uk_mouse is offline   Reply With Quote
Old 05-29-2014, 08:59 AM   #12
attaboy OP
Let's go for it!
attaboy's Avatar
Oddometer: 40
Thanks UK_Mouse
Wow, you were NOT lucky man
But thanks for the tip about trying it without a filter for 5 minutes. I suppose since my engine is clean from all the recent mods and flushes it would be ok.
Orange Aficionados
Old 05-29-2014, 11:31 AM   #13
charlie264
charlie264's Avatar
Oddometer: 8,235
Thanks UK_Mouse
Run an engine without a filter...... a) its designed to have that restriction. b) If a bit of crud moves....blocks oil jets. c) irreversible damage.
Only every as a last resort.....
Old 05-29-2014, 12:13 PM   #14
keith_irl
Oddometer: 82
Check your exhaust headers and pipes for pin hole leaks.
My bike sounded like that until I replaced the pipes. Sounds silly I know but thats all it was.
keith_irl is offline   Reply With Quote
Old 05-29-2014, 07:09 PM   #15
Scribe
£Bob£
Scribe's Avatar
Oddometer: 7,175
Mine sounds like that for a few seconds but it always goes away, leading me to think cam chain tensioner might be be stuck? It has happened to others.
"Do or do not. There is no 'try.'"
— Yoda
Man Ball Rolls Through Coloutahrado 2014!
Scribe is offline   Reply With Quote
Times are GMT -7.   It's 01:40 AM.
