Old 03-07-2014, 09:47 AM   #121
PowerCell
Manufacture
PowerCell's Avatar
Oddometer: 2,368
Originally Posted by Head2Wind View Post
Making progress, albeit slower than anticipated...
That wiring harness is giving me 'Nam flashbacks...
Great stuff!
~ Ken
www.powercellperformance.com
PowerCell is offline   Reply With Quote
Old 03-07-2014, 03:20 PM   #122
chasbo
chasbo's Avatar
Oddometer: 1,626
Wow, what a cool build!
"Dakar must be a race for few people, Dakar is a dream, the dream of the Rose Lake, if everybody finish it, the dream is over" Fabrizio Meoni
chasbo is offline   Reply With Quote
Old 03-07-2014, 03:56 PM   #123
charlie264
charlie264's Avatar
Oddometer: 8,270
Thanks for the complements. I'm glad to be given the opportunity to do something that I really enjoy doing. As soon as this one is completed I get to refine my process and build at least one more... if that one goes well, then there will be another right after than too.....
These throttle bodies are from a 2010 RC8, very good to know that the later model system changed as well as the spacing. I will keep that in mind when hunting for donor parts. I test fitted them to the 990 engine last night and they drop right into the manifolds, and therefore will fit the 950 as well. I _assume_ (and will verify before hand) that the throttle body harness is wired the same between the 990, I don't see a good reason for it to change, but sometimes strange decisions are made between models. I suspect that the injectors are a different rating and therefore will require a different tune to support them.
Interesting, seeing the figures banded about the RC8 seems to get better mpg over the LC8.
charlie264 is online now   Reply With Quote
Old 03-07-2014, 04:43 PM   #124
Dan950ser OP
NW Shredder
Oddometer: 418
Awesome work Ken! Thanks for the update and video. It's nice to see my girl coming along.
2007 KTM 990 SuperDuperEnduroR
2014 KTM 250 XC-W
Dan950ser is online now   Reply With Quote
Old 03-07-2014, 04:58 PM   #125
Dan950ser OP
NW Shredder
Oddometer: 418
So I was just catching up on the SE is a turd thread and was reminded of a question I meant to ask you Ken. Are you making the headlight an on/off switch?
2014 KTM 250 XC-W
Old 03-09-2014, 06:27 PM   #126
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,572
Dan has the SicAss left bar switch on order, will be landing at ADVmachines.com soon so we can include it in the custom wire harness build. Thanks for the reference to a excellent solution to a common desire.... 'ability to turn of lights'. IMO this _should_ be a default on any 'adventure' machine so that the operator can choose as the conditions require.
As promised I have been doing my best to get a few of the _major_ fabrication needs done, all associated with the fuel delivery systems.
The coarse filter is mounted to the left/front engine bracket, then the fuel pump is spaced and bracketed to allow a very tight fit between the two and get them into a area where I felt they belonged.
The process begins creating a pattern
From paper to 6061 T6 alum
Its a tight fit with a bunch of hoses and fittings in a concentrated area.
View from the back of the bracket
Bracket in place and filter and pump securely mounted, with fuel hoses cut and clamped.
The next task is to create a mount/heat shield for the fine filter...... the pattern making process includes skillfully using a hammer of all things.....
using a hammer to mark the forward intake manifold in card stock, this is the result
The card stock pattern is finished and fitted to the engine....
Mount and shield rough cut and ready to be bent
part bent and ready to have the holes cut
'slight' modification of the opening to accept the OEM grommets
Part fits! pretty nice fit too.... This will work for all those other open filter systems out there as a heat shield too.....
Fine filter system set into place.
slight modification of the injector fuel rail nipple allowed me to position the filter body aft to gain a better angle to the output of the fuel pump for the filter.
Nice fit and orgnization of the lines and fittings with a dual purpose mount that will keep the heat off the throttle bodies as well as the filter.
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 03-09-2014, 07:18 PM   #127
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,749
Interesting placement. Great work getting it to fit so nicely.
Q. Are you using a regulator and why does the front valve cover have a oil breather and the rear not?
Pete
Turtleshell5@icloud.com
For those who sit at home and dream-let them...Meoni
Pete640 is offline   Reply With Quote
Old 03-09-2014, 07:24 PM   #128
JRod152
will work for tires
JRod152's Avatar
Oddometer: 301
Strong work, Ken!
