Old 05-08-2014, 12:39 PM   #16
guglemonster OP
Oddometer: 249
KTM 1190 Cap filter
this is an early type for the KTM 1190 Fuel Cap, high flow filter
how it is fixed below the fuel cap
and how it looks like from the fuel cap
the newest generation has a full-media filter structure, different media and improoved design
guglemonster is online now   Reply With Quote
Old 05-29-2014, 03:00 PM   #17
guglemonster OP
Oddometer: 249
just to help Alex to mount his Mark II KTM ADV 1190 filter
as you can see, you have to remove some of the plastic around the tank untill you will reach the fuel cap directly
than you simply flip the fuel cap and drill the holes like for the 990
here he used same plastic but use the iron wire I sent you, it's more than enough ( in the picture an early 990 filter adapted to the 1190)
check the picture at the beginnig, as you can see the filter mut be mounted with the wings on each side to improve the internal volume of the filter itself
once mounted use some fuel hoose to push the corners of the filter in the rigth position.
once properly intalled it will slow downs refuelling a bit, depending also on practice and petrol station hardware, let me know.
about your question, 20/30 in NOT enought for a modern IE bike, but it will avoid sudden filter clogging and prefilter dirty drowing
you will have to change your original KTM filters eventually, but not as often or soon as bad petrol would demand
please keep me posted about the behaviour of my filters with mexican petrol.
thank you again
regards
guglemonster screwed with this post 05-29-2014 at 03:11 PM
Old 06-15-2014, 02:45 PM   #18
guglemonster OP
Oddometer: 249
new design for KTM SMR /SMT 990
new design MK I b and MK II b with neoprene for better sealing
it will prevent water and or petrol do pass below the plastic cap, typical problem of some early 690 and 990
advancing relentlessly :)
we have already a new proto finally for Safari Tanks and/or Acerbis caps....
hope to be able to post some new pics soon enough
Old 06-15-2014, 06:47 PM   #19
baddrapp
baddrapp's Avatar
Oddometer: 169
Are you going to leave the neoprene square? I would like to get one over sized so I can trim it to fit my application.
baddrapp is offline   Reply With Quote
Old 06-16-2014, 01:27 PM   #20
guglemonster OP
Oddometer: 249
the neoprene square is left to be adapted to the various mounting, SMR and SMT have different ways, customer mark it and cut it once they check the fitting.
if you want a bigger square you just name it and I will try my best.
is 3mmthick to serve as a special gasket.
may I ask the application?
regards
Old 06-16-2014, 04:48 PM   #21
baddrapp
baddrapp's Avatar
Oddometer: 169
I have a Husqvarna TR650. I have removed the stupid red reducer from the fill. Now it is way easier to fuel. The filter would be sandwiched between the tank and the fuel cap adapter.
Old 06-17-2014, 12:06 PM   #22
guglemonster OP
Oddometer: 249
yes it is exactly how we do it on the 990 SMR/SMT
please, post a picture and some measures.
regards
Old 07-14-2014, 11:38 AM   #23
guglemonster OP
Oddometer: 249
new fix with external automotive filter set-up
to totally avoid internal filter clogging, simpy remove the paper filter and wash the second generation ktm filter with injectro cleaner
special Akron hoses, 20-30 micron cap filter, 20-30 mircon new design for acerbis smal cap 0 micron filters
it fits perfectly below the screw cap, same design also for the TT safari 40 ltr tanks
ciaps
Old 07-14-2014, 12:11 PM   #24
ternus
El Gran Camino
ternus's Avatar
Oddometer: 91
I'm planning on going through the developing world with my KTM 1190 Adv R and expect to be encountering bad fuel. What filters do you have available so far -- any progress on aquastop/0-micron for the 1190?
Follow me from Boston to Argentina: Ride Report Main Site Twitter
2014 KTM 1190 Adventure R
ternus is offline   Reply With Quote
Old 07-14-2014, 03:12 PM   #25
guglemonster OP
Oddometer: 249
hallo
there would be no way for you to empty the filter in case of water
if you really think there is such a risk yo should use funnels while refuelling.
funnels have a 50 micron mesh filter, worse than the pump prefilter
or a funnel made of an inverted plasti bottle with a 0 micron acquastop filter, but is really slow
this was made using a winns additive bottle for a 690 that went to russia with 3 tanks
the o micron would not allow you to refuel tha fuel cap shape and position is really a pain in the back, for the 1190 I can only propose the 20/30 microns
it's the best compromise and for sure much better than not having any filter at al
we were checking some fuel pumps prefilter with low milage, less than 2000, black/choccolate and took me 4 washing (high concentration of clean petrol and injector cleaner letting the filter soak for 20 minutes each bath and blowing it from inside) to get them clean again
ciaps
Old 07-16-2014, 12:08 PM   #26
ternus
El Gran Camino
ternus's Avatar
Oddometer: 91
Fair enough. What's the cost of a 20 micron filter for the 1190 shipped to the USA?
Old 07-16-2014, 01:37 PM   #27
guglemonster OP
Oddometer: 249
hello
Mark I
Mark II
inverted bell shape (Mark II design, a bit slower but more efficient, Mark I faster and slighty less filtering) 20/30 microns is 25euros, we shipped to canada with international tracking for less than 8 euros :) we will share the paypal fees :)
name the type and let me know
guglatech@gmail.com
thanx
regards
Old 07-18-2014, 09:28 AM   #28
Alleycatdad
Unbunch yer panties!
Alleycatdad's Avatar
Oddometer: 1,439
Zero micron filters for 990 ADV safaris ordered.
I have to say, I'm super happy with the attention and service I've gotten placing this order. I waited too long with this on my list and then sent an email to see if we could expedite things if I ordered. I want the filters ASAP but shipping will be an issue, etc.... Basic pain in the ass "my poor planning is your problem" customer.
guglemonster shoots an email right back telling me that what I want is still kinda being developed and fine tuned and will tomorrow be quick enough to ship them?
That's kinda funny. By the time I get a reply out (we're working across a few time zones, as I'm in California), I've got another email with photos of the proposed final solution. This guy clearly dropped everything for me and I appreciate it.
In the end, due to time zone/email/work issues (slowing things down on my end) it's gonna take two days to get them in the mail.
Yes, guglemonster, that's quick enough.
Shipping's another issue but not one he can control, and sooner shipped is sooner arrival regardless.
Thanks for your efforts!
Steve
When in doubt, PIN IT! It may not help, but it'll sure end the suspense...
Wretched Exce$$ See ADVr's around the world-ADV spotwalla page
Riding Wretched Wretched Passes
Bad decisions make good stories.
Alleycatdad is offline   Reply With Quote
Old 07-18-2014, 10:37 AM   #29
guglemonster OP
Oddometer: 249
gosh I was sure you were going to complai about the color of the proto haahha that grey doesn't play with your orange haahahah
thank you very much, it's a real pleasure to help riders out there :)
if you want I'll let you have the pleasure to post the pics of your bike with you filters.
tomorrow, if the postal service will not play havoc with out plas, everything will be on it's way
must say I wish I could take part to such a great ride ahead of you
ciaps :)
Old 07-30-2014, 12:47 PM   #30
guglemonster OP
Oddometer: 249
sorry Steve :)
have to ruin your surprise :)
this will work for SAFARI and IMS big acerbis screw cap
fuel "sock" filter for fuel cap
Times are GMT -7.   It's 04:07 AM.
