Old 01-07-2014, 10:30 PM   #1
dezracer OP
dezracer's Avatar
Oddometer: 640
18k major maintenance. Your advice is appreciated.
My 07 is going in to shop. I have had zero issues other than a fuel pump failure at 2500. I have done regular oil changes and valve checks, new spark plugs, brake pads ,etc. I ride mostly dirt but not too hard on it for most part. What do you guys think I should have done?
3 things on my list for sure: oil change, new air filter, radiator flush. Optional stuff maybe water pump seal kit, new fuel filters, new sprockets and chain, grease head and swing arm bearings. Anything else you guys can think of or what I should I spend my money on would be very much appreciated..thanks in advance.
2007 990 Adventure
Suspension by Super Plush
Rekluse Pro Auto Clutch
WINGS N.O.S Exhaust
Euro Headlight with PIAA bulbs
KTM Hard Parts Radiator Cover
CJ Racer Clear Spoke Clutch Cover
Hilslamer Long Pegs
GPR Stabilizer
DH Racing tripleclamps
'300' Throttle Cam
16t CS Sprocket
Mefo "Super Explorers"
Ram Mount Garmin 76c
PABIKER sidestand relocaton kit.
2007 KTM 300XC (long live lightweight 2-strokes)
Las Vegas, NV and the Great Mojave Desert
dezracer is offline   Reply With Quote
Old 01-08-2014, 08:37 AM   #2
dezracer OP
dezracer's Avatar
Oddometer: 640
Any thought or suggestions mates.? Thanks
2007 990 Adventure
WINGS N.O.S Exhaust
Hilslamer Long Pegs
GPR Stabilizer
'300' Throttle Cam
16t CS Sprocket
Old 01-08-2014, 08:41 AM   #3
DirtyADV
DirtyADV's Avatar
Oddometer: 2,245
Back out and grease the chain adjuster bolts possible drill drain holes but maybe your bike don't see much water?
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 01-08-2014, 09:14 AM   #4
renogeorge
Oddometer: 1,367
Definitely replace fuel filters. Check stator/voltage regulator for sign of inadequate charging. Check sidestand switch for proper attachment/frayed wires. Shock and forks should be serviced if not since new. Check brake pads/rotors for wear. Definitely replace chain and sprockets if original.
Rob a bank, second on house, win lottery to pay for it all.
FWIW
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Old 01-08-2014, 01:11 PM   #5
dezracer OP
dezracer's Avatar
Oddometer: 640
Lol. Good stuff. Suspension has been serviced several times. Forgot to mention that. Thanks got the other recommendations. Good stuff.
2007 990 Adventure
WINGS N.O.S Exhaust
Hilslamer Long Pegs
GPR Stabilizer
'300' Throttle Cam
16t CS Sprocket
Times are GMT -7.   It's 05:04 PM.
