Old 07-28-2014, 05:50 PM   #241
tedmarshall
tedmarshall's Avatar
Oddometer: 547
Eek Sorry for typo Phil: meant LS2!
Ted Marshall
tedmarshall is online now   Reply With Quote
Old 07-29-2014, 07:37 AM   #242
Phil_Ammendolia OP
No Guz No Glory
Phil_Ammendolia's Avatar
Oddometer: 178
Originally Posted by tedmarshall View Post
Hi Phil:
I am circling Lake Superior. My new modular refused to latch. (The cheek pads won't stay fastened either, but that's minor.) I could force the metal pin into the latch for the first 2 days of my trip. But today at speed near Wawa, Ontario the latch let go of the upper part of the helmet. Helmet used 12 times. Not abused, dropped, etc. It wasn't safe. So I bought a Polaris snowmobile helmet to get me thru this trip safely. The motor sports dealer here is shipping my LR2 back to me in Chicago.
I'd like to keep my LR2. It is hi-viz and works well (mostly).
What do you advise?
Ted Marshall
Hi Ted,
Wow! So sorry to hear the trouble you had. I've not had anyone report a problem like this before. We'll get you taken care of. I'm sending a PM to you. Please take a look.
Thanks,
Phil
Phil_Ammendolia is offline   Reply With Quote
Old 07-29-2014, 08:22 AM   #243
vtduc
Oddometer: 149
Originally Posted by Phil_Ammendolia View Post
Hi Ted,
Thanks,
Phil
I had the front latch fail a couple of times on my FF386. The cable from the front button comes out of its guide. Both times I was able to pull out the inner chin foam to gain access to fix it. I now try to be very careful when using it. Other than that the helmet has been good so far (used maybe 15 times over 1K miles)
vtduc is offline   Reply With Quote
Old 07-29-2014, 02:48 PM   #244
Phil_Ammendolia OP
No Guz No Glory
Oddometer: 178
LS2 Helmets FT2 - Full coverage helmet - Retractable sun shield
The LS2 FT2 full face motorcycle helmet is fiberglass, DOT/ECE approved, has a retractable sun shield that has replaceable lenses, inflatable cheek pads for a great fit and fully adjustable flow through ventilation. If you like a full face style helmet, this is a great value, starting under $200.
You can see all of the available graohics at http://ls2helmets.us/_live/products/...e/82-ft2-ff396
Old 07-29-2014, 02:59 PM   #245
Phil_Ammendolia OP
No Guz No Glory
Oddometer: 178
LS2 Helmets FT2 Graphics
Other colors for many of these graphics can be seen at http://ls2helmets.us/_live/products/...e/82-ft2-ff396
Retractable sun shield lenses are replaceable and are available in dark smoke, light smoke, HiViz (amber), and clear.
Old 07-31-2014, 07:19 AM   #246
cognosticator
cognosticator's Avatar
Oddometer: 773
Phil, I wear glasses. When putting on the FF386 and the visor open, does the helmet go on without disturbing my glasses. On my Shoei Neotec I could spread the helmet enough to where it would not move my glasses going on or coming off. Can you answer that, thanks
Jerry Holland
COG 4478
2011 Triumph Speed Triple
Man, you were haulin' ass the other day when I passed you
cognosticator is online now   Reply With Quote
Old 07-31-2014, 07:54 AM   #247
sjc56
Oddometer: 1,371
I wear glasses with my LS 386, plastic frames, no problem.
Steve
sjc56 is offline   Reply With Quote
Old 07-31-2014, 08:03 AM   #248
cognosticator
Oddometer: 773
Thanks Steve, so are you happy with the helmet?
Jerry Holland
COG 4478
Old 07-31-2014, 08:09 AM   #249
sjc56
Oddometer: 1,371
Pretty much, only real thing that bugs me as others have mentioned, you can't just crack open the face shield for a little air, even when cold I like to crack the shield, plus it fogs up very easy so I got the anti fog insert. I have had it for a year and it is holding up fine.
Steve
Old 07-31-2014, 08:10 AM   #250
cognosticator
Oddometer: 773
Did you get the same size as you have with other helmets. I wear a med in Shoei and most other helmets but a Scorpion I need a large Thanks
Jerry Holland
COG 4478
Old 07-31-2014, 08:28 AM   #251
sjc56
Oddometer: 1,371
When I had Shoei's I wore a small and thats is the size I have with the LZ ,fits me perfect better then my Nolan's did which where a medium. I have an oval shaped head.
Steve
Old 07-31-2014, 08:29 AM   #252
cognosticator
Oddometer: 773
Great, thanks for all the info, I will leave you alone now
Jerry Holland
COG 4478
Old 07-31-2014, 08:34 AM   #253
sjc56
Oddometer: 1,371
No problem.
Steve
Old 07-31-2014, 08:35 AM   #254
cpallen
Nearly Adventurer
cpallen's Avatar
Oddometer: 1,003
I also wear glasses and have no problem. I do have to spread the helmet a little but have to do the same on my shoei multitec.
Mine came with an extra foam piece for the crown, which I had to install to keep the helmet liner from hitting the top of my glasses.
Courtney in Seattle
'13 BMW F800GT, '07 G650X Challenge '13 C650GT Scooter
cpallen is offline   Reply With Quote
Old 07-31-2014, 08:47 AM   #255
cognosticator
Oddometer: 773
I just ordered one from Amazon, I got the Focus Graphics Should have it tomorrow for my ride Saturday
Jerry Holland
COG 4478
Times are GMT -7.   It's 05:14 PM.
