Old 04-21-2014, 09:09 AM   #166
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,568
PS, you need to change your Profile tag line so its more better... KTM 990 SuperDuperEnduroR....
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 04-21-2014, 09:56 AM   #167
DirtJack
DirtJack's Avatar
Oddometer: 1,459
Originally Posted by Head2Wind View Post
I have not completed a bracket for the instrument pod yet, its just sitting there. I was going to mount it to the top of the headlight, where the other one was mounted, but the thing is, you cannot see it when sitting down and even when standing its not that easy to see through all the control cables,hoses and wires. It needs to be in a spot that is protected, or at least not going to get easily wiped off the bike when it takes a dirt nap... The HWDB upper clamp has provision for a billet mount on the front, but then it gets in the way of the front brake hose... So, to say the least, I have not completely figured this portion out yet.
H2W, Paul now has a mount for that dash (same as 690 and very similar to the 950 SER front end). I was able to route the brake line between the bars and dash. My 690 may have been the prototype for this mount.
Forks fully extended:
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 04-21-2014, 10:04 AM   #168
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,568
Thanks for the reference! Email sent to HWDB and Paul. We _might_ have to have a custom hose made (Galfer does it for me) so that it fits correctly with the bars and risers that are on it now. Will have to take a closer look at it tonight.
Old 04-21-2014, 11:59 AM   #169
Dan950ser OP
NW Shredder
Oddometer: 402
Copy and paste. I was thinking I might put my lower bars off my SX on if those felt to high with the rox system. Don't know if that will make the difference so we don't need a new brake line or not...
2007 KTM 990 SuperDuperEnduroR
2014 KTM 250 XC-W
Dan950ser is offline   Reply With Quote
Old 04-21-2014, 12:49 PM   #170
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,568
I believe that either way a different hose is going to be needed, will know more tonight.
Old 04-21-2014, 08:21 PM   #171
DirtJack
DirtJack's Avatar
Oddometer: 1,459
Forgot to mention that my 690 is a 2008 (250 mm suspension) and has 2" bar risers.
2008 KTM 690 Enduro
Old 04-26-2014, 09:32 PM   #172
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,568
Performed the first shake down ride. Everything is working well and it runs pretty darn good. Still need to complete the forward wiring section that interfaces to the bar controls. I may also need to relocate the ECU down about a inch so it will easily clear the fuel cell and the return line... it fits but its tighter than I would like.
Dan, you are going to like this I am sure!
Head2Wind screwed with this post 04-26-2014 at 09:40 PM
Old 04-26-2014, 10:58 PM   #173
Dusty
Dusty's Avatar
Oddometer: 1,272
Thumb
Very nice!!!
Originally Posted by d0gWateR
Vagrant, vagabond, transient, hobo, bum. But park a motorcycle next to him and PRESTO! He's an advrider!
Dusty is offline   Reply With Quote
Old 04-27-2014, 12:29 PM   #174
Dan950ser OP
NW Shredder
Oddometer: 402
Motor sounds like it's running well for sure. Did you start the motor in gear and take off with the kickstand down just cause you could?
2014 KTM 250 XC-W
Old 04-27-2014, 01:34 PM   #175
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,568
No........
Got slightly distracted this morning... could not pass on this CL find... PW80 for cheap
Preparing the next generation to keep the flame.
Now onto finishing up the 990 SE
Head2Wind screwed with this post 04-27-2014 at 01:49 PM
Old 04-27-2014, 01:59 PM   #176
Dan950ser OP
NW Shredder
Oddometer: 402
Nice little starter bike. I can't wait till my daughter is old enough to start riding! She is only 17 months but I still always keep an eye for a great deal on a crf50 or something comparable.
2014 KTM 250 XC-W
Old 04-27-2014, 07:37 PM   #177
Dan950ser OP
NW Shredder
Oddometer: 402
Ken will you post a picture of the subframe bracing when you get it done?
2014 KTM 250 XC-W
Old 04-27-2014, 08:04 PM   #178
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,568
Yes, will do.
Old 05-06-2014, 10:04 PM   #179
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,568
After several weeks and week ends of occasional work on the 990 SE EFI project I managed to focus some time on it this past weekend as well as the past several evenings to get a few things finished.
Since this bike gets _USED_ and with a load on its back some times, the rear subframe needed some minor repairs as well as gusseting to make it strong enough to hold up to BAJA....
All the bits are removed from the frame....
Fractures next to the thread inserts...
The back of the frame..... I can completely understand why KTM will not stand behind subframe failures when there is _ANYTHING_ other than a rider mounted to the back of the bike... icky..
The surgery center
Preparing one side of the gusset
Both gussets welded in and now fitting the aft section
all finished up and welded.... I am not a welder by trade, and definitely have room to improve, but this fix should be fine for quite some time.
Onto fixing the luggage racks, both of the aft sections of the mount were completely broken...
The fixed version...
Hopefully _COMPLETELY DONE_ back here....
Old 05-06-2014, 11:20 PM   #180
Eldon
950 ADV
Eldon's Avatar
Oddometer: 523
Nice job. I love this build!
05 KTM 950 ADV. Black (Black ones aren't faster. Fast riders just buy them)
06 YZ250 Smoker
00 KTM LC-4 - Sold
93 CR125 - Sold
89 CR80 - Sold
84 XR80 - Sold
74 Honda MR50 - Sold and I wish I hadn't
Eldon is offline   Reply With Quote
Times are GMT -7.   It's 04:16 PM.
