Old 09-02-2005, 01:38 PM   #1
Dark OP
Dark's Avatar
Oddometer: 944
Had to plug a tire today
I’m not anal about much, one of the things I am anal about is air pressure in my tires.
Moto, car, trailer, whatever….if it is between me or a loved one & the pavement I’m anal.
So on a pre ride tire pressure check I noticed I was down about 10 PSI.
WTF?
I take a look & sure enough foreign object.
So, open the tool kit get the plug repair tools & material & go to work
Out with the foreign object, in this case a 1.5 “ screw
Clean the hole
Insert plug
Trim plug
Done - 15 minutes including picture taking time
So, how long can these 880’s last with a plug?
I figure I got 6-8K of tread left on them.
Can I ride em out of tread with a plug in them?
I don’t ride that hard & rarely see triple digit speed.
Mostly highway speeds of 70-80. Occasional gravel.
Dark is offline   Reply With Quote
Old 09-02-2005, 02:29 PM   #2
SteveAZ
SteveAZ's Avatar
Oddometer: 1,181
I've heard some people say "don't worry 'bout it, it'll do fine with the plug."
I've heard other people say "the tire is a no go now, must replace. Very dangerous."
Me, I'm more towards the former. If I thought I had 6-8K miles left on the tire, I would likely trim the plug on the inside of the tire and put a patch over it on the inside. OTOH if I thought I had 1Kmi left I would simply take the attitude "don't worry 'bout it, it'll do fine with the plug." In fact, this is what I've done on both cars and motos.
But that's just me....
SteveAZ is offline   Reply With Quote
Old 09-02-2005, 06:58 PM   #3
G-Force Junkie
G-Force Junkie's Avatar
Oddometer: 1,328
Thats a lot of miles to run on a plug. I would at least have a shop pull the tire and install an umbrella plug/patch and remount the tire. Shouldnt be more than $50 if you bring the wheel in off the bike.
G-Force Junkie is offline   Reply With Quote
Old 09-02-2005, 07:20 PM   #4
Rad
Just me
Rad's Avatar
Oddometer: 12,172
You won't find a regular bike shop that will do that in the US.
Ride it, watch it, check the pressure a lot. The worst that should happen is ya get a slow leak. I ran mine a few thousand miles before I replaced my tire.
Rad is online now   Reply With Quote
Old 09-02-2005, 07:27 PM   #5
Loadedagain
making chips
Loadedagain's Avatar
Oddometer: 26,730
really? do it all the time up here... worked in a tyre shop as a student. we did patches all the time. just had one done on my jetta a couple months ago when i picked up a nail. $30 cdn including taking the wheel off my car.
** iba - 22936 *** Alcan5000 - 2006, 2008, 2012, 2014 ***
Stenhouse Racing - Specializing in KTM Upgrades
custom cnc service available to suit your specific needs.
Loadedagain is offline   Reply With Quote
Old 09-02-2005, 07:47 PM   #6
Lone Rider
Registered User
Oddometer: 25,130
What Rad said.........
You can always have the tire dismounted and patch it from the inside yourself. Done properly, it should last until the tread is gone.
Lone Rider is offline   Reply With Quote
Old 09-02-2005, 08:02 PM   #7
HarveyMushman
commutingmysentence
HarveyMushman's Avatar
Oddometer: 16,235
Hey, Mike!
You change your own tires, right? Like others have said, take this one off and put an "umbrella" patch on the inside and keep and eye on the pressure. It should be fine for the life of the tire. I ran a rear Tourance for ~7k miles like this with no problems.
Tim
photo galleries
HarveyMushman is offline   Reply With Quote
Old 09-02-2005, 09:23 PM   #8
Rad
Just me
Rad's Avatar
Oddometer: 12,172
You can get a car tire patched at any tire place or most gas stations. You will be hard pressed to find a bike shop that will patch a motorcycle tire in the states. A small independent shop may do it.
Old 09-02-2005, 09:35 PM   #9
gaspipe
Wandering Soul
gaspipe's Avatar
Oddometer: 11,352
I plug 'em and ride. Did one today. I'd surely be happier riding a plugged tubeless tire than a patched tube.
gaspipe [the original]
Hair of the dog....
gaspipe is offline   Reply With Quote
Old 09-02-2005, 09:35 PM   #10
matkal
Assault Commuter
matkal's Avatar
Oddometer: 1,651
After reviewing your pics I think you should have used a word other than anal to describe yourself
'09 R1200GS
Helmet laws suck. They interfere with natural selection.
ATGATT 35:12-14
"And Atgatt courted Motgatt, and took her for a wife.
And lo, he compromised with Atgmott, and verily she conceived,
and did bear a son, Notgatt. And Notgatt roamed naked,
and did bequeath his skin to the roads. And he was a wild ass and an outcast,
and was hated through all the land. And his forehead was branded, and he did be
come a sign and a warning to all the people."
matkal is offline   Reply With Quote
Old 09-02-2005, 10:01 PM   #11
Loadedagain
making chips
Oddometer: 26,730
it's not like he's plugging his ass... it's only a tyre.
Old 09-02-2005, 10:27 PM   #12
Waco
Renegade Sickle Hound
Waco's Avatar
Oddometer: 14,972
Get a Best Rest Cycle Pump or something equivalent if you don't have one already. I had a plugged hole once that would start leaking again after several hundred miles. If you have a pump with you, replugging the tire in a parking lot is hardly even an inconvenience.
Support the AMA.
Waco is offline   Reply With Quote
Old 09-03-2005, 09:12 AM   #13
SteveAZ
SteveAZ's Avatar
Oddometer: 1,181
...Ride it, watch it, check the pressure a lot. The worst that should happen is ya get a slow leak....
...I had a plugged hole once that would start leaking again after several hundred miles....
This is why if I thought I had more than a month's worth of miles left on the tire, I'm happy simply putting a flat patch over the trimmed plug on the inside. Very easy to do (don't even need to completely remove the tire) and patches are available anywhere.
Funny, but even the way message boards have a way of "amplifying" improbable events, I never hear of any tires that are simply plugged suddenly losing air or other "catastrophic" failure on any boards I've been on.
Hard for me to understand the paranoia about plugs.
SteveAZ screwed with this post 09-03-2005 at 09:27 AM
Old 09-03-2005, 09:33 AM   #14
DOD
idiot dirt rider
DOD's Avatar
Oddometer: 2,330
I had a plugged tire on my pickup explode. Probably because of loss of pressure while I was driving. It happened about 20 miles after I left the shop. For autos; no good tire shop will plug a tire. Automobile tire manufacturers definitely recommend against it.
After plugging a tire, the GS manual recommends a reduced maximum speed (pretty slow) and tire replacement.
Just remember that all of the control forces are transmitted through the tire/road interface.
I agree that if you are careful, the failure is a low probability event and many people have used plugs successfully. The possibility of tire failure is, however, significantly increased. If I can eliminate a risk for a few hundred bucks, I'll do it.
The difficult part of safety is that you don't get any extra, you just get to keep what you have.
DOD is offline   Reply With Quote
Old 09-03-2005, 11:45 AM   #15
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,734
I ran a plugged Bridgestone Exedra on my ST1100 for 4000 miles, no problems.
Would do it again.
Mike S.
'09 Bonneville Black, '05 KLR650, '07 Yam Majesty
AMA MSTA
http://www.reddeliciousband.com
tbirdsp is offline   Reply With Quote
Times are GMT -7.   It's 09:34 AM.
