Old 12-15-2014, 04:49 PM   #1
perfect-fairings OP
Oddometer: 132
KTM 690 ENDURO Rally Fairing -Parts
I would like to introduce you our rally fairings for the KTM 690 ENDURO.
Our fairings designed to fit perfectly with and without big tanks (e.g. SAFARI)
We have 2 types
1.For standard headlight
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Type 2 . with two vertical lights
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Price 199 euro ($270) both types ,just the fairing
Complete KIT 749 euro ($975) ,fairing for OEM headlight -frame adapter and navi tower
Complete KIT 849 euro ($1100) ,fairing - LED light (1200lumens,12W)-frame adapter and navi tower
Also we have carbon fiber heat shields for the exhaust ,price 99euro ($130)
[IMG][/IMG]
and the 450RR/690RR fairings
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
We also have the skid plate 690RR ,front lower fenders.
For the forthcoming Dakar 2015 we are sponsors for 2 teams
1.SPFiFTYONE Racing Team with 450RR
2.All Tracks Racing Team with Yamaha Raptor
Here you can find all our products
www.perfect-fairings.com
contact info
info@perfect-fairings.com
Thank you very much for your time!
Dim
perfect-fairings is offline   Reply With Quote
Old 01-20-2015, 01:14 PM   #2
perfect-fairings OP
Oddometer: 132
Hello everybody ,
we would like to introduce you our new rally kit for the 690!
After several thoughts we finally build a light rally kit with new short external fuel tanks 10L total capacity which comes with the 450rr fairing!
All brackets and the nav tower are build from MT-Rally,all are from high grade aluminium .
Rally kit includes:
fuel tanks ,complete with caps
navi tower
450RR fairing
brackets
LED lights
price is 1999 euro and shipping cost is for EU 70 euro and rest countries 95 euro
Separate parts :
front lower fender RR type 140euro or 950/990 type with brackets 175 euro
Skid plate carbon fiber RR with brackets 450 euro ,with water/tool box 650 euro
Pump complete system
This kit will be available 15/02/2015
You can pre order this kit for 1650 euro plus shipping cost (2 kits are still available)
[IMG][/IMG]
We accept paypal (+6%) and bank transfer .
Old 01-22-2015, 11:20 AM   #3
theofam
Oddometer: 425
Is it possible to only buy the tanks? If so, how much are they, and is the pump system necessary for proper fuel flow, or is it gravity fed? If a pump system is required, how much is it?
theofam is offline   Reply With Quote
Old 01-22-2015, 01:13 PM   #4
perfect-fairings OP
Oddometer: 132
Yes ,we sell separate the tanks.
You need a fuel pump,we are working to find the best solution and we hipe to have a compkete pump system very soon available .
Price for fuel tanks is 900euro ,tanks come with brackets and KTM OEM caps.
Thank you!
Old 01-22-2015, 04:26 PM   #5
theofam
Oddometer: 425
Thank you!
Thank you for the response. I'm interested in your tanks once you develop the pump solution.
Is it possible to see a picture of a 690 with only the tanks installed?
Old 01-22-2015, 04:29 PM   #6
perfect-fairings OP
Oddometer: 132
I will update with pics soon !
Thank you
Old 01-23-2015, 12:39 PM   #7
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 1,040
It would be easy to use the same vacuum operated pump, to transfer
fuel from the front tanks to the rear, as the Quest kit.
A very simple setup.
About the kit.
Does the stock seat fit ?
I'm assuming a low pipe needs to be used ?
Do you have any plans to build extra protection for the
exposed lower part of the tanks ?
What's the total weight ?
Will these tanks fit the 2014/15 bikes ?
Max
Da oggi la strada
senza limiti
MAXVERT is offline   Reply With Quote
Old 01-23-2015, 02:39 PM   #8
perfect-fairings OP
Oddometer: 132
Originally Posted by MAXVERT View Post
It would be easy to use the ste vacuum operated pump, to transfer
About the kit.
Max
Hello Max
Weight we will know it when we have the products ready,as we can see from prototypes the fuel tanks are light.
These tanks designed in order to work with all stock parts and the consumer to not make any change in the stock bike,just mounting the brackets and then the tanks.
About if they fit on the newer versions we dont have try to mount them on a 14/15 models..
Thank you very much
Dim
Old 01-23-2015, 03:04 PM   #9
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 1,040
[IMG][/IMG]
Simon Pavey's race bike ! Nice.
Did you make the rear tank ? Doesn't look stock with the low exhaust
hanger.
Max
Da oggi la strada
senza limiti
Old 01-24-2015, 10:59 AM   #10
perfect-fairings OP
Oddometer: 132
[IMG][/IMG]
hanger.
Max
Max
we didn't make the tanks on Pavey's bike only the fairing.
Our new tanks are smaller than the OEM rally KTM tanks (we are preparing and a bigger version for about 18L total) .
You dont have to change seat or exhaust pipes !
Old 02-07-2015, 04:24 AM   #11
perfect-fairings OP
Oddometer: 132
Finally we finished our prototypes!
some pics of the kit how it looks ..
[IMG][/IMG]
[IMG][/IMG]
[IMG][/URL][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
price is 2190euro and includes everything except fuel pump.
Old 02-07-2015, 07:52 AM   #12
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 1,040
Could you give us some information on the composites used.
Construction methods; handlayed, bagged, etc.
Are the tanks coated inside.
Will you have a guard for the bottom of the tanks available.
Some pics of your mounting brackets to the frame.
Will it fit the 2014/15 bikes ?
How many liters of fuel.
Skid plate available ?
Just trying to figure out if this will withstand crashes common with
rally riding.
Also I'd suggest using the tank mounting hardware KTM uses on their 990's.
The rubber grommets with inserts.
Looks Great !
Max
Da oggi la strada
senza limiti
MAXVERT screwed with this post 02-07-2015 at 08:03 AM
Old 02-07-2015, 08:15 AM   #13
perfect-fairings OP
Oddometer: 132
rally riding.
Looks Great !
Max
Max,
fuel tanks are handcrafted ,made from rovin fiber ,epoxy and vinylester resins.Not coated inside.
Capacity is 10L total.
We are making tank protectors ,carbon kevlar.
Skid plate with toolbox/water box is coming soon
the bottoms are extra reinforced .
it will fit the newer models with different brackets ,soon available .
Tanks also can be carbon kevlar if anyone ask for it .
i will take a look on KTM's mountings !Thanks for the info
this is the nav tower with the frame adapter we use
[IMG][/IMG]
Old 02-07-2015, 12:34 PM   #14
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 1,040
With 10 extra liters the 690 will have a total of 23 liters or around 6 gal. US
That will get most riders 300 + miles ( 480 + K's )
Perfect.
Max
Da oggi la strada
senza limiti
Old 02-15-2015, 01:03 PM   #15
perfect-fairings OP
Oddometer: 132
As now we are in production of the 690 Rally KIT we would like to say a big thanks for all your support and interest in our new "challenge".
Because of the big interest we would like to offer 5 KITs in the price of 1790,00 euros .
[IMG][/IMG]
Times are GMT -7.   It's 04:22 PM.