Keep it coming... w/ pics!
"Never let the things you want make you forget the things you have"
JRod152 is offline   Reply With Quote
Old 03-09-2014, 08:19 PM   #129
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,572
Yes, we are using a Cannodale 440 FPR housing with a Eurospec 3.5 bar FPR inserted. Located in the lower right section of this pic
None of the US models have venting on the rear cam cover... however I have seen some high HP setups on custom builds that take a ADV dual vent front cover and link it to the forward cover. With the SE, there is only a single hose that vents to the top of the oil tank, where the ADV has two.
Old 03-09-2014, 08:36 PM   #130
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,572
fine filter is clamped to the Vee shield
As with any custom build, sometimes the first iteration of a bracket and placement of system is not optimal.... I had to move the fuel pump forward, down and toward the centerline of the frame to clear the low fuel sensor.... so the bracket changed slightly as well as the fasteners....
The high pressure line is now mated to the fitting that attaches to the fine filter and so as it stands right now the fuel system is completed! WOW.... I have to say that its been more work than I anticipated... The FPR is mounted to the right frame rail, just aft of the ECU. The return line runs just to the left of the ECU and has a Quick Disconnect on it that plugs into the upper/center section of the fuel tank.
Old 03-10-2014, 03:13 PM   #131
Dan950ser OP
NW Shredder
Oddometer: 418
I'm really liking the way the heat shield/fine filter mount turned out. Looking forward to be able to take the tank off with out messing with any wiring or fuel line in the way.
2014 KTM 250 XC-W
Old 03-10-2014, 03:47 PM   #132
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,572
As it is right now, you will have one electrical plug to deal with for the low fuel light sensor. Then three QDs, two on the lower tank sections for delivery and one up top for the return. ONE bolt in the back, a little pull out on the sides of the tank and a slight pull back and up and away it comes..... no hose clamps, or hose nipples to mess with... HOWEVER (there is never a perfect solution is there?), the QDs can be grumpy and the o-ring can get caught up in the mating fitting. I put transmission assembly lube on all three of them and it has made the process much better... but with lube, comes 'sticky', and when dust is involved we all know where it likes to stay... :/
I pulled the shield/mount off last night and am in the process of getting it into CAD. The finished part will be laser cut and CNC bent out of .048" Stainless, which is a much better metal for heat rejection than aluminum and will fit under any open filter system with the OEM lower airbox grommets.
Old 03-10-2014, 05:42 PM   #133
Two Moto Kiwis
Homeless Somewhere
Two Moto Kiwis's Avatar
Oddometer: 3,818
Admirable work Ken, admire your fussy and perfect approach to doing it right
Andi (oveja negra) & Ellen (chica amarilla)...Two Moto Kiwi Grüvers .....riding Maya somewhere ..Una Chimba
Two Moto Kiwis Home Page ..Danger Is Real ... Fear Is Optional
For More Of Two Moto Kiwis Photos
....Where The Hell Are We .. Spot Us
Two Moto Kiwis is online now   Reply With Quote
Old 03-10-2014, 06:05 PM   #134
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,572
I have a few years under my belt making machines go fast in circles on both dirt and asphalt and win races in nasty conditions. If it isn't built to take a bullet hit, be light while doing it and serviceable in under 5 minutes we were riding in the back of the pack. IMO, it needs to be top notch durable for the conditions that the SE will be in, no system failures.
Old 03-10-2014, 06:26 PM   #135
Two Moto Kiwis
Homeless Somewhere
Oddometer: 3,818
When are you moving to New Zealand?
As a builder of a very controversial street fighter I took an unreliable bike that caused more grief than an angry mum in law and turned it into a ride-able , reliable bike by doing it properly, I loved the build, in excess of 200 hours of engineering fun
155 kg, 77 RWHP, more torque than a politician ... total hooligan
If you get 5 (after finishing Dans bike or need a coffe break) here is a coupla links or just google Andi Delis Malattia MH900e and hit images
I can appreciate the work you are doing, when back in NZ I will build a street tracker for fun.
http://www.ducatimonster.org/feature...red-nov05.html
http://www.bikeexif.com/ducati-streetfighter
Times are GMT -7.   It's 08:30 AM.
