Old 01-05-2014, 02:53 PM   #1
brooks OP
Oddometer: 323
Stripped insert on fuel tank
I had the top insert spinning on the left hand fuel tank while stripping it down for some maintenance- The one the upper fairing secures to. It ended up coming out so now I need to get it back in and glue it in place. What is a good epoxy or something similar that can be used on the fuel tank? Any advice on how to get it back in? Thanks!
Brooks
Brooks
brooks is offline   Reply With Quote
Old 01-05-2014, 02:57 PM   #2
renogeorge
Oddometer: 1,367
JB Weld
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Old 01-05-2014, 04:34 PM   #3
brooks OP
Oddometer: 323
There is like 4 types.
Brooks
Old 01-05-2014, 11:37 PM   #4
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,925
Someone in here used another approach.
He spun the whole insert with a drill inside its housing. As things got hot, plastic melted and then glued back.
Hope it helps.
Old 01-07-2014, 01:46 AM   #5
Zuber
Zoob
Zuber's Avatar
Oddometer: 1,984
The tank is fiber glass enforced nylon. Zip-ties are nylon. You could partially fill the hole with melted nylon, then heat the insert and .... insert.
"Son, you can't do both"
Times are GMT -7.   It's 03:55 PM.
